That’s understandable - Taobao customers typically expect instant customer service from 8am to 10pm. It sounds like you need to expand and hire more workers to take off some of the time burden. 加油!
Hi Hank, is there any possibility of an alternative body tube for DM11? The current DM11 tube is too aggressive and small. The pocket clip is unusable too. I would love to be able to buy a 26800 tube just like D4SV2’s. It’s perfect.
I am also curious, why did you choose to make D4SV2, K1, and DM11 all have slightly different threads despite being almost exactly the same diameter where the body tube connects to the head? Being able to swap a D4SV2 or K1 body onto my DM11 would solve all of my problems with it. Please consider using a standard thread pattern on new models with similar connection sizes.
I ordered Nov 25 and the price has not changed for the version I ordered- green with green switch led, and 3500K, B35AM LED. Still $74.65
I never saw any other options listed when I ordered. Only the body color, switch color, and emitter.
Prices did increase by $5 for the newer models but the add on cost for B35AM and XHP 35 HI on the DM11 decreased by $5 so you wouldn’t notice a difference with that particular build.
I wish there was a blue switch back light option. I thought that used to be available? Now I guess I'll have to decide between cool white and cyan when the SFT40 DM11 comes out, but I already have a light with cyan back light T_T
I tried to test it, but it’s so quick it wasn’t easy to get a meaningful measurement - it appears to be about 1.6 lumens, so not exactly “bright” it seems
Thanks also for the added info on the driver!
Interesting, all the previous tests were done with a Wurkkos-branded 5000mAh cell. I switched it out for a Molicel P42A and measured the exact same output, so at this one at least doesn’t seem to care about the battery used.
Perhaps I should start adding a fan in the runtime tests - I do mine with the light facing upwards in a white cubicle bookshelf, with an old Galaxy S-something plugged into life support specifically for measuring runtimes.
If you add cooled runtimes, make sure to keep doing uncooled also! The vast majority of runtime tests are uncooked so they’re only comparatively useful if there are uncooled ones to reference against other lights.
Zero only does cooled runtimes, and while that may be nice for representing you holding the light and using it on a cool breezy night, his runtime tests are largely useless for comparison against other lights as tested by other reviewers.
They’re only useful for comparison against other lights he’s reviewed because the testing parameters remain the same.
The same is true for every reviewer. Each person has a different setup for this sort of testing, so the variation is far more inconsistent than for things like lumens. At least with lumens, people can obtain reference lights and get within roughly 10% of the same value as other people… but for thermal runtime/output tests, one person might test at 15 C ambient temperature with a fan, while another might test at 30 C uncooled.
It can also vary significantly for a single reviewer. Like, even with HVAC and a thermostat, room temperature could be 17 C to 22 C in different seasons. A light may appear to regulate at a higher lumen level simply because it was measured during the winter.
Depends on the country and shipping method. For Germany -> normal shipping, no extra VAT/charges. Express shipping -> FedEx will send you a letter with custom/VAT fees.
Hank,any chance you introduce Cree XQ-E High Intensity?
I think it would be a really good option for channel switching lights. Right now the throwy options are all cool white low CRI Osram. Offering Cree XQ-E HI will open the door to a much bigger range of CCT and CRI with an LED that has three times the throw capability of XP-L Hi.
Edit: XD16 also looks interesting and capable of 2 amps recommend max current.
