I received notice today that mine has reached the country, and in the hands of the postal service. Scheduled for Monday delivery, but maybe I’ll get lucky and have a shiny new toy for the weekend.
Big big thanks to you and all who have helped on this project. I watched all your development videos. Long time Coleman gas lanterns user and I still plan on using them as I like the heat from them while winter camping. However the LT1 have become my go to lantern. I use it all the time at work too.
Patiently waiting for the mini version. Thanks again.
Got my third one today in green this time and just love the colour.
This one has came set with the simple Ui and of course took me few minutes to remember the 10H to switch it to advanced Ui,
these days takes very little to get me confused…. yes keep laughing you`ll get there one day too hope not
I’ve bought several different USB-C OTG adapters/cables to be plugged in the BLF LT1v2.0 (or other Sofirn lights that feature powerbank function, eg. the Sofirn Q8 Pro, Wurkkos HD20, Wurkkos TS21, Astrolux EC06, and possibly more in the future) so I can use the flashlight/lantern to charge other stuff that only use a standard USB-A male plug.
I notice that some of the OTG USB-C adapters (male USB-C to female USB-A) have bigger molds that barely fit the USB-C port on the lantern/flashlights.
Side question:
Is it safe to use USB-C OTG adapter/cable (USB-C male to USB-A female) on these flashlight/lantern to serve as a more general-purpose powerbank? Or would there be some concerns to note about?
(I understand some of the cheaper/lower quality adapter/cable will pass a lower current, maybe just 5v/1A; but the more expensive/higher quality OTG adapter can allow 5v/2A or maybe 5v/3A)
I have noticed a variance in the molded plug end between cords and run into a variety of devices that have problems with inserting the larger molded plug ends.
I think using an adapter is even better than safe (when using high-quality ones) because you can force the LT1 to act as a powerbank and the other device to charge itself. When I plug my smartphone in my Q8 Pro the phone tries to charge the light for some reason, so I need to plug in an adapter to the Q8 Pro which has 5.1k pulldown resistors on the USB-C CC1 and 2 pins to activate 5V.
Yes, this is a ‘universal’ problem with plug ends & sockets on various devices.
I have reverted to shaving a little off the moulded plug to get it to fit a socket. Otherwise I use a different cable.
thank you for your help;
I tried this already, but 3 clicks does nothing : after the 3 clicks, whether I wait and then hold or turn off, it stays in stepped mode. I must be missing something there
If you got your lantern recently than just like @Rayoui mentioned first you have to switch to advanced mode to be able to use this future.
To switch to the advanced mode: from off 10 clicks and hold
so here is what I did :
from Off, 10clicks+hold > advanced mode
switch On, 3 clicks to switch to ramped (and it works this time)
switch Off, then 10 clicks > back to simple mode
Thanks guys. I couldn’t change the LED switch light by pressing 7 clicks from off. Was a little annoyed but was putting this down to a software quirk.
Followed the instructions to get into advance mode. I can change the LED switch light now. Bought 2 LT1 over a 2 week span. One was already in advance mode while the other was not.
Patiently waiting for the green and orange one to be available on the Sofirn Cdn webstore.
@Cigarguy
You can get one in Sofirn store on AliExpress
Mine came within 12 days from ordering to GTA, perhaps quicker to Calgary since you`re so close to Vancouver where usually the cargo plane lands, according to shipment tracking.
Without batteries came to a grand total of C$ 64.25 .
I generally order mine off their Chinese website and get them in under two weeks. I get charged sales tax (marked as VAT) but, shipping is free and delivery is fast so I keep going back to their store.
My recently delivered LT1-A2 was received in Advanced UI mode, and set to stepped ramping.
There obviously seems to be some inconsistency in how the units are actually prepared, and shipped, making any assumptions tenuous. Perhaps the same folks who (inconsistently) run Jinba’s labeling machines also prepare and flash the drivers. Any bets on how many “Sofrin” lights have made it into the wild? There must be at least some.
My unit also left the factory with the switch and its lights clocked at 10 degrees off vertical (not unlike thisreview sample), which my OCD would not allow to go uncorrected.
I was not aware of how the switch PCB and well it rests in are designed, but discovered that they are indeed shaped/indexed to prevent this, and it was a result of sloppy assembly practice that resulted in it being misaligned.
That said, those were the only lapses I found with mine, and overall, the LT1 is quite pleasing and deserved of its reputation.
I don’t mind the much-lamented green switch illumination of the newest revision, but the blue is kind of odd, and I wish the blinking mode was more like the breathing/pulsing mode like the SC31B had. Not sure if that is the result of intention, or a limitation of some sort, but a more refined implementation would actually make it usable in my book.
Last thing I might wish for is some Anduril documentation that is a cleaner, happy medium between a spaghetti-like chart and a wall of text.
