@Barkuti the problem is, I want to buy them for my bike, for off road riding, so I won't feel the heat.
And it's advertise to have thermal control, so I can't harm the led or battery, and I will probably use the 100% mode all the time, and trust that thermal regulation, if it works.
I want all the light I can get, without harming the battery or LED.
I tested again with second activated turbo and control works bu very slow down output. My M21B reached 70°C I turn off flashlight at that point. So be ware not use at all turbo or just use 35% or 50% output which is safe. Also on bike you have active coolling. I also used my M21B on my bike two weeks ago. On turbo it is stay about 2-3 min and step down. So for riding it is not best mode at all. Stay with 35% at which any boost Convoy drivers have stable output and you will be ok with temperature.
Hi Simon, any details over M21e with culpm/sft40, try checking your official store for details about output current but those but cannot find any. Thank you.
Recently install an SFT-70 6500K into S11 with convoy xhp70 6v4,8a 22mm single cell driver. The emitter does throw,it shows dot in the hot spot, but i think it has something to do with focusing or gasket set up.
Hello please could @Simon Mao / someone help answering following questions regarding H2? Convoy H2 LH351D
1) Can it be switched to 4 modes stepped permamently? If I do this, the next time i turn on, it is going to be in stepped mode? How do you change between steps? It states in product description:
2) Does the moonlight mode (hold button from off) works when the flashlight has been set to stepped mode?
3) Does it have charging indicator built in?
4) Can it take protected button-top 18650?
5) What is maximum power draw at 100%/turbo brightness?
6) Approximate runtimes?
1: Yes, it will stay in the stepped ramp unless you change it back to smooth. To change modes you just hold down the button from off, just like virtually every other e-switch light.
2: Yes, moonlight still works when using the stepped ramp
