Grizzly’s Updated Convoy 4X18A SBT Review – Still Incredible, but not quite as much as I thought
Just shows how much Flashaholic’s measurements are off. I measured 4100 lumens at 30 sec on the 4X18A and he gets 4920.
I don’t think that’s even possible on an 18A driver.
I measured 4800 at 30 sec on the Astrolux MF02S SBT and that was running at 35A.
How does it compare to the Convoy L7?
You are wrong about the lack of thermal regulation though.
Yes, there’s a 60 sec timed stepdown, but once it exceeds 60°C it steps down straight away upon reactivation. If you apply a fan and it drops below 60°C it starts increasing in output. The issue is that it won’t reduce the output and stabilize at something it can manage
1lumen reviewed that model
There is a basic comparison with L7 in the comparison section.
Do you have runtime graphs that I can reference in my review? I’m basing the thermal regulation statement off of my observations at 1Lumen’s 3X21A review right now, since it has the exact same driver and the thermal characteristics of the two hosts should be virtually identical. That review does not show and increase in brightness once the light is cooled down below 60C.
I have both the 4x18 and the 3x21 and the 3x21 is better IMHO.
Why
Better ergonomics and better combination of spill and throw, they are both equally important.
What are you talking about? They’re exactly the same size & shape except for a 5mm longer tube on 3X21A.
The beams are totally identical as well, unless you’re talking about one of the triple versions of 3X21A.
Yes the triple. Completely different beam pattern.
The knurling on the light is completely different as well.
That would entirely come down to one’s own preference as to what’s better. I sell these to my customers for hunting and the last thing you want to do is throw down range a too wide beam.
Better for you, but not necessarily everyone else :slight_smile:
Griz - I’ll show you a graph a bit later, right now I’m running tests for my EC06 review. This EC06 is only handling 730 lumens with a temp limit of 50°C and room at 23°C. That’s not very impressive
Awesome! Looking forward to seeing that graph. Maybe one of these days I’ll buy some kind of logging thermometer, haha.
That sounds very similar to my results with Sofirn Q8 Pro. I need to update my graphs because I’ve gotten a lumen tube since, but I’m seeing almost exactly the same sustained output with a 45C thermal limit and 21C ambient temperature.
Appreciate you taking the time and pointing that out.
Sarcastic? lol
What is this “triple version” of which you speak?? 3 LEDs??
precisely
I think the Convoy L7 is a winner. I’d prefer a side-switch-only configuration but the beam pattern is great and the host handles heat really well. I handled my brothers and now I have one coming in the mail :stuck_out_tongue:
L7 is fantastic. I got one a couple weeks ago and I’m thoroughly enjoying it.
