What is the current status of this? Also does anyone have a ballpark guess where the price would be?
This is sounding like a great light!
Wurkkos is still working on the circuit/driver design. No estimated date of completion for this yet.
I was just thinking about a light like this. Definitely interested!
Updated
Do you already know which LED to use in the final product?
12*LH351D +1*SFT40
We need more pics of the prototype please.
This is a exciting light concept. Can’t wait to see how it develops in 2022.
Is there a interest list for this light, I like to get one when available.
Almost looks like the bezel plate for the HD15 got reused as the switch plate on this light.
Having thought about the design, I think it would be best usable, if the flood and the throw section have each their own controller and their own Anduril2.
The two buttons could be arranged in a way so both can be pressed at the same time, if needed. So, the user could fire up the LEDs at one time or each segment alone.
The thermal mass has a bit of inertia, so if both controllers are sensing heat from the mass, they each can level off the power as best as possible, without the risk of starting an oscillating system, where one side regulates down while the other picks up the now free dissipation capacity and ramps up, and so on. The thermal mass will act as a damper on this.
High thermal mass actually kinda makes it harder to avoid oscillation. Regardless though, Anduril’s thermal algorithm is very averse to oscillations, so it shouldn’t be an issue. It has pretty strong dampening built in already, to keep the output relatively flat. It can oscillate a little sometimes on really hot lights, but the amplitude decreases rapidly, typically down to zero or near-zero within just one cycle. So it’s less of an oscillation and more of an overshoot-and-correction.
If there were two independent drivers in one light, they would likely react to each other but settle fairly quickly to a stable level.
The light isn’t using Anduril though. I’m not sure exactly how that was decided, but I think it may be because I’m not a circuit designer so I can’t just send a schematic plus firmware and have it manufactured. Or maybe it’s just because of the chip shortage… I don’t know.
Oh, you would be absolutely right, if the thermal mass also was coupled with high thermal dissipation. Then the slippage introduced by the mass would lead to oscillation with a LED power controller that does not have the dampening capabilities of Anduril2.
Actually, here we have just mass and very little dissipation. Simply spoken, the blob of metal will just heat up and stay so for a comparably long time. Referred to as inertia.
Any news?
Hopefully xhp50.3 is still an option, not just sft40.
And bright colored anodizing!
Test prototype available assemble with 12 LH351D 5000K and 1 XHP50.3 HI, something need update:
switch feeling
The brightness did not reach the expected value, maybe update the LH351D to a more power one
the handle, not sure
What were the lumen numbers? I really think most people here understand that if you are using 90cri emitters tgat lumens aren’t going to be mind-blowing. 12*351Ds from 3*21700 would have me expecting maybe 9000 lumens OTF.
Maybe the best lumens and beam quality for the money would probably be 5000k SST20s. Avoid xpg3/xpl2!
Also, the anodizing should be champagne as default.
yes, 5000k about 9000-9500lm, 6000K should have more
Please stay with LH351D. Most of BLF users will prefer that version. Also I prefer them over greenish SST20. Also LH351D is my favourite high cri led. If you want to switch to something powerful only reasonable will be xhp50.3
