I was told by an owner that it does, but I don’t own the light myself.
Sure, they are in parallel, any #
Bugger, waited too long.
Hi FreeMe. Still have some coupon codes?
I would wait for a 5000 to 5700ºK be it even at a bit higher price, but just in case BG doesn’t follow up, I’ll take this offering.
Thanks.
Sure.
Thank you freeme for code I complete check out
I will wait
Hi FreeMe. Still have some coupon codes please?
Coupon code for me too thanks for your work Freeme
Its Sofirn made. It is like Q8 21700 Pro version with 6 leds :money_mouth_face:
Do you have a code for me freeme? Thanks
Interested,can i have the code pls?
Interested
Hi. Code please. Thanks.
A BIG thank you freeme!!! Just placed my order and can’t wait for the very under rated EC06 to get here Now to order a couple sets of P42A cells!
Thank you for your continued support!
Order placed
Thank You Freeme
I stated earlier that this light was grossly over driven on turbo. It’s also one of the lowest setting lights I have. I’ve got three dogs that sleep in different spots on the bedroom floor. This light ceiling bouncing on it’s lowest setting gives just enough light to tell where they are. It’s low is so low that I can directly look at the 6 LED’s at night. I can see each of the 4 sub LED’s in each LED.
What lumen output will my Samsung 40ts give?
What are the best batteries to get for maximum output?
Thanks
28K or so at start, 22-23K after 30 secs - about right. Tested T42's, P42A's, 30T's. 40T's and T42's should be about the same.
I'd stay with 40T's or T42's. Not much gain at all from 30T's. 30T though is still considered the best battery on the market for sheer output, though shorter runs.
Again, very short term high output - gets smokin hot.
I have read at startup 28k Vapcell T42, 27k Samsung 40T, 26k Molicel P42A.
