Sorry for keeping you guys waiting...
Has this project been abandoned?
I’m interested too
It will happen this month but not exact date. Fyi, there will be another emitter option being release after SFT40.
Will it be the round Yinding 5050 ?
Which one? What am I missing?
Will announce later.
freeme:It will happen this month but not exact date. Fyi, there will be another emitter option being release after SFT40.
aggalitsas:Has this project been abandoned?
SFH55 added.
SFH55 added.
Coupon for BG store?
ASTROLUX. [quote=aggalitsas]
SFH55 added.
[/quote]
HI freeme,
coupon for BG store of astrolux ft03s with sfh55? thanks in advance.
ASTROLUX.
aggalitsas: freeme:SFH55 added.
I don’t get it :question:
Weird. I see that banggood has a ft03 sft40 ready to ship, but it says that the coupon code works on a different sku number.
The one that the code works on says completely out of stock with no estimated arrival date or anything.
Hello freeme,
can I get a discount code for the astrolux ft03s with sfh-55? Would be very happy...
Thank you freeme,
incredibly quick response.
Ordered...
Hello Freeme, can I get a code for the SFT40?
Can someone please explain the difference between sfh-55 and SFT40?
SFT40 is a dedomed sst-40 with better throw and tighter spot but how does it compare with sfh-55?
The SFH55 should be 4 times as bright with 65-70% of the throw. 1.3km Vs 900m for the SFH55. Hotspot will be much bigger.
Here is Tom E’s thread on the SFH-55.
I received a sample of this LED from Neal - no info, no labeling, no docs. He just asked me if I'd be interested in testing a new LED. I couldn't resist. After some simple bench power supply tests and measurements, I realized it's a 3V LED, must have a pretty low Vf so should be easy to get some serious amps feeding it, and it's footprint matches a SBT90.2 so we should have available MCPCB's to fit it. I decided to host it in a WildTrail WT90 since I have 2 of these, should be easy/quick to re-u…
Hey freeme, I just saw the SFT40 version listed in the original ft03 sst40 webpage in BG under ID: 1420116 and in stock, while your link is still showing as out of stock. Needless to say, the coupon is not working. BG should get on it and fix this.
