I went on to the wurrkos.com website . It shows the FC12 in purple at $23.99
If you click on it the price becomes $39.98 .
What’s up with that ?
Ordered on the 12th, arriving tomorrow.
18 days from order date….I’ll take that!
I’m expecting January for BF orders
I hope to be pleasantly surprised :partying_face:
Just received a TS21 in RED w/sst20 4000K. It's awesome!
Has one strange issue - the BLUE switch LED comes on and off intermittently, on it's own, usually during usage. Funny I've seen the same exact behavior with the Astrolux EC06. Seems to be reproducible with the light cold, sitting for a while. Didn't check if the TS21 is using the same USB-C charging controller chip as the EC06 but I suspect it is. I believe Sofirn makes both the Astrolux EC06 and these Wurkkos lights. The BLUE LED is from the charging circuit. I get the same BLUE LED on if I connect for charging, then disconnect the BLUE LED stays on solid for a while -- strange behavior.
Wurkkos - can you guys verify this behavior? Anyone else see this?
Mine has the same behavior. The blue light will randomly come on after power off for maybe 30 seconds. I have the gun metal grey version 2. It’s an awesome light, my favorite actually. I’m wondering why it does this too?
That is noted here in LuxWad review
https://zorro.casa/sync/Hosting/Utilities/Electronics/Anduril/Anduril%20manual%20~~%20v2%20~~%20simple%20mode%2C%20Wurkkos%20TS21.txt?blf
Good to see confirmation. Seems like same mistake now appearing in multiple lights, at least the TS21 and EC06.
Where did this text snippet come from exactly? Looks more like a manual, not a review. Luxwad's reviews I thought were all video?
Current last post in his review
I’ve also got the button issue on my champagne TS21.
Ohh - just measured the new TS21 parasitic drain. On the hi amber switch LED, draws 13.5 mA - yes milli-amps. Way too high!
It's 116 uA on LED switch OFF, 180 uA on LED switch Low (hardly noticeable btw)
13.5 mA is a big draw. That will drain a 4000 mAh cell in 12.5 days.
Expected draw with switch OFF is ~30 uA, maybe 200-300 uA at most on Hi.
Once again, the charging circuit is responsible for some of this, carelessness for the rest.
Dunno - what will it take to get these manufacturers to start checking this? I don't get it.
Hope mine is different when it comes but I doubt it. Anyone else check theirs?
I see Digitalcircuit reported about the same in LuxWad’s review.
It's designed this way, same as the EC06, same as the SC31 Pro - way too low resistor values used like 1K or 0.5K, when 6K-12K should be used. With the TS12, the amber at this intense level looks way too bright, but the low is very hard to notice - probably has to do with the mech design - poor placement, poor optics for the switch LED. I see other lights using a switch cover that's not very translucent - details, details...
Do you mean SC31 Pro? I didn’t know that one had high parasitic drain too.
Ooops, yep. SC31 Pro. Recently got 5 green ones to gift, but did minor checks/updates. All 5 had a 0402 1K resistor for the switch LED's, and even my older black SC31 Pro had the same 1K resistor. Swapped them out for 6.8K - much better, low and hi still good visibility.
Hi went from about 1400 uA down to 271 uA. So Yes, stock SC31 Pro has high parasitic drain for switch LED on Hi, way too high.
With 6.8K resistor: OFF: 34 uA, LO: 75 uA, HI: 271 uA
Probably could even use a bigger resistor like a 10-12K and still get good LO/HI output.
Is it hard to get to that resistor?
There she is, had a pic, to the left of pin #1. Easy to remove with a wet iron tip, I used very light amt of solder paste on the 2 pads then used the iron on one end to simply get it in place, then hot air - worked well.
I’ll probably leave it stock and just use low level. My soldering skills suck lately. I checked my SC31 Pro. 1.4 ma on high, 90 microA on low and 41micro A on off. I can see the low pretty well so not so bad.
Does the built-in Anduril and/or Anduril-2 "Low Voltage Protection" which activates at ~2.8 VDC eliminate all parasitic drain on the battery, so that the battery cannot be discharged any further whether the processor was "in-active-use" or while it is "idle-and-sleeping"?
I have no experience with the micro processors used for Anduril, but I understand how they would be able to stop power from being supplied to the main or aux LEDs (including the switch LEDs).
What I am wondering is, does the processor still need to have a parasitic drain on the battery in order to determine if or when the battery's voltage is above the low voltage cutout or is there some other type of circuitry that totally eliminates all current when the battery voltage is below the low voltage cutoff and if there is a parasitic drain after the low voltage cutoff, how large is it?
Thanks.
I think it does turn off the switch LED's in LVP - it wakes up periodically when the MCU is asleep. I believe in the wakeup period, it draws about 3-4 mA, but again it's only for a short duration at a periodic scheduled time slice. I don't know all the specifics though, but of course it can't do anything about the charging circuits - those are independent.
I think at the final moment of reaching the bottom level, it shuts everything down.
