ASTROLUX. [quote=aggalitsas]
Coupon for BG store?
[/quote]
[/quote]
HI freeme,
coupon for BG store of astrolux ft03s with sfh55? thanks in advance.
I don’t get it :question:
Weird. I see that banggood has a ft03 sft40 ready to ship, but it says that the coupon code works on a different sku number.
The one that the code works on says completely out of stock with no estimated arrival date or anything.
Hello freeme,
can I get a discount code for the astrolux ft03s with sfh-55? Would be very happy...
Thank you freeme,
incredibly quick response.
Ordered...
Hello Freeme, can I get a code for the SFT40?
Can someone please explain the difference between sfh-55 and SFT40?
SFT40 is a dedomed sst-40 with better throw and tighter spot but how does it compare with sfh-55?
The SFH55 should be 4 times as bright with 65-70% of the throw. 1.3km Vs 900m for the SFH55. Hotspot will be much bigger.
Here is Tom E’s thread on the SFH-55.
I received a sample of this LED from Neal - no info, no labeling, no docs. He just asked me if I'd be interested in testing a new LED. I couldn't resist. After some simple bench power supply tests and measurements, I realized it's a 3V LED, must have a pretty low Vf so should be easy to get some serious amps feeding it, and it's footprint matches a SBT90.2 so we should have available MCPCB's to fit it. I decided to host it in a WildTrail WT90 since I have 2 of these, should be easy/quick to re-u…
Hey freeme, I just saw the SFT40 version listed in the original ft03 sst40 webpage in BG under ID: 1420116 and in stock, while your link is still showing as out of stock. Needless to say, the coupon is not working. BG should get on it and fix this.
I think the SFT40 should be available soon. I can buy it in China.
Ok, thanks! Didn’t make my choice easier. I’ll guess I’ll have to wait for reviews to see the comparison
From my understanding, it should be similar to SST-40 vs. SBT90.2 just with more power.
I assume the SFT-40 can sustain the max power much longer while the SFH55 will maybe get 30 seconds on turbo. Is that correct?
The BIG LED SFH55 - 11 x 10 mm 3V no dome monster
Tried to Google it but didn’t see that thread. Thanks.
Now the SFT-40 version is “Restocking” again. Someone in BG is surely having a laugh.
FT03 SFH55 also. What the heck is going on?
No worries, I will get them fix the coupon on Monday. I was told that they will receive SFT40 within a week.
Up until now, we have either a coupon or a flashlight available, but never both at the same time
What is the technical methodology how they got the SFH55 to 9300lm? How did they double it? Seems ambitious, no?
