[Black Friday Deal]Sofirn Aliexpress Store~Deal price for all products
Thanx for the code, bought one! :+1:
Would be nice if the HS10 had an 18350 body option. Just a nominal size difference yet big punch up in mAh gain.
I’m curious about the c8l is it 21700 like the g and f?
Black Friday Deal start from 25th to 29th, more codes will update soon
You are the best
$2 unlimited code 30 pieces --1QMYAPO4H7LV
$3 unlimitd code 30 pieces---9ULIBJ6NNU3N
valid time from 25th--29th, during black friday deal
Thanks. I took advantage of ...
On Deal Now, thanks for all support
$3 unlimitd code update---9ULIBJ6NNU3N
hi ! I’d like to buy HS40, but only if the head can work on SP40 bodies (19650 & 18350) ?
thank you
HS40 and SP40 body tubes can be used interchangeably, as shown here.
(the body tube knurling pattern for HS40 has been changed to a horizontal instead of diamond pattern on the SP40)
HS40 does not come with 18350 tube though (but can use the SP40’s 18350 tube)
HS40 uses USB-C (tested charges at up to 5v/2A - so one shouldn’t probably charge an 18350 battery using this),
(USB C-to-C cable charging is supported)
while SP40 uses micro-USB port.
Thank you a lot for that answer (and yeah,with 2A, that makes sense that no 18350 tube is provided with that one)
The store on Ali has an ugly support service. I ordered the HS10, only the LH351D 5000K was available. I asked them: will there be 4000K, to which they replied that it will be in a week or so and they will send it if I am ready to wait. I did not cancel the order, increased the processing time, trusted and waited. The next day after the conversation, my ordered 5000K was sent. They answer my questions and indignations with laughing emoticons! Besides the word - freaks, I have no name for them ...
Sorry for you …
Instead of asking, I ordered the 5000K HS05 flashlight and a 2700K LH351D and did the reflow myself :wink:
I thought about the same. I even wanted to order a diode from them in parallel. But I thought: I'll ask ... So I asked!
Usually, Sofirn adds what I ask for when buying, but sometimes there are some miscommunication : either they forget or put something different. But I am happy overall !
(We’ll see if the HS40 and HS10 I just bought from them will come with or without spare LEDs …)
The last day now!!
EU countries order from aliexpress will not have VAT problem and avoid fines in future because of Abnormal declaration
Leave a code word (BLFGW) (during 7th to 10th .Dec Deal time) when ordering, and order amount more than $30 will get a free soft rubber diffuser
Good afternoon. Received Sofirn HS10 everything is in order, except for the absence of a clip and a lace on the hand. I do not need a lace, but the lack of a clip is disappointing. Useful thing. Reply from Sofirn: "The HS10 does not have clips or laces. Sorry because we made a mistake in the photos, sorry." How cute!
Hello Jackie
Can you maybe provide discount (code) for Q8 PRO without batteries.
Thank you
Kind regards
