Gen 2 springs have less coils, and as such, have wider deltas between wires, which makes them have higher conductivity(at the cost of mechanical strength, and still worse than my 3rd gen design in terms of resistance).
Mine arrived today along with the Convoy 4×18a.
I’m not sure about swapping springs in it because they look gold plated stock.
Thanks again BlueSwordM for making that happen. You just cannot get enough good parts for modding.
How does the FB2 bin look to everyone? I’m thinking of getting a DT8 but since Hank ran out of the FA3 bin, I’m worried the 4000k sst-20 DT8 might look a bit green since I don’t expect each emitter to get much over 2.5.
Hank has FD2s at the moment. I believe lumintop is using them or FA3s which I have in my HL3A. I’d be annoyed if I ordered a DT8 only to discover that it’s greener than my HL3A. I wouldn’t be able to stand it and would want to swap the emitters in one of the lights.
How much demand is there for a 5mm spring? Just wanted to know.
Simon (Convoy) mentioned that he doesn’t have a suitable 5mm spring for high current just last week, I suggested these, but the current ones are too big.
I’d be interested in it also. Currently I’m using the large spring in reverse on the Convoy 8A driver for use on a rifle. It would be much better to install a 5mm spring for my customers
I see. I’m going to note it down, and reopen another GB in a few weeks anyway.
It looks like I could actually use some new Copper alloys which have slightly higher conductivity(still not as high as BeCu C17500, but higher than C17530) with similar mechanical properties and a different plating setup.
You could also drop the exotic alloys paradigm, BlueSwordM, and find some good manufacturer willing to go with copper clad steel springs.
Here's some related info at Fisk Alloy (copper clad steel 40), and I also found this Jiangsushy chinese manufacturer of the stuff. So even before going into custom copper clad steel of 50% or higher IACS, this by itself is an upgrade. Thick and short springs also matter, as this considerably reduces the spring's resistance (increases conductance) while maintaining its strenght.
I know there were problems with this first experience of yours in this regard, as the springs you received were really no better than other good high conductivity springs at the usual manufacturers (Convoy). You know what I mean with this, it is a matter of trusting in the right people, which is a matter of the kind of energy you hold in this regard, of what you believe (i.e. mind reprogramming, visualization, and etc.).
Getting a nice set of high IACS, strong copper clad springs should be fairly easy and affordable; even with silver or even gold coating.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
If you produced a batch of 5mm springs I would definitely buy some. I don’t have a specific need right now, but it would be good to know that I had the best 5mm springs on hand for any build.
@Barkuti, that is not actually the case. I did have initial problems when asking and “probing” a lot of manufacturers about the springs themselves, but once I found my current manufacturer, I did not have any of my problems.
They made my springs perfectly to my design requirements, the specifications of the real springs themselves were very close according to my simulations(mine did not take into consideration the contact resistance of the plating itself, and assumed a perfect weld), and thus, I am very happy with the 1st and 3rd Gen springs especially(the 2nd Gen spring designs were certainly not optimal :P).
Besides, I don’t recall Convoy using any BeCu alloy.
Currently, they are using a phosphor bronze alloy, which is good enough for most applications; my own springs are a step up from that, and are competitive with the Emisar BeCu C17500 short springs in regards to conductivity/mm length of wire(still worse, but not by much), with a good size, better mechanical properties, and lower prices(gold plating in small quantities is rather expensive as I’ve said before…).
Overall, I am satisfied with my current generation of springs, but I want MORE obviously from them:
better materials, better plating, better design, more of them, but I am limited by funds.
Still, thank you. I hadn’t even thought about CCS materials. I’ll look into it and perhaps do my usual math/simulations.
I did a quick conductivity test on one of your springs long ago, injecting a high current over it with my precision power supply and measuring the voltage drop over its opposite ends as best as I could; I also tested one of the springs coming in one of the Convoy SST40 drivers, and couldn't find a significant difference. It was a quick test, and can't say if I did it with a gen2 or gen3 spring.
Your efforts are welcome in any case. Concerning the idea behind copper clad steel, or what I have in my mind, is some ≈70% IACS, copper clad piano wire spring with a decent plating. And of course, springs made with thick and short in lenght wire, for maximum conductivity.
I did that the other day and I got ~9mΩ for both small and large springs, Intl-outdoor about 4mΩ but they are significantly shorter, which makes sense because their lights don’t accommodate for protected cells, they also put a thin brass button under the spring to prevent the cell from crushing the components on the spring side of the driver.
@thefreeman, that sounds about right taking into account contact resistance.
I’m still not going to go with gold plating as I got a new quote, and the prices are still as expensive as ever, and I don’t want to increase the prices yet again unless I can massively increase the current performance of my springs.
My measurements don’t account for contact resistance, I used a four wires measurement with the voltage probes at the end of the first turn (bottom and top)
One can use these springs instead of doing a spring bypass? Results are the same or better ?
thx
A 1cm piece of 22AWG is only ~0.5mΩ, significantly lower than the measurements of the springs I posted just above (though it’s uncompressed, if the spires touch it could be lower)
Spring bypass is in general terms always better. However, and despite the above figure from the freeman is accurate (“1cm piece of 22AWG is only ~0.5mΩ”, 544.381µΩ or 0.544381mΩ according to Electrodoc software), it must also be noted that a proper spring bypass needs to be coiled, or else its life could be rather short. If the bypass is not coiled, it will elbow at some point due to the spring compression, and after repeated spring compression and release it will sooner or later crack at the elbow joint. For this reason the lenght of a proper spring bypass must also take coiling into account. It is only slightly more lenght versus straight wire, 30 - 40% maybe. Cylindrical toothpics make good molds for coiling the wire, by the way.
Properly coiled spring bypasses can last for ages (the solder points are critical and must be done properly).
They arrived yesterday!! All looks good, they survived the journey. Thanks !!!
@Tom E Niiice!
Finally
Great news.
Got mine yesterday. Thank you
808Hi
That is odd…. Hawaii..?
It would appear that Hawaii would be later. Who can understand the mail. LOL
Water Cooled MT35 PLUS RE-MODDED------MT35 Plus with SBT90.2 mod ( GT90 kit from Texas Ace )
7th annual BLF/O-L contest Haikelite MT07 upgraded-----8th annual BLF/O-L contest “SKELETON”
Water Cooled 20K lumen POT LID LIGHT------ Cyclops 18M cd flashlight Mod------Q-beam mod to led
Convoy 4x18 Luminus 90.2 mod with 86mm reflector
Think outside the box too long , cannot find your way back in
I received my springs today
I got my envelope too
, how to differentiate between gen 2 and gen 3 springs though ?
@thefreeman, look at the design.
Got em.. today!!!!!!!!!!!!!!
KB1428 “Live Life WOT”
Got mine today, better late than never, thanks
No problem.
I’m so happy everyone finally received their springs.
That not only made my anxiety dissapear, but it also means I can start selling springs again.
The FD2 looks pretty good overall at low-mid currents, and excellent at high currents, but I’m not sure if it’s available from our usual supplier.
So, I just thought about something.
Are the gen 3 springs still available for purchase?
Yes they are still available to purchase.
Piercing The Darkness YouTube channel – https://www.youtube.com/c/PiercingTheDarkness
Thanks for answering, BlueSwordM.
thx
