Does this change your overall opinion of the light? Sounds like something like the K1 better meets your uses. I have a 4x18A, but as a toy, and I’m not sure what the “practical” uses most people have for theses super throwers. I’ve always wondered about that actually, I suspect most people here are in it for the giggles (myself included).
I guess I should have looked at the dimensions of the head and a size a reflector but I didn’t.
I’m still surprised it doesn’t have more output.My K1 which was slightly Modified by Tom E.with bypasses.Turn On is 5805L/ 528Kcd-1453 meters, using P42A.
128Kcd more throw.
That is 1800 more lumens and 128Kcd more throw.
Yes, also running on Anduril 2… not sure if that makes any difference in output. I kind of doubt it. You get 10 people to measure it and you’re going to have 10 different measurements. But he’s pretty good equipment I think he uses that Mauka light meter set up.
You are wrong about the lack of thermal regulation though.
Yes, there’s a 60 sec timed stepdown, but once it exceeds 60°C it steps down straight away upon reactivation. If you apply a fan and it drops below 60°C it starts increasing in output. The issue is that it won’t reduce the output and stabilize at something it can manage
Do you have runtime graphs that I can reference in my review? I’m basing the thermal regulation statement off of my observations at 1Lumen’s 3X21A review right now, since it has the exact same driver and the thermal characteristics of the two hosts should be virtually identical. That review does not show and increase in brightness once the light is cooled down below 60C.
That would entirely come down to one’s own preference as to what’s better. I sell these to my customers for hunting and the last thing you want to do is throw down range a too wide beam.
Griz - I’ll show you a graph a bit later, right now I’m running tests for my EC06 review. This EC06 is only handling 730 lumens with a temp limit of 50°C and room at 23°C. That’s not very impressive
Awesome! Looking forward to seeing that graph. Maybe one of these days I’ll buy some kind of logging thermometer, haha.
That sounds very similar to my results with Sofirn Q8 Pro. I need to update my graphs because I’ve gotten a lumen tube since, but I’m seeing almost exactly the same sustained output with a 45C thermal limit and 21C ambient temperature.
