How do I connect/solder bars to 18650 cells
6 posts / 0 new
mckeand13
I’ve got this 4×18650 battery pack for a bike light and the cells are pretty tired. I’d like to replace them, but I’m trying to figure out the best way to do so. They’ve got very thin bars connecting the cells on both the top and the bottom. It looks like those are spot welded, and I’m assuming won’t come off all that easily.
What options do I have as far as soldering something to join the cells. I’ve done plenty of soldering, just not directly to a battery. I assume heat is a major concern.
Thanks.
IMG-1813
Edited by: mckeand13 on 11/11/2021 - 23:18
wle
wle's picture
Last seen: 15 hours 25 min ago
use high heat and high power [minimize time on the cell contacts]
tin the bar and cell first
use lead solder [not lead free, melts lower]
use acid flux [i think]
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
mckeand13
Any suggestions on what to use for the strip? Maybe I could find some brass at the hardware store.
flydiver
Last seen: 8 hours 55 min ago
I use de-solder braid with a small bit of shrink for insulation in the middle. Easy to work with and has good throughput.
To Air is Human, to Respire….Divine.
d_t_a
Last seen: 8 min 55 sec ago
I often see pre-fabricated ‘nickel strips’ being sold by stores that cell batteries / battery pack / solar BMS (battery management system), I think they are used for joining batteries together to forma a a battery pack like the one on your bike.
However, I have no personal experience with those nickel strips nor with soldering directly to batteries.
I wonder if nickel strips are the best (budget?) choice or if there are some other better materials for joining a battery pack together though.
YuvalS
YuvalS's picture
Last seen: 14 min 33 sec ago
I am using regular wires (according to the current rating).
make sure to have isolation on the positive side since the heat may damage the thin heatsrink and expose the negative side.
My FW repository
My BLF/OL contest entries: 7th 8th 9th
