Thanks, Tom E, and everyone for your valuable input.
I'll take a code, and thank you, freeme!
No prob! But I did find it has excessive parasitic drain with the switch LED on hi - 2500 uA. There's a 0.5 K ohm resistor (0402) in the path - probably should be much higher. Interesting just the other day I found the Sofirn SP31 Pro also had excessive drain on the switch LED on hi of 1300 uA with a 1K 0402 resistor. I swapped that 1K for a 6.8K and now it does 276 uA on hi - much better.
The SP31 Pro switch LED's were super bright, too bright, and so are these on the EC06.
So the stock draw is as follows:
switch LED OFF: ~120 uA
switch LED Low: ~170 uA
switch LED Hi: ~2500 uA
Even 120 uA is a little high, but not bad. Typically it should be ~30 uA w/Anduril 2 on this type of driver.
For me I can swap the 0402 0.5 K resistor with about a 6.8K.
Wondering if Sofirn makes this light? Switch PCB has label on it which think it says Q8 Pro.
Code please Thanks freeme
Order placed
Thanks freeme
This light is fantastic !!! I tested it against an Imalent MS08 and it is even brighter than this when switched on with 3 Molicel P42A, I decided to buy 4 more and combine them to make a 100,000 lumens monster. Mateminco / Astrolux you are great !!!
Code please, thank you
Sent.
Thanks, ordered.
Thank you for your continued support!
Code please
Thank you, texas shooter, for confirming that I can not miss out on this exciting light. I did not receive the code, yet, so I ordered via the "Can't wait for our reply, Buy Now" button.
By the way, here are all of the links for the five (currently) topic threads for this light, just on this forum, running contemporaneously, so all can see what's currently going on with this exciting item:
[Review] ASTROLUX EC06 Pop-can flashlight with 16,000 lumens, 566m beam distance, Type-C charging/discharging & Anduril II The_Flashaholic
Astrolux EC06 - some pics & a beamshot d_t_a
FREEME ✌ ASTROLUX® EC06 6*XHP50.2 16000lm 566m 3*21700 USB-C Flashlight Group Buy >>> $69.99 freeme
Notice/Analysis Astrolux EC06 Vodak-Yarout
EC06 Tear Down Review Tom E
https://budgetlightforum.com/t/-/68717
Code please!
code please i am Interested
Hi freeme,
Any plans for a 5700k xhp50.2 model?
I will ask them tomorrow.
Would be awesome… :+1:
Posted a tear down review of the EC06 here: https://budgetlightforum.com/t/-/68717, with some measurements.
Works with only 1 or 2 batteries too?
I was told by an owner that it does, but I don’t own the light myself.
Sure, they are in parallel, any #
