Ordered a green B35AM R9080 3500K w/amber switch back light. Could not resist after that vid.
DM11 > D1S
Glad you liked the video! I don’t do any commercials… maybe in the future!
Thanks for the suggestion! I gave it a try - There is not any coating that I can see on the lens of my light, and removing the lens did not change the color of the beam in any way. It appears based off this sample that Hank has listened to the feedback and changed/removed the AR coating.
LuxWad - That was a great video btw! Wow, love the super clarity in the macro shots, plus the smooth motion. Just amazing!!
Kinda disappointed to see the extreme price premium for the B35 options (and XHP35 HI to a lesser extent given the more expensive emitter). I don’t see that sort of bump in cost for switching drivers from competing brands, and unless this is a new design it doesn’t really knock it out of the park in terms of efficiency.
LuxWad - agree with everyone: your videos are fantastic and you now have a new subscriber, the informative yet relaxed (and honest) reviews are spot on
Thanks for the video! I was trying to hold off but you’ve forced my hand. Ordered one with B35AM 3500K
It may have something to do with the individual hand-tuning the optic requires to sit at the correct height for the B35AM.
It’s a boost driver that is more expensive.
Pray tell me which competitor is selling those cheap boost driver lights, asking for a friend
Since video shows non calibrated thermal runtime, would you mind showing properly set themp settings runtime and output?
500lm seems to me too weak for this massive heatsink of flashlight...
It’s a 98 CRI LED, it is going to get relatively hot. I guess it’s going to fare better under a cold night out than in a lumen tube.
I have around 20pcs of B35AM and AR and they can sustain 1000lm without a sweat. Better find one and try so you’ll see how underpowered looks this initail video…
Hank's rating is 1400 lumens with the B35AM. Video shows 3.6 amps from a boost driver for a 6V LED, looks like 1650 at start, so maybe ~1500 at 30 secs. The light is 120 mm long, 40 mm head - nothing at all very big, think of it as a BLF/Eagle X6 but little shorter, or an Astrolux EC01 but slightly larger head diameter.
My immediate question is why limited to 3.6 A? Can the driver take 4 amps?
Hank’s rating is 1400 lumens with the B35AM. Video shows 3.6 amps from a boost driver for a 6V LED, looks like 1650 at start, so maybe ~1500 at 30 secs. The light is 120 mm long, 40 mm head - nothing at all very big, think of it as a BLF/Eagle X6 but little shorter, or an Astrolux EC01 but slightly larger head diameter.
4A seems to be the absolute maximum on Eurekatronix’s high perf MCPCBs, 3.6A drive current sounds adequate to me.
In my builds B35Am at 6V/4A turns a lot rosier than realy is so it’s on a max driving limit. Sosetting it on 3.6A is very good idea. Only stepdown is a minus
check this Clemences reports:
[image] [image] [image] And B35AM / Optisolis also available... [image] [image] [image] [image] Nichia B35 on 16mm board [image]
Ohh - there's no neutral thermal pad, so I guess that's a limiting factor?
Ref: https://budgetlightforum.com/t/-/66345
Correct.
Cool! Sounds like the R&D has already been done on these LED's. Not clear from Hank's listing, but looks like the output binning varies based on the tint - lower tint, lower output. E700, E800, E900, E1200 shown in the store listing https://www.eurekatronix.com/product-page/nichia-b35ax?
So the 3500K is E700, 4000K is E800, 5000K is E900, etc.
Datasheet on the Nichia B35AM here: https://www.nichia.co.jp/specification/products/led_spec/NV4WB35AMT-E(5768D)R70%20R8000%20R9080.pdf
Page 4 has the lumens outputs at 1.4 amps. Hhmm, might have to re-consider 3500K. 4000K jumps up to the next output bin, roughly 200 lumens more I'm guessing for 3.6 amps.
Yeah, so choosing higher CCT should give you higher outputs at the given current. I guess…
Sounds good to me. I typically use lights like this for walking the trails at night, and I usually stick between 5-20 lumens. Just enough to see down the trail without ruining my night vision.
My current go-to is a D80v2 with 219b and a 2A max regulated driver. The B35AM 3500K will probably more than double the max output of my D80v2.
