That was my reason for ordering two of these lights also. At least charging the battery inside the Stank seems to work fine, I’m going
to keep them in the cars with the battery removed and only inserted in an emergency on the road. When the battery stops accepting a charge, I guess
it’ll be a throw-away light, or I’ll just check my other flashlights to see which ones fit those safety cones.
I am unsure if I am keeping mine or not. I would keep it just for the 2 cones, but they do not fit any other flashlight in my collection. I might keep it because it is so unique however the battery thing does bother me.
Heh, my supplier had basically the same light and I sold nearly all I ordered (about 80) in 2 weeks for $7 each. I think there might be 4 or 5 left in the box. But I wouldn’t have one for myself, not with button cells and such weak output. That light has “muggle” written all over it.
Besides, once the flex heads have been bent around a couple of times, they don’t always push back into the body the way they should. They get kinked.
^ Insane^ In for a 3 pack. Pricing change: Note that they are charging me $14.85 SHIPPED! for the 3. Thanks Turkey dance:-)!! Planning of gifting out to muggles for Christmas and keeping the Sofirn D25s for myself now.
FreeLionVon EDC flashlight is a mini and lightweight keychain flashlights with three lighting sources of white, red and UV. The max output for white is 550 lumens with beam throw 100 meters. Plus the extremel compact size and USB rechargeable design. It’s ideal for everyday carry.(copied from item description)
Thanks for posting. Ordered 2 (separate transactions, coupon worked both times), because this is nearly a dream light for me. If only it had a hat clip. I’ll probably destroy one trying to put better emitters in the white/UV, and when I do I’ll see if the body is thick enough to drill/tap so I can screw a hat clip to it (instead of super gluing).
I don’t think it’d be worth the trouble on the UV. In a tiny thermally-ignorant host like this and with only a 300mAh battery, it’s doubtful that it can actually see the claimed 700mW output (or if it does, that only lasts a few seconds I’ll bet, with output dropping off rapidly and the emitter derating just as fast). A nicer/better emitter isn’t going to help anything. It would be neat to craft a teeny ZWB2 filter for it, though!
