it's still there, just go to the store by the link you get from FREEME (or just to banggood :D ), and there will be a gift astrolux A02 (you can chose color, and led)
if you bought one already, you just have to buy second one, to get the gift :D
Thanks for the info.
I ordered one a few days ago and sadly I missed the free gift.
Thanks freeme.
This will be my first LEP
Remember to share your LEP experience with us when you receive your order.
Thanks freeme. This will be my first LEP
got it 2 days ago.
The PWM is so visible on low and high, thankfully on Turbo there's no visible PWM.
The parasitic drain is about 20µA-10µA jumping to around 100µA every couple seconds.
I'm getting 4.6A to 4.5A on turbo.
For build quality, the front bevel is sharp, the threads on tube from head aren't anodized, the tail one are.
The astrolux 21700 li-ion fit just right in the 26650 adapter, you can't use any thicker 21700 with it.
The A02 is crap, the threads are normal triangular, are horrible (hard to asamble), the button to. and it's not much brighter than Skilhunt E3A, and have narrower hotspot. But it's almost twice it size.
The 21700 astrolux li-ion discharged on 1A on Opus BT-C3100 v2.2 did 4383mAh
And well there's some staining on the 21700 astrolux li-ion, do I polish it?
Did you try to wipe it with a microfiber cloth? If that doesn't work, try a bit of isopropyl alcohol on paper towel.
after IPA 99% there are still visible some metal pitting, just wondering if it's rust. Will just have to check on it, from time to time.
Hi freeme,
is it still possible to get the code for the WP3 and the gift?
Would really like to order one…
THX,
Henning
There is no more free gift for WP3. [quote=henningap] Hi freeme, is it still possible to get the code for the WP3 and the gift? Would really like to order one... THX, Henning [/quote]
freeme,
have maybe any crazy deal for WP3?
Price is stated in title.
freeme, have maybe any crazy deal for WP3?
Any recommendation for diffuser that can be open? I heard that the diffuser for the Weltool W4 will fit it with an o’ring, but is there something better for it, that will just fit?
Again I have to answer my self :D
Found this: (it's plastic, so good enough for this, I'm not brave enough to use it with normal flashlight, because of the heat)
https://pl.aliexpress.com/item/1005003070794873.html
https://pl.aliexpress.com/item/1005003051209649.html
the 60mm fit ok, it shouldn't drop by itself, but is rather loose, and you can still take it out pretty easy (good for coloured lens)
the 59mm fit just right, but you can still take it out.
So I would rather buy 59mm
Used 3 layer of this https://pl.aliexpress.com/item/4001312966522.html for the flod
End well, you can avoid touching the sharp front bevel, there's a step inside, so It can't go any further.
Interested.
You got mail.
Interested.
Interested
Thanks
You got mail!
Interested Thanks
Interested
All replied.
Ordered. Thanks for the code!!!
+1
