I’m not so sure. The driver in the bottom of the head is not in a pill. It appears to be press-fit or glued in place.
There is what could be a small copper pill visible inside the top of the light. It could be a small pill holding the laser module, but not the driver. Or it might just a retaining ring holding an internal lens over the phosphor.
The LEP module is a cilinder that looks like threaded in place from the battery side. There is probably two wires coming out of the module that are soldered onto the driver, and the driver is then glued in place. To access the module you need to remove the driver. There is no holes from the front that can get you the option to poke with something. There are two small holes in the driver though, you may use that for prying but with the risk to ruin something on the driver.
while the Ant Man may be disappointing, it seems to be the best 14500 thrower for it’s size. All other 14500 throwers which outperform it have a bigger head. Hopefully Lumintop sells enough of the Ant Man to entice other manufacturers to produce more affordable LEPs.
But they were the first to do a really small LEP flashlight, and it works (although some better than others), and it turned out a better throwing flashlight than anything before in this size. Lumintop gets my credits for that.
Monomode, capable of 2A output at 4Vout (likely too much for the module used in the Ant Man, here it’s set at 1A), no thermal regulation (no MCU), but it does have LVP thanks to the R1/R2 divider on the Enable pin. We could do without the 2.5V voltage reference by connecting R3 to VOUT, but the current will be quite approximate due to the Vf variation, the LDO used for the VREF is quite cheap anyway.
By some miracle this BB converter is still in stock at Mouser and is actually slightly better than the one used in the lume1 driver.
With this it should still have a soft start at startup, the issue with the constant current topology I’m using in my other drivers is that it has the tendency to spike at startup, which apparently isn’t good for laser diodes.
For a more powerfull driver for driving a LEP module like this:
I would do something different since commonly available BB converter are not powerfull enough for 3A@4V, I would use a boost converter with a constant voltage output >= Vf and use a constant current linear regulation after that, since the Vf will be high even in thermal step-down the efficiency should remain good. A boost converter with passthrough would be used so that it just outputs Vin when Vin>Vout (e.g. when the battery is full).
The soft start function would also work properly in this case.
Ali don’t think so because I am using Texas_Ace’s calibrated lumen tube, and my throw measurements seem to support the higher lumens.
For throw I was using the LX1330B meter that is well regarded around here. I’m not saying there isn’t something I haven’t noticed, but I did run the tests multiple times now (4 times at different times).
I think there is just a laser lottery going on, and apparently I won this time. (In the past I always get under performing lasers, Welltool W4 that under performed, L2K that under performed), so good for me! If you look at the numbers that chibiM and djozz are posting, even they are considerably different.
