Ordinarily I really like our rewiew but for this time the conclusion with three graph for runtime, made me scratch my head
Mixing fan and no fan, high and turbo is disturbing
Finaly if i’ve good read to this graph if you want see effect of fan is that:
Fan have no effect above 10.000 lumen
Don’t change output in first 10 minute
Gap of around 2500 lumens between 10 and 30 minute.
Mixed record.
I prefer to have gloves and 2500 lumens less with no fan (and no price and sound of fan)
For two wind turbine near the light it’s a little deception.
But manual fan is a good thing, you heat down our light between two burst and maximized the time at high between 10.000-5000 lumens.
Thanks Imalent for send you this light.
Thanks to you, it was a rewiew I was waiting for and it is very complete for me
Nice info I think the plastic shroud would trap the heat more than dissipate the heat, but if it was made of Alu it would have heat sink’ed much better. Just because you can’t feel the heat in your hand doesn’t mean it’s not getting hot - that’s $ad….
Did you not look at the graph immediately above your post? The fanned outer shell absolutely pulls heat aways from the flashlight body allowing higher sustained lumen output.
I obviously tripped over my words, I didn’t mean the fans do nothing - think I was trying to say an aluminium shroud wouldn’t trap the heat the same as plastic and would actually heat sink as well IMO.
1lumen has some good info on this light too.
I know of course 1lumen, it does some good technical reviews. Regarding the Imalent MS08, I think the protective shell with the two fans is innovative. I prefer this to a handle and in any case the cooling, even with its limits, lowers the temperature of the head, benefiting the electronics.
La tua recensione è stupenda! Non solo è completa tecnicamente ma hai anche fatto delle foto esaustive che da sole dicono già tutto.Sono assolutamente d'accordo con te che le maniglie ormai fanno parte della preistoria e che Imalent abbia avuto un'idea geniale e spero di vedere presto altre torcia con questo involucro. Volevo anche fare un passo indietro circa quello che avevo scritto riguardo alle prestazioni dell'MS08 paconfrontata con l'Astrolux EC06 qui su BLF sul topic riguardante l'EC06. Con le batterie con cui viene venduta effettivamente all'avvio MS08 è più debole di EC06 ma ho sostituito le batterie Imalent con 3 Vapcell T42 che sono le batterie che usavo con EC06 e il risultato si è ribaltato questa volta Imalent è risultata all'avvio più luminosa di EC06 quindi è tutta una questione relativa a che tipo di batterie adottiamo.
Your review is great! Not only is it technically complete but you have also taken some exhaustive photos that by themselves already say it all.I absolutely agree with you that the handles are now part of prehistory and that Imalent had a brilliant idea and I hope to see more flashlights soon with this wrapper. I also wanted to take a step back from what I had written about the performance of the MS08 compared to the Astrolux EC06 here on BLF on the EC06 topic. With the batteries it is actually sold with at startup MS08 is weaker than EC06 but I replaced the Imalent batteries with 3 Vapcell T42 which are the batteries I used with EC06 and the result flipped this time Imalent resulted on startup more luminous of EC06 so it's all a question of what type of batteries we use.
Nice review.
I have to wonder about the water rating. Will the fans really survive a complete underwater dunk?
They look an awful lot like a set of small computer cooling fans.
But still, 10K-ish Lumens for a bit then perhaps 7K-4K for an hour on high. Awfully tempting except for the price….
All the Best,
Jeff
You mention comfortable to hold though heavy - is this so with the protective shell on? 4-cell soda can lights generally “clumbersome” for smaller hands and this is 3 cell I know but with protective shell I would think it would be wider than, say, Q8.
Just got mine today and it is absolutely Incredible. Even when walking around with it on turbo it only felt slightly warm.
The only thing is that I can’t figure out how to lock the fan from turning on, which it does quite frequently. In fact, i could hear the fan running before I even opened the box when it came today
edit I don’t have a meter but it is far, dar brighter than my ~10,000 to 13,000 lumen Nightwatch NSX3 and 4’s. I haven’t seen anything like it except the MS18
It seems that the supply chains are badly hurt.I have ordered from Banggood one MS08 and one portable radio,and while I had not read in their site that the items are not in stock,they are indeed.
Now I wait,without knowing if and when they ship those.
Edit:
I took a notice from BG today,that the radio has shippd.Now,I wait the light, to be shipped as well.
That sucks Theo… Mine came like 5 days after i ordered it.
Can’t wait to fire this thing up tonight. I’ve been trying to find a good way of blocking the fan button from getting activated. I have a lens cap from my binoculars that fits on there perfectly but i’d have to use a rubber band to hold it on. I even though that perhaps I could use a small metal disc since there’s a magnet in the tailcap for the fan charger but it’s not strong enough to hold anything.
I add to the review a test, on the temperature, made using a thermal camera. The test was done with and without fans of the protective shell after 10 minutes with the MS08 in Turbo.
The Imalent MS08 can always be held in the hand thanks to the ventilated shell.
Sweet pictures! My light is still perfect but one of the magnetic charging wires stopped working. Need to reach out to Imalent to see if they sell them separately. Wish they just used dual usb-c
