FastTech New Arrivals & Promotion
1273 posts / 0 new
fasttech
fasttech's picture
Last seen: 1 day 3 hours ago
Convoy 4×18A 5400LM 5700K LED Flashlight
Luminus SBT90.2 LED / 9-mode / 4*18650 / USB-C charging / 1122m beam range / temperature control
Head diameter: 69mm Tube diameter: 50mm Waterproof level: Life waterproof Low voltage warning: automatic power off Illumination: Maximum 314.7KCD Reverse polarity protection: None, the positive side of the battery should be facing the head
Mode operation instructions:
Click the button -> flashlight is turned on with last brightness -> press the button,brightness ramping up -> release and press the button again,brightness ramping down
Flashlight off, press the button -> moonlight mode 0.01A (0.2%) (This brightness will not be remembered)
Flashlight on or off, 2-click the button -> turbo 100%
Flashlight off, 3-click the button -> strobe
Flashlight off, 4-click the button -> tactical mode, only 100%, 4-click the button again to quit tactical mode.
Flashlight off, 5-click the button -> voltage detection (* means “flash”, *** suspend ******* means 3.7V )
Flashlight off, 6-click the button -> ramping mode switch to 4modes 1%-10%-40%-100%
Flashlight off, 10-click the button -> Lock mode, The flashlight will flash once under any operation, which means the flashlight is locked. 10-click the button again to quit lock mode, please note that this is the only way to unlock.
Please note:
If you put the flashlight in a bag, be sure to loosen the connection between the battery tube and the head. Otherwise, the flashlight may be turned on by mistake, which has a risk of burning the contents in the bag.
Please use a USB Type-A to USB Type C cable and 5V adapter to charge the battery.battery should be facing the head
FASTTECH - LED Flashlights, Lasers and Electronics
fasttech
fasttech's picture
NEXTORCH TA30 MAX 2100LM 6500K Tactical LED Flashlight w/21700 Battery
Cree XHP50.2 LED / 6-mode / USB-C charging / IPX8 / 250m throw
Max 2100 lumen blinding high light and 250m flood-light long shot; the patented dual-function tactical switch can access to momentary on or one-step strobe under any working conditions by halfway or fully pressing the switch; rotational magnetic switch around the tail cap for easy one-handed mode switch; strike bezel embedded with super-hard nano-ceramic beads to efficiently break car windows.
TA30 MAX comes with a USB Type C direct-charge 21700 battery, to reduce the frequency of changing batteries, more environmentally-friendly; 5000mAh large capacity, to ensure the long endurance and lower battery anxiety
Waterproof: IPX8 (Submersible to 2m)
Head diameter: 38mm
Tube diameter: 28mm
Impact resistance: 2m
fasttech
fasttech's picture
NEXTORCH TA41 2600LM 6500K Tactical LED Flashlight w/21700 Battery
Cree XHP50.2 LED / 7-mode / USB charging / IPX8 / 272m throw / nano-ceramic strike tip
USB direct charge design Super hard ceramic strike tips: Escaping from car windows & close quarter defense Waterproof: IPX8 (Submersible to 2m) Impact resistance: 2m Head diameter: 38mm Tube diameter: 27mm
fasttech
fasttech's picture
ARCHON J2 2-in-1 1000LM 6500K 100-Meter Diving LED Flashlight w/21700 Battery
Luminus SST20 LED / green laser / 7-mode / 100-200m throw
Head diameter: 46mm Tube diameter: 28mm Angle of light beam for White light: 10’ With battery over-discharging protection Operation voltage: 4.2V to 3V
fasttech
fasttech's picture
TANK007 TC01 800LM 6500K LED Flashlight w/18650 Battery
Cree XM-L2 LED / 5-mode / IPX8 / 200m throw / glass breaker function
Head diameter: 34mm
Tail diameter: 29mm
Voltage: 3.7-4.2V
Impact resistance: 1.5m
fasttech
fasttech's picture
Nitecore HC65 V2 1750LM Triple Output LED Headlamp w/18650 Battery
Luminus SST-40-W 6500K LED / 4500K & red LED / CRI ≥90 / 11-mode / 1*18650/2*CR123/2*RCR123 / USB-C charging / IP68 / 165m throw
Enter coupon code MAP on the shopping cart page to see our unbeatable price.
Flashlight modes: Primary White Light Turbo > Primary White Light Hi > Primary White Light Mid > Primary White Light Lo > Primary White Light Ultra Lo > Auxiliary Red Light Hi > Auxiliary Red Light Lo > Auxiliary Red Light Flashing > Auxiliary White Light > Beacon > SOS
Waterproof: IP68 (Submersible to 2m)
Max beam intensity: 7000cd
100’ wide range flood beam
180’ all-round adjustable
Elastic and breathable headband with silicone sweat diverting strip
Highly efficient constant current circuit (non-PWM)
ATR (Advanced Temperature Regulation)
The power indicator can display the battery voltage (+/-0.1V)
fasttech
fasttech's picture
WUBEN E12R 1200LM 6500K Camping Light LED Flashlight
OSRAM P9 LED / 6-mode / 1*18650 / USB-C charging / IP68 / 179m throw / power bank function
E12R delivers up to 1200 lumens with a beam throw of up to 179 meters, it can be used as a camping light or floodlight.
It utilizes 18650 Li-ion battery with circuit protection board, which has a run time up to 173 hours.
Premium temperature control design
Impact resistance: 1m
fasttech
fasttech's picture
Black Friday & Cyber Monday Sale 2021 – Sitewide 12% Off! Code: BFCM2021
Hey, guys!
Here comes the 2021 FastTech Black Friday & Cyber Monday Big Sale! FastTech offers a 5-days promotion that saves up to 15% on your order!
Blowout 1:
Black Friday & Cyber Monday Sitewide Coupon
Offer: Sitewide 12% off
Valid Date: Nov 25, 2021 – Nov 29, 2021 (UTC-6)
Coupon Code: BFCM2021
Blowout 2:
FastTech gift card limited offer: Get gift card 3% Free
Buy FastTech Gift Card Now →
Agro
Agro's picture
Last seen: 3 min 8 sec ago
Fasttech, any news about shipping knives to EU?
fasttech
fasttech's picture
TANK007 UV-AA02 3W 365nm UV LED Flashlight
1-mode / 2*AA / IPX8 / 50m throw
  • UV-AA02 has multiple uses as below:
    Check the leaks in an air conditioner or automobile circulatory system
    Crime scene inspection of marks or blood
    Treasure and minerals search; antique appraisal
    Ink curing and glue curing
    Identify counterfeit bills
    Gas leaks inspection
    Spot the fluorescence of special substances
  • LED Lifespan: above 20,000 hours
  • UV Intensity: 9000μW/cm2 (38cm), 56500μW/cm2 (15cm)
  • Voltage: 1-3.6V
  • Chip characteristics: Constant current circuit chip which maintains constant brightness
  • Anti-dropping height: 1.5m
  • Tail diameter: 21.2mm
fasttech
fasttech's picture
I am sorry to tell you that there is still no shipping method that can ship knives to the EU.
fasttech
fasttech's picture
TANK007 UV-L03C 365nm UV LED Flashlight
1-mode / 1*18650 / USB-C charging / IPX8 / 50m throw
Head diameter: 26.7mm
Tail diameter: 24.6mm
UV intensity: 52000uW/cm2 (15cm), 11000uW/cm2 (38cm)
Voltage: 2.8-4.2V
Waterproof: IPX8 (Submersible to 1.5m for 30 minutes)
UV anti-counterfeit lamp
*Low carbon and eco-friendly;
*High power equals to output supplied from 150W high voltage
*The polymerization isn’t affected by high temperature
*High thermal conductivity copper substrate – heat dissipation performance
Constant-current: Keep the stable output within 1A for protecting the LED lifespan.
Specialized black filter lens: 99% stray light filtered by specialized UV filter black lens, which makes fluorescent inspection easier, faster, and more reliable. Since tail emission is visible as deep violet light, adding the UV-A pass filter eliminates the glare and makes the background of the part surface darker. This increases the contrast between fluorescent indications and the darkened part surface when using fluorescent magnetic particle or penetrant techniques.
fasttech
fasttech's picture
TANK007 UVC31 365nm UV LED Flashlight w/US Charger
Nichia LED / 1-mode / 1*18650 / USB-C charging / IPX7 / 50m throw
Head diameter: 40mm Tail diameter: 26mm Voltage: 3V-4.5V Anti dropping height: 1.5m LED Lifespan: Above 20,000 hours UV intensity: > 72000uW/cm2 (15cm), > 30000uW/cm2 (38cm)
fasttech
fasttech's picture
fasttech
fasttech's picture
TANK007 UV122 400LM 6500K 365nm UV LED Flashlight
Cree XP-G2 & UV LED / 3-mode / 1*18650 / USB-C charging / IPX7 / 200m throw
Dual LEDs (Lighting +UV Detection)
UV light mode:
  • Non-destructive testing of special gas, oil tubes, machines, etc.
  • Crime Scene Investigation of fingerprint, blood, sperm, flammable chemicals, etc
  • Conservation and restoration of artworks, antiques, etc.
  • Anti-counterfeit detection of document, passport, ID card, etc.
  • Biological research, treasures and minerals hunting
    White light mode:
  • Outdoor lighting, hiking, exploration, camping, etc.
UV intensity: 52000uW/cm2 (15cm), 9100uW/cm2 (38cm)
Waterproof: IPX7 (Submersible to 6.5 feet or 2 meters for 30 minutes.)
Anti-drop height: 1.5m
Head diameter: 35mm
Tail diameter: 26mm
fasttech
fasttech's picture
Nitecore UT27 520LM 5700K & 3000K Dual Output LED Headlamp w/2*Battery Packs
authentic / 2*Cree XP-G3 S3 white & 2*red LEDs / 7-mode / 2*battery packs/3*AAA / IP66 / 128m throw / 90’ adjustable / APC technology
  • Equipped with spotlight, floodlight and auxiliary red light with a max output of 520 lumens
  • Spotlight uses a Cree XP-G3 S3 LED (3000K) and a TIR optic lens with a max throw of 128m and a max peak beam intensity of 4,120cd
  • Floodlight uses a Cree XP-G3 S3 LED (5700K) and a TIR optic lens with TrueVision Technology for an ultra smooth flood beam
  • Powered by a proprietary Li-ion battery pack and compatible with 3*AAA batteries
  • HLB1300 rechargeable Li-ion battery pack (1,300mAh) included with a built-in USB Type C charging port
  • Glow-in-the-dark battery compartment for easy battery replacement and location
  • Highly efficient constant current circuit provides a stable output of up to 13 hours
  • Dual switch design for easy access to various light sources, brightness levels and modes
  • Power indicators can indicate the remaining battery power
  • Advanced Power Cut-Off (APC) technology for an ultra-low standby power consumption
  • 90’ adjustable tilt angle for various lighting needs
  • Specially designed lightweight and breathable headband and diffusing stuff sack included
  • Waterproof and dustproof rating in accordance with IP66
  • Impact resistant to 1 meter
  • Lockout Mode: Both buttons will be locked in lockout mode to prevent accidental activation so that the UT27 can be stored or transported in the pocket or the backpack.
fasttech
fasttech's picture
TANK007 CI05 395nm UV LED Flashlight w/18650 Battery
authentic / 1-mode / USB-C charging / IPX7 / < 50m throw
Professional applications:
Crime scene investigation, forensics, inspection, searching, laboratory research, etc. Preservation, conservation, and inspection of artworks, antiques, paintings in the workroom, on-site visits, artworks center, museums, galleries and auctions, archives, private conservation studio, etc. Anti-counterfeit detection of banknotes/passport/ID cards/documents, etc.
LED Specifications:
UV intensity: 6200μW/cm2 (15cm); 950μW/cm2 (38cm)
Spot Diameter:
Diameter 150mm (at distance of 300mm)Diameter 250mm (at distance of 500mm) Diameter 500mm (at distance of 1000mm) Uniform light spot without dazzling or stray light, uniformity >= 93%
Circuit Specifications
Voltage: 3.0-4.2V Circuit characteristics: Constant current chip/constant brightness. Charging indicator: Solid red when charging, solid green when fully charged; power less than 20%, the indicator flashes one time per second.
Physical Specifications:
Head diameter: 33mm IPX7 waterproof, work normally for 30 minutes when immersed in 1m water. Anti dropping height: 1.5m Please note: Avoid direct exposure to the eyes or skin, UV light may harm your eyes or skin. Children should use it under the supervision of adults.
fasttech
fasttech's picture
New Arrival! NEXTORCH T20L 2000m Long Shot 900LM White Laser Tactical LEP Flashlight
authentic / 1000000cd / 6-mode / 1*21700 / USB charging / IPX7
With a 20W white laser light source, L20L can interfere with or even damage the camera’s CMOS image sensor to protect privacy and security. The max output of light is up to 900lm, a 2000m focused long shot, that supplies great help in tactical, search, patrol, and hunting at night. 6 modes switch easily to meet different lighting needs. 1PX7 waterproof and 1-meter impact resistant, it is a reliable and durable torch.
Tube diameter: 58mm Tube diameter: 27.5mm Waterproof: IPX7 (Submersible to 1m)
fasttech
fasttech's picture
Weltool W4 “Dragon In Cloud” 2.6km Long Distance Throwing LEP Spotlight Search Flashlight authentic / laser excited phosphor / 560LM / 2-mode / 400-700nm / w/ 1*21700 / USB-C / IP67
W4 LEP searchlight throwing distance up to 2.6 kilometers! , Luminous flux 560 lumens, light intensity reaches 1782000 candelas, use one 21700 rechargeable lithium-ion battery, high-quality drive circuit with temperature control, constant current drive, and ensure that the flashlight will not overheat. W4’s LEP light source has high energy density, and then passes through a special lens reflection system to form a dazzling light column. High and low brightness modes are adjustable, simple, and practical. In the off state, only half-press the switch to turn on the highlight, and it is equipped with a stainless steel bezel for tactical use. The W4 spotlight has almost no floodlight, concentrated light, and significant spotlight effect. It is suitable for field search, sea rescue, long-distance indication, etc.
Head diameter: 60.5mm
Tube diameter: 27mm
Divergence angle: 1.8’
Light intensity: 1782000cd
Reflective system: Biconvex acrylic lens
Instructions:
First, unscrew the flashlight tail cap counterclockwise, the battery positive electrode is inserted toward the head, and tighten the tail cap clockwise.
The flashlight has the positive and negative pole reverse connection protection function, even if you install the battery in the wrong direction, the flashlight will not be damaged, but it will not work, please check the battery at this time
Half-press the tail switch button once, the flashlight starts working (high mode), and the flashlight stops working when the switch is released
After half-pressing the flashlight to start working, immediately release it and then half-press the tail switch again, the brightness mode is switched to low brightness, and the operation is repeated in this way, and the mode cycles. Press the switch hard in any mode, there will be a “click” sound, lock the current brightness is always bright; press again, the switch will have a “click” sound, the flashlight is turned off.
When the battery power is low, the flashlight light flashes, even if you focus on your work, you will also see the light prompt. Please replace the battery in time.
Notes:
Unauthorized disassembly may damage the light and void the warranty
The light will increase in surface heat during use, recommended use is outdoors in a well-ventilated area with ambient temperature under 25 degrees Celsius and the wind speed exceeds 5m/s. When the light is uncomfortable to hold due to increased heat, please turn the light off until it cools down. If used indoors, it is recommended to be used for no more than 10 minutes each time and allow the light to cool down between uses.
Please swap out the O-rings regularly to maintain the water-resistance level
Lubricate the threads with professional-grade lubricant regularly
Maintain and keep clean any contact surfaces of the flashlight with an alcohol swab. This may prevent irregular flashes during use.
Remove batteries during storage. Keep lithium-ion batteries charged approximately every 4 months
This flashlight may not be used as a diving light
Do not aim this light directly at eyes or exposed skin to prevent injuries
Keep this flashlight out of the reach of children.
WARNING:
This light uses a high-efficiency LEP emitter, with a power output between 0.22 – 0.25W, classified as a Type IIIb laser device. Please use in accordance with applicable laws and regulations. By using this device, you certify you have read the included “Laser Safety” warnings and release the manufacturer and retailers from all liabilities.
The tail cap acts as a “safety key” and must be kept safe. The tail cap switch can shut off the light immediately or by twisting off the tail cap as a safety backup. An opaque protective cover can be purchased additionally. Equipped properly, this protector will prevent any light from escaping the front of the flashlight as a safety device.
DO NOT aim at another person. DO NOT aim at mirrors, glasses, or other reflective surfaces. DO NOT aim at aircraft or vehicles in operation.
fasttech
fasttech's picture
NEXTORCH T10L 500LM White Laser LEP Flashlight
authentic / 6-mode / 1*21700 / USB-C charging / IPX7 / 1100m throw / glass breaker
T10L applies the highly-collimated white laser source of strong directivity for more effective locating in the distance, searching, and aiming. Max 1100-meter focused long shot is far enough to target the goal rapidly and accurately. One-step strobe independent tail switch ensures easy operation and quick response. With a strike bezel embedded with three super-hardness nano-ceramic beads, it is efficient for breaking windows in an emergency.
White laser technology: A blue laser motivates the fluorescent material on the fluorescent crystal coating to release a wide-spectrum white light, and then White Laser intensively emitted by central emitter later, with high-density energy. The reflection of the white light through a special lens becomes intensively well-dazzling white light Rotate anticlockwise to switch modes among OFF-Low-Medium-High-Strobe, clear and easy to operate. Strike bezel with nano-ceramic beads Waterproof: IPX7 (Submersible to 1m) Impact resistance: 1m
fasttech
fasttech's picture
Lumintop THOR I 400LM White Laser EDC LEP Flashlight
authentic / 3-mode / 34200cd / 1*18350 / IPX8 / 1200m throw / rear E-switch w/RGB light
Intensity: 34200cd (max.) Waterproof: IPX8, underwater 2m Impact resistance: 1m Head diameter: 32mm
fasttech
fasttech's picture
Weltool W3Pro 505LM Tactical LEP Flashlight
authentic / 2-mode / 363375cd / 1205m throw / 400-700nm / 1*21700 / USB-C charging / IP67
Weltool W3Pro "Featherless Arrow" is an upgraded version of W3 with a luminous flux of up to 505 lumens! The light intensity reaches 363375 Candela, the throwing distance is about 1205 meters! You can use one 21700 rechargeable lithium-ion battery, using high-quality constant current IC, and temperature control to ensure that the flashlight will not be too hot.W3Pro's LEP light source has high energy density, and then passes through a special lens reflection system to form a dazzling light column! High and low modes are simple and practical.
The Weltool W3Pro tactical flashlight has almost no flooding and concentrated light. It is a spotlight, suitable for long-distance throwing, designed for special purposes.
Specifications:
Intensity: 363375cd (Hi) / 72000cd (Lo)
Head diameter: 33mm
Tube diameter: 26.5mm
Reflective system: Acrylic lens
Switch: Tail tactical switch, 50,000 press life
High efficiency constant current drive circuit, no noise, and no PWM
Temperature control protection: when the flashlight temperature is too high, the flashlight will automatically reduce
Battery over-discharge protection
Passed 1-meter drop test
fasttech
fasttech's picture
New Arrival! Nitecore MH25 V2 1300LM 6500K LED Flashlight
authentic / 7-mode / 1*21700/1*18650/2*CR123 / USB-C charging / IP68 / 475m throw
  • Head diameter: 40mm
  • Utilizes a high performance LED with a max output of 1.300 lumens max peak beam intensity of 57.000cd and max throw of 475 meters
  • An optical system combined with crystal coating and "Precision Digital Optics Technology"(PDOT)
  • Powered by a 21700 high capacity Li-ion battery while compatible with 18650 and CR123 batteries, it provide a runtime of up to 1.500 hours
  • Tactical mode and daily mode are available
  • The tactical tail switch and the metal side switch control 4 brightness levels and 3 special modes
  • Strobe mode uses randomly changing frequencies for stronger dizzying effects
  • A power indicator beneath the side switch indicates the remaining battery power
  • The power indicator can display the battery voltage (±O.IV)
  • Intelligent Li-ion battery charging circuit with a USB-C charging port
  • USB-C charging (Do not attempt to use the MH25 V2 to charge CR123 batteries)
  • A highly efficient constant current circuit provides a stable output
  • Incorporated Advanced Temperature Regulation (ATR) module
  • Electronic reverse polarity protection
  • Waterproof and dustproof rating in accordance with IP68 (2 meters submersible)
  • Impact-resistant to 2 meters
fasttech
fasttech's picture
FastTech Upcoming 2021 Christmas 8% off Site-wide Sale – Coupon Code: XMAS2021
We Wish You A Merry Christmas. It’s time to start holiday shopping, get an 8% off site-wide discount for your orders. It is a 3-day sale only.
1. Christmas Site-Wide Coupon
Offer: Site-wide 8% off
Valid Date: December 24,2021 – December 26,2021 (UTC-6)
2. FastTech gift card limited offer
Pay via Paypal/credit card to get an extra 3% free value instantly in the total amount. Get gift card 3% Free
fasttech
fasttech's picture
New Arrival! Convoy L21A 2300LM 6500K LED Flashlight
Luminus SFT40 LED / 12-group / 1*21700 / IPX8 / 800-1000m throw
  • Head diameter: 64.5mm
  • Driver: 12 group mode, maximum current output 8000mA, internal temperature protection management
  • No strobe can be seen in any mode, and there is temperature management.
  • It can control the temperature of the flashlight not to exceed 55 degrees Celsius. If the temperature of the flashlight is lower than 55 degrees Celsius, it will output full current. If the temperature is higher than 55 degrees Celsius, it will continuously adjust the current so that the flashlight will not overheat
  • 12 groups: Click the button to turn the flashlight on / off, touch the button to select the mode. If the flashlight is turned on, tap the switch 20 times quickly to enter the configuration mode. (In a visual interface, as long as you click on an option, it means that the option is selected. The flashlight has no visual interface. It flashes to represent an option and "touch the button in the flashing process" means to select the option.)
  • Option 1 (normal flash 1 time + buzz flash): touch the switch to enter the sub-option to select the mode group. If the user has no operation, the configuration mode will enter option 2.
    Suboption 1.1 (normal flash 1 time): touch the switch to select mode group 1 (0.1%, 1%, 10%, 35%, 100%, strobe, bicycle, battery check)
    Suboption 1.2 (normal flash 2 times): tap the button to select mode group 2 (0.1%, 1%, 10%, 35%, 100%)
    Suboption 1.3 (normal flash 3 times): tap the button to select mode group 3 (100%, 35%, 10%, 1%, 0.1%)
    Suboption 1.4 (normal flash 4 times): touch the switch to select the mode group 4 (1%, 20%, 100%, strobe, bicycle, battery check, SOS)
    Suboption 1.5 (normal flash 5 times): tap the button to select the mode group 5 (1%, 20%, 100%)
    Suboption 1.6 (normal flash 6 times): tap the button to select the mode group 6 (100%, 20%, 1%)
    Suboption 1.7 (normal flash 7 times): tap the button to select the mode group 7 (0.1%, 1%, 10%, 50%, strobe, cycling , battery check, SOS)
    Suboption 1.8 (normal flash 8 times): tap the button to select the mode group 8 (0.1%, 1%, 10%, 50%)
    Suboption 1.9 (normal flash 9 times): tap the button to select the mode group 9 (50%, 10%, 1%, 0.1%)
    Suboption 1.10 (normal flash 10 times): tap the button to select the mode group 10 (1%, 10%, 35%, 100%)
    Suboption 1.11 (normal flash 11 times): tap the button to select the mode group 11 (100%, 20%, strobe)
    Suboption 1.12 (normal flash 12 times): tap the button to select the mode group 12 (only 100%)
  • Option 2 (normal flash 2 times + buzz flash): touch the switch to activate or deactivate the memory mode. If the user has no operation, the flashlight will enter the last mode
fasttech
fasttech's picture
Merry Christmas! 8% off site-wide discount with coupon code: XMAS2021 is valid now. Valid Date: December 24,2021 – December 26,2021 (UTC-6) SHOP NOW!
sochi111
sochi111's picture
Last seen: 3 weeks 2 days ago
FASTTECH,
what happened to free shipping?
Now you have $20 minimum to get free shipping?
1stein
1stein's picture
Last seen: 57 min 48 sec ago
sochi111 wrote:
FASTTECH, what happened to free shipping? Now you have $20 minimum to get free shipping?
Not surprised at all. Please consider within the last year vessels availability dropped dramatically and prises has risen about 10 times.
I appreciate there is still an option for free shipping.
fasttech
fasttech's picture
Yes, only orders over $20 are free shipping now. The shipping cost increased dramatically these years, we have to set the minimum for the free shipping. Hope you can understand.
Lightbringer
Lightbringer's picture
Last seen: 5 hours 37 min ago
Who orders less’n 20bux from FT? LOL
