Armytek partner c1 v2 glass is broken
Hope im in the right forum… I ve got a armytek partner c1 v2 everyday in my pocket, since 3.5 years and one day the glas is broken in my pocket. I send a Mail to armytek but they have no glass for me and said i can get a 30%coupon for a new flashlight.i want nö other i want my Partner back:-) … I only want to know what size the glass must have to order an ar glass at kaidomain or fasttech…
Is there someone who can measure it for me? It is the XM-L2 partner c1 v2
Thanks
The advice they gave you is probably best. Take the discount and use your old one for parts.
:cry: that was the answer i dont want…. Ok i try a new one
Thanks
So much for Armytek’s 10 year warranty :person_facepalming: This is repairable if you have some basic tools. The main issue is getting the bezel off, because this style has thread locker. There is an excellent guide on how to remove it here:
After that you just need a replacement lens from one of the usual sources. From what I recall, most Armyteks this size us a 20mm x 1mm lens, which is $2.25 at Kaidomain. You should double check the size with calipers before ordering through.
http://kaidomain.com/S022290-20mm-D-x-1mm-T-Multi-Layer-AR-Coated-Lens-1-pc
I ordered it…its 20mmx1.25. I found someone who measure it for me.
Thanks for your help
If you decide to buy new and sell the old one, pm me.
Ok when it doesnt fit i send you a pm
Not only that but boy is it military grade.
It also has no repairability apparently, even more military like…
