Thanks to this new section on BLF I know of the existance of whale oil lamps :-)
Nice glazes Fritz! (I made stoneware glazes for a while as a hobby, but never experimented with reduction firing the oven. Since 10 years ago I don't have a workshop for it anymore)
From my reading I get the impression that wick type lamps were relatively low power typically, in the few CP to 200 CP/Lumens range. Only designs like the center draft circular wick and Aladdin designs got any where near the 200 Lumens output while flat and round wick lamps were typically closer to the 10 to 30 Lumens range. Is this correct?
The most powerful wick type lamps were probably those used in Lighthouse lanterns. From some pictures I have seen it looks like they often used multiple circular wicks of increasing size from the center in a center draft arrangement. These would be 19th century lamps I presume? Any one have any references or photos of such lamps and their outputs or information on the highest power lamps prior to the center draft circular wick designs?
A circular wick type was invented by Argand. It apparently eliminated most of the smoke from whale oil lamps. In Norway, I saw old kerosine lamps with flat and round wicks. The ones with round wicks had much smaller bulges around the flame in their chimneys, which looks as though they worked much better. The wick itself was actually flat, but it was fed upward throw a circular hole that bent it in a circle.
Lamps are incandescent like simple electric lights, so the key to efficiency is temperature. The chimney makes it brighter by drawing air. But if there is too much air, there are no carbon particles, like a gas stove. It is the carbon lamp black in the flame that radiates the light. Then there needs to be enough air and heat farther up in the flame to burn away the lamp black, or everything nearby will turn black and absorb the light, like the old part of the Norwegian farm house or a lamp chimney when the lamp has been turned too high. The flow needs to be laminar. If the wick is too high or there is too much flow for any other reason, the flow becomes turbulent, and then there are spots in it where carbon escapes. That happens to non-smokeless candles if the wicks are not trimmed in time. In smokeless candles the wick bends over and burns to the proper length at the edge of the flame where there is both air and heat.
Way back in the 70’s we had the 3 day week. It’s a long and political story that lead to the Winter of Discontent in 1978. There’s a ton of stuff to read if you want to.
Basically, the 3 day week means the lights went off, not many people had televisions, cooking wasn’t electric, heating and cooking were gas.
So we lit Tilley, Vapalux, or other old paraffin lamps and heaters instead. The most famous clean burning paraffin heater being the Aladdin.
Every petrol station here had an Esso Blue pump for filling cans with clean burning paraffin (clean kerosene) for our lamps, heaters and stoves. And as it is today, it’s an up yours to anyone telling me I have to pay ‘the man’ to have to cook and heat on domestic supply.
This Vapalux belonged to my dad who was a vet (animals not Vietnam). As a child I helped him deliver calves, find lost sheep and lambs, watch piglets being born, and light us playing Monopoly or cards round the table at night.
And here it is hissing and glowing to this day. Always a pleasing thing is this lantern
Over in the US you still have Miles Stair, an old connection of mine for importing CountyComm stuff to the UK, an Endtimer, survivalist, and an enthusiast of this wonderful old tech.
Any UK residents can find a similar love for all things lighting, heating, cooking at Base-camp. There are two people (Mike and Amanda) who run it, husband and wife, massively knowledgeable on all of it. If you phone and want to chat, make a big mug of tea and have biscuits in your pocket, these chats can take literally hours. Proper old school people, I love them.
Wow, since this thread is de-necro’d. This is an oil lamp from the 1800’s my great grandparents used to use. I ended up with 4 family oil lamps which my grandmother all had converted to electric (in the late 50’s I believe). All original globes and chimneys
Found this oil lamp at the city dump. Whoever threw it away, set it beside the dumpster hoping someone would take it and put it to use. There was no chimney and an old nasty wick. The lamp was covered with old oil varnish, was all yellow, and it smelled really bad. I spent some time cleaning it out with acetone and some other things. Bought a new wick, and a new chimney. Bingo, works perfect.
I have two Aladdin Lanterns and keep them for the nostalgic memories since we used them before electrical power was available where we live. If you run them at too low a brightness, they emit noticeable soot, but otherwise they are great because they can be very bright and quiet (completely silent with a nicer tint compared to white gas Coleman Lanterns).
We have not used the Aladdins recently because unfortunately the replacement "Aladdin Lox-On Mantles" became too expensive (over $30 each) and difficult (if not impossible) to obtain. If anyone knows of a reliable source for the mantles (that is not Ebay), please let me know.
We now use two "BLF LT1" li-ion battery lanterns for power outages and enjoy using them even when we have power. I also occasionally fire up the calcium carbide Miners Lamp that I used as a kid (which was way brighter than the flashlights of that era) and are always surprised it still works like new and that calcium carbide rocks can still be obtained fairly easily. The big disadvantage of the Miners Lamp is that while you have some limited control over the brightness, you don't turn it OFF after it is ON and once you add water to the calcium carbide you need to clean and reload for the next use.
