Fixed, thank you. Can anyone do FWAA repair in Australia?
17 posts / 0 new
Sillen
Sillen's picture
Last seen: 2 days 20 hours ago
I was replacing glow gastket in my FWAA and ripped the top off one of the 219c 3000K.
Any suggestions on where I could find the service of someone who could replace either one or all three LED for a fee?
Edit: Change titles
Edited by: Sillen on 11/28/2021 - 08:12
Sillen
Sillen's picture
In despair I purchased a replacement from liteshop.com.au – they still had a 219c 3000K in stock.
Can anyone do or does anyone know of a business that can replace LED’s?
grin
Last seen: 5 days 21 hours ago
Maybe cutter.com.au
Sillen
Sillen's picture
grin wrote:
Maybe cutter.com.au
Kk, thanks for the suggestion – didn’t know they do service as well.
lazerEagle
lazerEagle's picture
Last seen: 1 hour 52 min ago
tim or owen might have a crack
- the best way to predict the future is to create it -
TimMc
TimMc's picture
Last seen: 11 hours 20 min ago
Happy to give it a go.
I’ve got 219B sw30, sw35 from Simon and some 219B sw45k D200 and sw45k D220 from Bob_McBob and azhu.
Owen is active on Reddit.
Sillen
Sillen's picture
I really appreciate it and it might be least complicated seeing as you’re in the neighborhood. Sending PM.
Tldd
Last seen: 2 months 1 day ago
If you’re feeling adventurous, it’s not a hard fix to do yourself. You will need a soldering iron, tweezers, and a stovetop. Unsolder the MCPCB, put it on a thick sheet of metal (frying pan?) and heat it up until the LED’s begin “floating.” Pull off the broken one, replace with a new one. Note the positive/negative directions by the notch.
jon_slider
jon_slider's picture
Last seen: 43 min 35 sec ago
Sillen wrote:
TimMc wrote:
219B sw30sw45k D220
I really appreciate it…
glad to see youre on your way to a solution Beer
TimMc just offered you my two all time favorite LEDs Crown
TimMc
TimMc's picture
Did you need to pry the ring around the MCPCB out to get the MCPCB out?
I picked up torches this morning from Sillen to swap 219B sw30 into FWAA and try to fix the WildTrail WT3M switch LEDs. Thanks Sillen for the extra torches to play with while fixing two. Beer
jon_slider
yes, it was not difficult
id30209 wrote:
you can see a slot at the top of the pic that makes for easy lifting of the ring
TimMc
TimMc's picture
Thanks! The ring required a bit of force and careful prying.
Lumintop FWAA Copper with Nichia 219B sw30 D180 R9080
Sillen
Sillen's picture
Thanks for the suggestion, one of these days I will do an LED swap but not a triple to start with. I knew Tim has done this before, including smaller lights and he has a proper ‘hotplate’ or whatever it’s called. Turns out I had ripped off one dome and damaged the other two so 3 new LEDs. Great work by Tim!
jon_slider
Proof of Light! Love
TimMc wrote:
Outstanding photo tutorial also. Grad
Sillen wrote:
Great work by Tim!
Congratulations! Beer
TIFisher
Last seen: 1 day 22 hours ago
Agreed, the step by step is fascinating. Very cool work Mr. TimMc.
TimMc
TimMc's picture
I’ve added some comments to the album for clearer step-by-step instructions in case someone wants to swap LEDs in their FWAA:
https://imgur.com/a/wkWavMG
A 10A 14500 cell might push the 219B LEDs a little too hard. A 3A 14500 cell may be safer.
jon_slider Have you modified Anduril for your FWAA’s with 219B LEDs?
jon_slider
no,
I do not know how to reflash Anduril 2 on a FWAA
fwiw
on my meter, the FWAA w 4000k SST-20 made slightly less than 1100 Lumens. With the 3500k 219b it makes about 800 lumens maximum.
I did try to burn up the 219b on Turbo, and failed
so, no worries…
Im using the Vapcell H10.
