Yea, I pretty much do that for all mods. On most lights, you wouldn't really have a reason to remove the battery tube often. For this SC31 Pro, only time I'd remove it is for exchanging 18650/18350 tubes, but you'll find the driver stays better in place once it's been secured for a while, not sure if it's hours, days or weeks. It's really the LED wires that make it awkward in popping out the driver. Mostly the Chinese lights use a stiffer, lower strand count wire (plus their silicone covering seems stiffer) so I almost always replace them, specially if I can fit in a thicker gauge. But of course the thicker wire tends to pop out the driver more :FACEPALM: .
What tint do you think this SC31 Pro has? I think it’s 5700K or above. Very ugly live compared to my other SST40s (convoy: s2+, s21a; astrolux: ec01, ft03; mateminco mt01). I bought it at Sofirn’s official store on aliexpress. I tried to get help from them, another LED, but they think it’s okay.
Did you set "white-balance" manually when taking this picture (otherwise, most cameras will auto-adjust the color temperature).. Your SC31 Pro beam does look more "greenish" though based on your picture. (in my limited experience, both SST40 5000k and SST40 6500k, will look varying degrees of "greenish" when at lower brightness levels).
The two images were taken with the same settings in manual mode. With the naked eye, there’s a big discrepancy from my previous SST40 lights. It doesn’t matter, it just annoys me. I’ll buy another one LED + MCPCB from Convoy. But it wasn’t worth buying from Sofirn.
It is difficult to prove with images what one sees with the naked eye.
It’s funny I really like the Sofirn lights I’ve got (sp25a, BLF sp36pro, and sc31pro). I only grabbed the sc31pro as it was so cheap when buying other stuff I grabbed it. And now it’s my most used single cell 18650 light, I absolutely love it. Doesn’t get too hot, can be run at high lumens fairly sustainably, flat top/button top, nice multi purpose beam, side switch etc. It’s just a fine choice, I grab it over other lights 4x the price.
Has anyone rewritten anduril for a different battery mode? I would like this light to work like fenix. turn it on, and the aux light indicates battery level. this is a feature i use hourly on Fenix. I have no interest in battery mode as it takes too long to count the blinks, and personally find it pointless. I simply need to know 25% 50% 75% etc.
i just got this light yesterday, glad to see i can reprogram it, may have to make adapters to do it.
be interested to see peoples response. i feel like a lot of more can be done with the aux light to indicate battery voltage.
I'm not sure exactly how the battery level works on a Fenix, but it's do-able. I think the 25-50-75-100 level detection is in Anduril 2, just not enabled, and doubt it would blink it out at turn on, but could be programmed to do so. It's a worth while feature to consider, for sure.
I’m not sure exactly how the battery level works on a Fenix, but it’s do-able. I think the 25-50-75-100 level detection is in Anduril 2, just not enabled, and doubt it would blink it out at turn on, but could be programmed to do so. It’s a worth while feature to consider, for sure.
Its pretty simple, as soon as the light is turned on, the aux light simply goes solid green for over 75, blinking green for 50-75, solid red for 25-50 and blinking red for under 25.
all you need is a maybe add a 3 second timer to get your finger off the light to look. it really removes battery charge worries. having it buried in a sub menu i feel is not a great place.
is there a way to @ToyKeeper. To see what he/she says?
For those who don’t want it, could simply have a toggle behind the battery mode.
Does that mean 50% would range between 26% and 74%. Seems pretty broad if that is the case.
no. i gave the range above. 25-50 and 50 –75 would be different light groups
Ok, 25% range, Still broad . Why wouldn’t you want to know exactly. Anduril counts it out slowly enough. Now Convoy’s is hard to count it is so fast.
Ahh, ok - this SC31 Pro light has only one colored LED wired to the processor (MCU), not two. TK occasionally checks threads, bit the Anduril 2 thread may be the best for this, but she doesn't design or mod hardware.
because to me its useless. I don’t care if the voltage is 3.8 or 3.7, literally means nothing to me. I need to know if the battery needs to be charge, or roughly my runtime. 4 groups is all i need. over 75 % no charge, under 50, short or long walk depends on if charging. and if walking and really using a lot of lumens do i need to cut back etc.
my wife does not need to know the voltage range of a li-ion cell. not sure why anyone does. a voltage check now takes a bunch of clicks and counting, at least 20 seconds. this should take less than 3.
don’t use it, thats why i said toggle it. I don’t like carrying extra cells, i check voltages hourly sometimes with my fenix’s very simple.
Ahh, ok - this SC31 Pro light has only one colored LED wired to the processor (MCU), not two. TK occasionally checks threads, bit the Anduril 2 thread may be the best for this, but she doesn’t design or mod hardware.
has a red/ green light depending on charging. not looking to mod the lights, is it just a voltage change to go from red to green? I don’t really care how its done. it can be 4 blinks for all i care.
I will give this a couple days, then bounce the question over there. I am seeing “2” has aux light voltage check, so it appears this has already been thought about.
Thanks Tom
You can use a build option, in theory, to blink out a simpler battery level. This is the code in Anduril 2:
ifdef BATTCHECK_4bars
PROGMEM const uint8_t voltage_blinks[] = {
// 0 blinks for less than 1%
ADC_0p, // 1 blink for 1%-25%
ADC_25p, // 2 blinks for 25%-50%
ADC_50p, // 3 blinks for 50%-75%
ADC_75p, // 4 blinks for 75%-100%
ADC_100p, // 5 blinks for >100%
255, // Ceiling, don't remove (6 blinks means "error")
#endif // BATTCHECK_4bars
In theory, you can use this method instead of the big n.n method, just a compile setting.
PROGMEM const uint8_t voltage_blinks = {
// 0 blinks for less than 1/span>
ADC_0p, // 1 blink for 1–25/span>
ADC_25p, // 2 blinks for 25–50/span>
ADC_50p, // 3 blinks for 50–75/span>
ADC_75p, // 4 blinks for 75–100/span>
255, // Ceiling, don’t remove (6 blinks means “error”)
#endif // BATTCHECK_4barsIn theory, you can use this method instead of the big n.n method, just a compile setting.
you are significantly well versed in her code structure. it would take me a bit to learn and rewrite. I guess in “2” she did exactly what i asked with the 4 groups. I will be ordering a flashing kit over the next month
since you mentioned it only has 1 wire to the mcu, how are they accomplishing the green/red aux led indication?
Actually the 4 level batt level indicator stuff has been around a long time, I just wanted to verify it still exists in the latest A2.
Actually I was wrong - that specific code is not used on the A2 project, but there is a compiler setting: BATTCHECK_4bars, that should be used properly in the module: fsm-adc.c, just that it's untested, unproven, least as far as I know...
Green/red aux? You mean for battery charging? The MCU is not involved in the charging circuit -- totally separate controller. In theory, there is a spare pin, #7, than can be used for a 2nd AUX LED, but again, a hardware mod would be needed.
Maybe Wurkkos FC11 would be what you want if you can live without Anduril.
Actually I was wrong - that specific code is not used on the A2 project, but there is a compiler setting: BATTCHECK_4bars, that should be used properly in the module: fsm-adc.c, just that it’s untested, unproven, least as far as I know…
Green/red aux? You mean for battery charging? The MCU is not involved in the charging circuit — totally separate controller. In theory, there is a spare pin, #7, than can be used for a 2nd AUX LED, but again, a hardware mod would be needed.
Didn’t realize the charge controller controlled the led separate, may i ask where you are seeing a diagram of the pinout wiring. I wrote over in the other thread to see if toykeeper is there. should be a simple build 1-4 blinks is all i need, i was just trying to be fancy with the different colors. no big deal if all green.
MCU pinouts on the SC31 Pro matches the Q8 w/AUX LED which matches the Emisar D4 (no AUX LED):
/* Emisar D4 driver layout
* Reset - |1 8|- VCC
* eswitch -|2 7|-
* AUX LED -|3 6|- PWM (FET)
* GND - |4 5|- PWM (1x7135)
I reverse engineer the MCU pinouts, then try to identify the charging circuit controller, then find the datasheet on it.
