I’m interested too
It will happen this month but not exact date. Fyi, there will be another emitter option being release after SFT40.
Will it be the round Yinding 5050 ?
Which one? What am I missing?
Will announce later.
freeme:It will happen this month but not exact date. Fyi, there will be another emitter option being release after SFT40.
aggalitsas:Has this project been abandoned?
SFH55 added.
SFH55 added.
Coupon for BG store?
ASTROLUX. [quote=aggalitsas]
SFH55 added.
[/quote]
HI freeme,
coupon for BG store of astrolux ft03s with sfh55? thanks in advance.
ASTROLUX.
aggalitsas: freeme:SFH55 added.
I don’t get it :question:
Weird. I see that banggood has a ft03 sft40 ready to ship, but it says that the coupon code works on a different sku number.
The one that the code works on says completely out of stock with no estimated arrival date or anything.
Hello freeme,
can I get a discount code for the astrolux ft03s with sfh-55? Would be very happy...
Thank you freeme,
incredibly quick response.
Ordered...
Hello Freeme, can I get a code for the SFT40?
Can someone please explain the difference between sfh-55 and SFT40?
SFT40 is a dedomed sst-40 with better throw and tighter spot but how does it compare with sfh-55?
The SFH55 should be 4 times as bright with 65-70% of the throw. 1.3km Vs 900m for the SFH55. Hotspot will be much bigger.
Here is Tom E’s thread on the SFH-55.
I received a sample of this LED from Neal - no info, no labeling, no docs. He just asked me if I'd be interested in testing a new LED. I couldn't resist. After some simple bench power supply tests and measurements, I realized it's a 3V LED, must have a pretty low Vf so should be easy to get some serious amps feeding it, and it's footprint matches a SBT90.2 so we should have available MCPCB's to fit it. I decided to host it in a WildTrail WT90 since I have 2 of these, should be easy/quick to re-u…
Hey freeme, I just saw the SFT40 version listed in the original ft03 sst40 webpage in BG under ID: 1420116 and in stock, while your link is still showing as out of stock. Needless to say, the coupon is not working. BG should get on it and fix this.
I think the SFT40 should be available soon. I can buy it in China.
