What did you mod today?
Does the body tube clamp down on the perimeter of the driver directly? If so, using a low strength silicone potting compound/epoxy/adhesive could work. I wonder what product the chinese manufacturers use, itā€™s a light grey/ white and peels off with your fingernail, but is enough to hold the driver in place during a battery swap
Yeah, thereā€™s a ring around the outside of the shelf that the driver sits on, with a small space underneath for wires. Then the body tube holds that in, along with the battery and spring.
Keeping the driver from twisting is enough for me, itā€™s held in well enough once assembled. I wonder what they useā€¦
Today I ā€œmoddedā€ an old bunkerlamp to use on the balcony of our appartment. Not really modding, I cleaned it, polished the aluminium refector, adjusted the rubber glass seal, added new wiring plus a rubber ring to seal the wire entrance hole, drilled a hole in the window frame for the neoprene wire to go into the house (the window is under a broad overhang so the hole will not rot, still I sealed the inside with outdoor paint), and screwed the lamp to the wooden frame that covers one side of the balcony.
The lamp is branded ā€œIndustria Rotterdamā€ which is pretty cool because here in the Netherlands there has never been very much ā€œmake-industryā€, a lamp like this would typically have been made in France or Germany.
For fun I fitted an old russian E27 neon glow bulb, bought a few years ago on ebay from I think it was an Ukrainian seller, cool stuff and very cosy but not really enough light to illuminate even a small balcony. When spring comes and the balcony gets used again I will use a Philips Warm Glow >90 CRI lamp that dims from 2700K down to 2200K.
It is nice to re-use something that might be tossed out by some folks, especially when it has a local or at least national connection that may not be commonly found.
I have refurbished and re-used things that were tossed by someone else.
Not sure if I should admit to taking someone elseā€™s trash.
When I was a kid many of my toys were hand-me-downs from cousins.
35 years, or so, ago I found a steel American Flyer wagon that was discarded. I rescued it, repainted as it was rusty as could be, installed new wheels, and made a gift of it to our son. That wagon is still in service at another home with another youngster. Toe wagons are still sold today but are no longer made in Chicago.
I love to restore stuff, especially old furniture, it is usually built better and with more detail and attention than modern things. While doing that I am not afraid to insult history a bit by altering a few things here and there to suit my modern taste and needs.
I was tempted to paint the aluminium frame of this bunkerlamp a different colour, it is light grey and the paint is a bit damaged here and there, but decided to keep it original this time.
Super cool djozz. Appreciation for the details and care put into that piece of history! :beer:
[quote=djozz]
Cool! Almost excactly like the cover of the first book in Finnish translation of Hugh Howeys Silo-series. Silo Book 1.
The SST20 in my sofirn C01s died and I replaced it with a Samsung LH351D 3500K. Have no experience with reflow soldering so I bought the version with a 10mm MCPCB. The PCB is thicker than the original though, so I canā€™t screw the top on fully. Any ideas on how to shorten the reflector so it all fits? Also lost the pocket clip, wondering if thereā€™s a way to make a new one without power tools
You can literally reflow with a tealight candle :slight_smile: (thatā€™s what I do, success rate is quite good : I failed one by overheating in about 10 reflows using that technique)
Were you able to test the emitter with a multimeter or cell or something to be sure it was the problem? Kind of rare for emitters to die in normal use (usually they only die from physical damage or when really pushing the amps up high for testing or in a hotrod light). I wouldnā€™t try to shorten the reflector, personally, but with some care you could do that by hand with a finer double-cut file, or sandpaper on a flat surface and time. If you have access to some sort of belt or disc sander that would be easiest. The reflective coatings on reflectors are extremely delicate, though, so you want to avoid all grit and dust getting on there if possible. It would be slightly more work but probably better to sand the bottom of the mcpcb instead, or buy one that is the same thickness as the stock one. If you do a search here or look at the stickied threads, thereā€™s some great info on reflowing your own emitters - thereā€™s a learning curve but itā€™s pretty simple really and can be done for very low or no cost depending on what you might already have at hand.
Also, donā€™t forget that Sofirn is pretty great about warranty. Theyā€™ll send out drivers or whole new lights (usually) if you contact them. Easier to deal with than many other manufacturers. They sell clips, too, and many other sellers do as well. If you had a clip that was the same/close to the same diameter but the ears were too wide, those can be filed down to suit, just want to smooth it all up nicely when the dimensions are where you want them to be so as not to gouge the anodizing on the body.
Thanks for the detailed response! My flashlight wouldnā€™t light up but it would get hot so I assumed the emitter was the problem. I did initially test the sst20 while it was still soldered on but it wouldnā€™t light. Weirdly enough after I desoldered it, it lit up on testing with the multimeter. Regardless, itā€™s working now with the lh351d.
Ah, I didnā€™t know sofirn would replace a faulty light, will definitely check that out. The original sofirn pocket clip is a little too malleable and not springy enough for my liking so Iā€™ll see if there are any for other AAA lights i can use
Good deal, glad youā€™re back in action, and youā€™re welcome! Normal for emitters not to light up with a multimeter while still wired to the driver/host circuitā€¦just not enough juice from most multimeter diode test functions (some can do a good 3v or a little more, but if the circuit is actually complete it will lose enough voltage not to workā€¦but with a bare disconnected emitter all is well even if the meter can only put out 2v for the test). With warranty for Sofirn, they kind of expect you to go through the retailer first (as is the Chinese business custom, opposite of what most of us are used to), and if that canā€™t be done then Sofirn will usually take care of you. They have different reps for different outlets but messaging them on Aliexpress has worked for meā€¦can also ask to purchase various parts that way and they are super accommodating. Many other companies are not nearly so agreeable or reachable.
Not sure about a good clip for that size. The only small one I have is on an Ultratac K18 AAA and itā€™s mediocreā€¦plus I think Ultratac may have gone under. If you post a separate thread about that Iā€™ll bet someone here has some good solutions or ideas. If you havenā€™t already, have a browse on the Kaidomain site to see if they might have anythingā€¦or possibly Fasttech.
Nicely done. What voltage is the driver running at? 6V or 12V?
I did some sharpening and color inversion of the image and it kinda looks like itā€™s a 12V. The traces from the solder pads go to opposing corners of the emitters split pads.
Deep carry clip for my variable tint Emisar D4V2:
This clip started as a 2-way clip for an FW3A.
  • I sawed off the backbend portion, then used pliers to add the 2 bends at the tip.
  • Iā€™m quite please with how it turned out. The modding process only added minor scratches to the chrome plating on the clip. The lip is now big enough to slip onto a pants pocket one-handed, and itā€™s deep carry. Much better than the stock clip.
  • The clip is currently installed on an 18500 battery tube, but it also fits on the stock 18650 tube.
That is awesome work. Looks like the light came stock with that clipā€¦.never know the difference.
After looking at my previous post #10701, I noticed that 1 of the 219Bs was not flat against the MCPCB. Thatā€™s the downfall of taking pics while modding - you can notice issues afterwards.
I took the head apart and saw 2 others were similar. Solder was between the LEDs and the board so no gaps. I think everything wouldā€™ve been fine, but not up to my standards. So I put the MCPCB on my electric skillet, tapped down on the LEDs again, and was surprised as to how much extra solder came out. Seems just as much as when I did it the first time.
I put everything back together and now Iā€™m pleased with how the pics look.
Not modded today, but during the last days.
I modified a Eagtac D25C, which I bought in purpose for this mod.
Modifications performed:
  • forward clicky switch, using the original PCB and copper contact ring): it doesnā€™t stay completely flat / aligned with the tail, but doesnā€™t protrude much.
- new rubber button, slightly taller than the original
- H17F driver, replaced the original one, but used the brass ring that allows contact between driver/head/battery tube, in the inverted position
- in the head:
  • as a spacer I used a copper piece that I ordered from kiriba-ru a while ago (initially thought for zoomie pills)
  • used a triple DTP MCPCB + optic from FWAA, with 3 Luxeon V2 4000K emitters
  • and I put a piece of orange GITD tape for the ā€œafterglowā€ effect.
- the lanyard was made with the original lanyard but rearranged
- and the pocket clip was removed.
Iā€™m pretty happy with it, it less big and less large than the OTR 311 which I was using as EDC light, and besides that, it has tha very configurable H17F driver that is probably my most favourite for clicky lights currently :wink:
This is probably my new EDC flashlight, and despite not being perfect it is a very nice light. As for the D25C, I like its anodizing very much, as well as the size (compactness :wink: )!!
Nice mods, MascaratumB. Thatā€™s a really nice little triple you have now.
Thanks Lotus_Darkrose :wink:
I was wanting something like this for a while, so Iā€™m glad the mod worked out well :blush:
Oh, and BTW, this is not an original idea (making it a triple) since it has been done before by some other members here on BLF :wink:
