【convoy】H4 and B35AM options are updated
@Barkuti the problem is, I want to buy them for my bike, for off road riding, so I won't feel the heat.
And it's advertise to have thermal control, so I can't harm the led or battery, and I will probably use the 100% mode all the time, and trust that thermal regulation, if it works.
I want all the light I can get, without harming the battery or LED.
I tested again with second activated turbo and control works bu very slow down output. My M21B reached 70°C I turn off flashlight at that point. So be ware not use at all turbo or just use 35% or 50% output which is safe. Also on bike you have active coolling. I also used my M21B on my bike two weeks ago. On turbo it is stay about 2-3 min and step down. So for riding it is not best mode at all. Stay with 35% at which any boost Convoy drivers have stable output and you will be ok with temperature.
Yes, all R9080
NVSW519AE
sm455M450L5R9080
NV4WB35AME
sm455E800KR9080
I will gradually use green ar-coated lens on all products
Hi Simon, any details over M21e with culpm/sft40, try checking your official store for details about output current but those but cannot find any. Thank you.
Can’t wait for this to happen. Hopefully soon.
By the way Simon, it has been more than 3 months on the Quad TIR,(S21C/S12 Base). How’s the progress?
Recently install an SFT-70 6500K into S11 with convoy xhp70 6v4,8a 22mm single cell driver. The emitter does throw,it shows dot in the hot spot, but i think it has something to do with focusing or gasket set up.
Hey guys, looking to buy a M3-C with battery, any discount code for this black friday?
8A current
The host is being oxidized.
Simon - when are you going to release your version of the Pioneman K80? I saw a photo awhile back on your Facebook page
Can you give us a sneak peek? Can’t wait for this flashlight!
What colours, drivers etc. are gonna be available?
Excellent news!
Hello please could @Simon Mao / someone help answering following questions regarding H2?
Convoy H2 LH351D
1) Can it be switched to 4 modes stepped permamently? If I do this, the next time i turn on, it is going to be in stepped mode? How do you change between steps? It states in product description:
2) Does the moonlight mode (hold button from off) works when the flashlight has been set to stepped mode?
3) Does it have charging indicator built in?
4) Can it take protected button-top 18650?
5) What is maximum power draw at 100%/turbo brightness?
6) Approximate runtimes?
1: Yes, it will stay in the stepped ramp unless you change it back to smooth. To change modes you just hold down the button from off, just like virtually every other e-switch light.
2: Yes, moonlight still works when using the stepped ramp
Pardon if already asked;
Can I get the L2 with the GT FC40 emitter? I really like the L2 length, but want the 26650 as opposed to the 21700 for longer runtime.
Thanks in advance
. [/quote] 8A current [/quote]
I see, Thank you Simon. i hope there's improvement in the ramping dynamics with the new driver.
Do all the FC40 leds on Simon’s store have good duv now? I seem to remember the first batch being a bit green?
How do they compare to the ones from rngwn?
25A driver is in production
use the 8A or 6A driver .
SST20/LH351D/219B/219C can be installed
