The one on the far right is what Iām using in my dev host. Or perhaps even more floody, not sure exactly which optic itās using. Itās a nice beam, but itās not very throwy at all. And the host is pretty scratched up and had some manual corrections to the shape. So itās great for dev purposes, since itās functionally the same as a production model but not in good enough condition to be sold to a customer or sent to a reviewer.
This looks like a nice upgrade!
It might help to check the lens, and maybe polish off the AR coating. Hank said your light is 99% the same as a production version, and the lens might be that other 1%. I noticed the coating on my dev host was different than his other lights, and gave the beam a green hue, but he said thatāll be fixed in production. If that affects yours, you should be able to fix it by scraping off the AR coating with a polishing cloth or something.
Iām leaving mine as-is because itās the only time Iāve seen this type of AR coating and its uniqueness makes it useful. The coating has sort of a rainbow hue depending on the angle. When I remove the lens, the beam looks white instead of green.
Glad you liked the video! I donāt do any commercialsā¦ maybe in the future!
Thanks for the suggestion! I gave it a try - There is not any coating that I can see on the lens of my light, and removing the lens did not change the color of the beam in any way. It appears based off this sample that Hank has listened to the feedback and changed/removed the AR coating.
Kinda disappointed to see the extreme price premium for the B35 options (and XHP35 HI to a lesser extent given the more expensive emitter). I donāt see that sort of bump in cost for switching drivers from competing brands, and unless this is a new design it doesnāt really knock it out of the park in terms of efficiency.
LuxWad - agree with everyone: your videos are fantastic and you now have a new subscriber, the informative yet relaxed (and honest) reviews are spot on
I have around 20pcs of B35AM and AR and they can sustain 1000lm without a sweat. Better find one and try so youāll see how underpowered looks this initail videoā¦
Hank's rating is 1400 lumens with the B35AM. Video shows 3.6 amps from a boost driver for a 6V LED, looks like 1650 at start, so maybe ~1500 at 30 secs. The light is 120 mm long, 40 mm head - nothing at all very big, think of it as a BLF/Eagle X6 but little shorter, or an Astrolux EC01 but slightly larger head diameter.
My immediate question is why limited to 3.6 A? Can the driver take 4 amps?
In my builds B35Am at 6V/4A turns a lot rosier than realy is so itās on a max driving limit. Sosetting it on 3.6A is very good idea. Only stepdown is a minus
