Thanks Lotus_Darkrose
I was wanting something like this for a while, so I’m glad the mod worked out well
Oh, and BTW, this is not an original idea (making it a triple) since it has been done before by some other members here on BLF
Nice work MB. I’ve always loved Eagletacs original D series lineup. Best mechanical design around imo.
I’d love to see this next to a FWAA for reference.
Thanks JaredM
This was my first Eagtac, but I am impress with it already. The original UI, given those blinkies that appear in the main cycle after a while were not my favourite, but it worked well (tightening/untightening). Also, mine had a High CRI SST20 4000K, which was good.
As for the comparison, here it is
Convoy S2 (18350) > OTR 311 > FW1AA > DQG Slim Ti > Eagtac D25C > FWAA > Tool AA (magnetic tailcap) > FW3A 18500 > S1R Baton II
Without mods, the D25C is less than 1mm taller than the FWAA (74.5mm x 74mm)! It is smaller than the FW1AA (76.9mm).
Novatac Spa
modded to sw30
max was 90 lumens stock
now 190 lumens w sw30
What switch and rubber boot did you swap in? I have a D25C I’d love to convert to forward clicky
Inside the D25 is a completely standard ordinary clicky switch. Identical in size and shape to what you would find in a Sipik 68.
You should be able to swap it for any generic standard clicky. Just desolder the old one from the board and solder in the new one.
Yesterday I received my Sofirn order and to comply with air freight regulation regarding batteries (I presume this is a new ordinance), the 26650 cells (2x) were inserted in a cheap host. Well, one of those hosts is no longer an economical zoomie. A bit of modding with some extras I had and one became a fair light.
And some beam shots:
At 30” (75cm)
“Flowering” of the die at 12” (30cm). Is this typical of XMLs?
Outside at 30 yards (10m).
When I initially put this project together, many things just so fitted together. But some tweaking will be needed.
1- The emitter is too cold - somewhat in the blue spectrum (although not as much as that last picture, phone auto-exposure makes it look worst).
I doubt it’s a genuine Cree, but for what’s it worth, a closeup of the LED:
So I’ll change to the XML3 from the Convoy S9. I had ordered an XPL-HD for that light.
2- The rear-clicky isn’t correct. Always double tap to get the driver to respond. Even without the switch, just with a wire, the driver is not responsive. Maybe a cap on the board (MTN N-lite) to be replaced?
Oh! I forgot. Some specs:
Low – 26 lumens
Med – 217 lm
High - 560 lm
Tailcap at max: 3.4 Amps using Sony VTC6 fully charged. If this driver is rated at 3 Amps with 8 x 7135, would the excess current draw be from inefficiency?
I would think a proper Cree XML-T6 should give me 800 to 900 lumens at 3 amps (from their datasheet).
As for the switch, I used one of these (2.93€ |Taschenlampe vorwärts schalter|switch flashlight|switch fittingflashlight remote - AliExpress) sold by Simon of Convoy.
As Firelight2 said, you only need to unsolder the stock switch and replace it by the new one.
As for the rubber boot, that one was from another flashlight (eventually Convoy T2?) and fit well, without protruding too much. I don’t have measurements, but I would say that you can find some suitable here, eventually the 14x6mm or 14x8mm:
https://www.aliexpress.com/store/group/Silicone-Tailcaps/708513_10000003674535.html
The original one will not work well as it is too short for the forward switch.
Today I decided to try how many amperes I can get Wildtrail WT3M to draw. I changed SST40’s to 5000K XHP50.2’s from Sofirn. I managed to squeeze 26awg wires parallel to the original wires through the small hole in the mcpcb. I also did double spring by-passes with 24awg wire. I also did solder “beds” to both springs that I filed flat. I theorized that it provides bigger contact surface to battery poles.
I measured current with Uni-t 210e clamp meter and 16awg wire and used Molicel P42 battery.
At start it draw 30.5 amperes and stayed above 30 A for a while. Too bad I don’t have any equipment to measure lumens.
I call this trial a success.
congrats on your mod
imo, no, the cross in the middle of the beam at 12” is not normal, in the lights I use… but I dont have your light
when I see that cross, I believe the LED is too low, relative to the bottom of the reflector… I sometimes sand the centering ring to be thinner, to bring the base of the reflector closer to the base of the LED…
at other times I lift the mcpcb with a shim. Copper sheet is recommended. I also have had success using thermal tape, folded into the necessary thickness under the mcpcb, instead of thermal paste.
at other times I remove the centering ring that is lifting the reflector too high above the LED, and install Kapton tape instead, to make sure there is no short circuit from reflector to LED and the solder joints on the mcpcb
So I would need some challenging work there:
I estimate some .010” clearance as is. The original wiring was flattened to accommodate the LED ‘washer’ and this served me.
I just so checked the reflector body width and is about .300” so I’m good to grasp in the lathe chuck and make a reduction.
BTW, would you think this be a true Cree? The high (maybe 7000ºK) I have disdain and maybe decapitating (shaving) the emitter would lower this. I don’t have many 5050 led options in my bin and pirating the Convoy S9 is just another hurdle. And then the output is below par.
Edit:
Bringing up the star wouldn’t have any effect as the reflector sits on the MCPCB via the gasket. The stack is held together via the bezel.
Regarding plus-shaped donut hole in beam.
I’m not familiar with that particular reflector. However, I’m not sure it’s that unusual having a donut hole in the center of the beam with a large reflector when viewed at 12”.
The reflector focuses the light forward. Where there’s no reflector, the projection will tend to be dimmer. This should only be apparent at extreme close range. Once you shine the beam a more practical distance it should look fine.
Try shining the beam 30’. Do you still get a donut hole in the center of the beam? If so, then there may be a problem.
Lowering the reflector:
great photos
looks like the reflector would press on the wires if the white plastic spacer was removed, so I would Kapton Tape the solder joints, and remove the white plastic spacer, in hopes of bringing the reflector closer to the base of the LED.
and/or, I would sand the white spacer to be half as thick as it is now. And still insulate the solder joints w Kapton tape… You can put the tape on the base of the reflector instead of on the MCPCB, your choice…
Well, I’m going to make a reduction in the reflector base. I reckon I can make some .060” clearance there.
The translucent gasket is what centers the stack so that can’t be removed but I can reduce its thickness from .030” to about .015”.
But what about de-doming the little beast?
Edit:
Thanks for chiming in Firelight2. This reflector is somewhat thin at the base so that’s not an option (reducing the base).
As for the beam profile; at 30” there’s much artifact on the perimeter. Scattered secondary rays from improper focus I suppose. Have a tool shop so whittling down some aluminium isn’t a problem.
Another thing you could try is using thinner wire to the solder pads on the star. Bit awkward, but it’s doable
Firelight2 :
Do check my last photos. The wires are the smallest (maybe 30 ga) and were flattened at the solder pads.
You could try inserting a few scraps of copper sheet cut in the shape of the solder pads between the star and the LED. The effect would be to slightly raise the LED in the reflector.
I’m not sure this whole project will accomplish anything though. I find it hard to believe the reflector would be designed to have the LED sit so high up. I suspect none of these suggestions will actually affect the beam in any meaningful way.
true
when lifting the star, a similar reduction in centering gasket height can help keep the stack height constant, and bezel pressure consistent. In some cases I have also opted to change lens thickness on some builds, or if there is room, tighten the bezel down further.
disclaim
I have zero experience with your light, and cannot recommend non reversible changes… I most definitely would NOT shave the reflector
I think sanding down the centering ring is a viable option… but, again, no experiece with your model of light, dont know if the cross in the beam at 12” is “normal”…
fwiw, I just reworked a Novatac w 219b, to lift the star. It had the same UGLY cross in the beam, at 3” from target, plus a ring around the outside spill at 4’ from a wall… FUGGLY!.
by lifting the star closer to the reflector, and removing the white plastic centering ring, I most definitely DID eliminate the cross in the beam… I just had to use Kapton tape over the solder joints on the star… since the reflector presses on those… and I had to fiddle to get the LED centered, since I no longer have the luxury of a centering ring.
@ Firelight2:
Don’t quite get at what you are describing? You are presuming I sit the reflector on those solder pads with Kapton intermediary.
@ Jon:
I just reduced the outside of the reflector base to clear the solder points. Now for the reduction of the gasket thickness. A long process as these are polyethylene (or some sort of soft plastic – but higher melt/soften temperature) and don’t machine well. Using sandpaper on a wooden block. Checking for parallelism as I go.
But none have answered my second query; would this be better if I shaved the dome? Is it an actual Cree? Putting more time in a clone than what I expect to have as result may not be worth it.
Edit:
A picture to better describe my intent.
Don’t mind the tape, covering the apertures to not have any shavings in there.
excellent option
I agree its a pain to sand the centering ring… I use a block too
I dont know the answers to your shaving and authenticity questions
here is an LED type lookup:
I hope you get the beam dialed in
ime the cross in the beam, is definitely related to reflector to LED spacing, and not specific to the LED you chose
