FREEME ✌ ASTROLUX® MF01X 18*SFQ43 LEDs 21000lm 3*21700 USB-C Flashlight Group Buy - ALIVE frm $105
Yes, the charging circuit is spec'ed this way so the measured 120 uA makes sense (20 uA for the driver circuitry, 100 uA for the charging circuitry) - not a deal breaker with 3 21700 cells, but good to know.
Astrolux needs to start implementing metal switches if the plan on staying in the higher end market. Acebeam (best switches), Manker, Fenix, and Imalent all know what is up. METAL SWITCHES SHOULD BE THE STANDARD, FIGHTEH ME.
Manker has good switches? How do you know that because they look nice?
Metal buttons*
Thanks Tom E for reporting about the high power consumption of the TS21 (Anduril 2 with powerbank, amber-orange switch LED) when the aux LED is set to "High".
I also tried to measure on my TS21 (my multi-meter with mA measurement is a sort of low-end multi-meter only, so may not be so accurate).
Anyway, sharing my measurements:
1) TS21 (Anduril 2, with powerbank function, amber-orange switch LED)
Anduril aux-LED state on:
'Off' = 0.11-0.13mA, shoots up to around 0.40mA (for less than 1 second) every 5-6 seconds
'Low' = 0.18-0.19mA, shoots up to around 0.45mA (for less than 1 second) every 5-6 seconds
'High' = 13.9mA, shoots up to around 14.2mA (for less than 1 second) every 5-6 seconds
2) TS21 (Anduril 1, no powerbank function, green switch LED)
'Off' = 0.04mA, shoots up to around 0.31mA (for less than 1 second) every 5-6 seconds
'Low' = 0.10mA, shoots up to around 0.36mA (for less than 1 second) every 5-6 seconds
'High' = 3.1mA, shoots up to around 3.4mA (for less than 1 second) every 5-6 seconds
There's definitely a big difference in "High' state = almost 14mA (amber LED) while 3mA (green LED).
3mA seems to still be quite high, but a lot better than 14mA though..
I quite like my U22 III switch. Solid and responsive but seems to have enough resistance as to not be prone to accidental activation.
The switch on my U21 died very quickly but that was a long time ago and maybe Manker is making good switches now
I have three Manker U11 with failed switches under the span of 6 months. Terrible design and QC.
Interested
Never had an issue with Mateminco switches. My Acebeam L16 sometimes used to double click instead of single click. Had a similar issue with the MH20GT which had a soft click and hard click single switch (not sure what it’s called)…and the GT mini switch…let’s not even talk about that.
Interested
Interested!
Interested
Interested
Interested
Interested
Interested
Soon...
Oh yeah, thats what I’m talking about. :+1:
It looks quite similar to the “silver” WT90, which is also using three 21700 cells.
Will there be other body colours of this new light?
