major Stink, not gonna open them, will return…
I am unsure if I am keeping mine or not. I would keep it just for the 2 cones, but they do not fit any other flashlight in my collection. I might keep it because it is so unique however the battery thing does bother me.
Woah that battery is scary, kill it with fire before it kills you.
Heh, my supplier had basically the same light and I sold nearly all I ordered (about 80) in 2 weeks for $7 each. I think there might be 4 or 5 left in the box. But I wouldn’t have one for myself, not with button cells and such weak output. That light has “muggle” written all over it.
Besides, once the flex heads have been bent around a couple of times, they don’t always push back into the body the way they should. They get kinked.
how about 3 for $15?
rechargable, too.
code: 6761WOZ8.
^ Insane^ In for a 3 pack. Pricing change: Note that they are charging me $14.85 SHIPPED! for the 3. Thanks Turkey dance:-)!! Planning of gifting out to muggles for Christmas and keeping the Sofirn D25s for myself now.
Muggles will hate those .
https://www.amazon.com/FreeLionVon-Rechargeable-Flashlights-550Lumens-Searching/dp/B0946SPDJR
26.99 - 50% off clip coupon
FreeLionVon EDC flashlight is a mini and lightweight keychain flashlights with three lighting sources of white, red and UV. The max output for white is 550 lumens with beam throw 100 meters. Plus the extremel compact size and USB rechargeable design. It’s ideal for everyday carry.(copied from item description)
That FreeLionVon looks pretty good!
I would get it, but I don't want to accidentally use the UV light because UV light is dangerous.
Good find, thats a good deal even if it’s not of the highest quality.
Thanks for posting. Ordered 2 (separate transactions, coupon worked both times), because this is nearly a dream light for me. If only it had a hat clip. I’ll probably destroy one trying to put better emitters in the white/UV, and when I do I’ll see if the body is thick enough to drill/tap so I can screw a hat clip to it (instead of super gluing).
I don’t think it’d be worth the trouble on the UV. In a tiny thermally-ignorant host like this and with only a 300mAh battery, it’s doubtful that it can actually see the claimed 700mW output (or if it does, that only lasts a few seconds I’ll bet, with output dropping off rapidly and the emitter derating just as fast). A nicer/better emitter isn’t going to help anything. It would be neat to craft a teeny ZWB2 filter for it, though!
Keychain flashlight "Brynnl S11" for $8.50
https://www.myvipon.com/product/8779716-Brynnl-S11-LED-Keychain-USB-Rechargeable-amazon-coupons
https://www.amazon.com/dp/B09CDQCYMB
This is a decent deal if you don't mind a keychain flashlight with a plastic body.
Bought one of these last time.
Pretty good little light.
It looks like Seeknite S11 / BORUiT Mini which was reviewed here: Seeknite S11 / BORUiT Mini ($14 Rovyvon Clone) mini review and comparison
Yup, I'm thinking it's the same thing with a different brand name.
Just received 2 of these. NICE https://www.amazon.com/FreeLionVon-Rechargeable-Flashlights-550Lumens-Searching/dp/B0946SPDJR
There are little soft plastic plugs covering screws on both ends. Looks like it can be disassembled…hopefully no glue.
Red needs a lower mode, UV has a lot of white/purple, but overall a nice light. Just needs a clip!!!
Might buy this just for the straps, then finally buy an acebeam h30, since IMO they’re too heavy for head wear.
