Me personally, I just won’t replace the hotwire bulbs for one simple reason: to fit the fan, braids, whatever, I’d have to leave off the dust-covers, and nfw am I doing that.
There was one set of pricey lights that let you physically adjust the “filament” placement to make sure it’s accurately focused, but I’d still pass. Hotwire bulbs are more efficient when the heat’s bottled up, but not LEDs.
I’ve seen these with double xhp 70 on Alix or something like that. Didn’t cost that much even. Talk about an upgrade! If you can get it to focus that is…
I can’t point to the exact statute, but it is illegal to modify factory DOT-approved headlights Replacing the halogen bulb that were in the lights when they were approved with an led or any other type of lamp for that matter, is looked at as modifying. The bulb has to state that it is DOT approved and/or (?) state SAE Certified. There are a very few sellers of led replacement bulbs in the US that do state the led bulbs they sell are only sold for off road use.
Yes, the US has always been slow to adopt improved headlights. EU used halogen bulb headlights years, decades, before they were legal in the US.
Under US law it is not even legal to install one of the improved EU headlights in an US registered vehicle, even if it fits, unless it is US-approved. This is really too bad as some EU-rated cars have vastly superior headlights.
The recently passed infrastructure bill has a mention of within two years the headlight rules must be ammended. We’ll see. Meanwhile, there are already millions of illegal led headlights sold and presumed installed. And nearly every evening that I may be out in the dark I think I meet some of them on the highway.
I don’t know what car you have but those Phillips one with passive sink braids should fit every car like Cindirela shoes even with car lid closed. Only possible Canbus issues can happen.
It’s very illegal in the EU, reflectors in yuor car are homologated to a certain light source (for example halogen bulb) and only that type of bulb can be used. LED retrofits are illegal and they may get you in trouble much quicker than in the US.
If Philips manufactures H7 replacement lightbulbs that don’t mean they are approved all over the world. Cars and vital carparts can only be driven/used if they have a official European type aproval. But because of the EU, no matter what EU country has issued the approval, it is valid in the whole EU. The toughest approval authority is German, and the approval is not given for a specific type of bulb, be it the H4 or the H7, but for the retrofit of that bulb in a specific car (headlight).
So the manufacturers are going for the quick hits, eg the cars with the biggest volumes. At the moment I have retrofitted my lowbeam headlights with (for my car approved) Osram H7 led bulbs and I’m very satisfied. The difference is impressive, and I’m hardly feeling the urge to use my highbeam when there is no oncoming traffic.
You can read some of the United States Department of Transportation’s statements on the subject here , here , here , and here. It should be noted that while these memos talk about HID kits the same rules still apply to LED kits see here. The same issues with LED are still present. You have to physically match the light emission of a wound filament with a square LED for the headlight optics to work correctly. That isn’t physically possible. This isn’t like a table lamp you can swap the bulbs on. This is more like you putting on someone else’s glasses.
You’re both incorrect. Philips and Osram have regional approvals. They apply to a specific retrofit model in a specific car reflector and more importantly they’re not valid within the rest of the EU - homologation is but what Philips and Osram are getting is just a local approval/certificate. They’re strictly country dependent (as for now mostly in Germany and a little bit in Austria), if you live in France it’s illegal to use them, if you live in Germany you can use them (if your car is certified) but you cannot drive outside the country otherwise you’ll be fined.
Do you have some sources for that info?
Several months ago I talked with a former Philips manager who worked on their car bulbs. We discussed legalese briefly and what I got from there was that they had EU-wide approval. But maybe I got it wrong. And I can’t find evidence of it being either way quickly.
ADDED: a longer search confirmed, polish Osram and Philips website both state that their LED bulbs don’t have ECE approval. That’s a bummer.
My bad, apologies for that. I was right about the cars, if approved by one of the national institutes, it is approved for all countries in the EU (and of the EFTA). But when it is about carparts: these must be approved by any country you want to sell them.
Just another fine example of the advantages for us common people of having an EU. And for me: I leave the retrofit ledbulbs just where they are until it’s time for my next MOT. Test by consumer organisations (ADAC & ANWB) have proven that ledbulbs offer more visibility for the driver and less blinding for the oncoming traffic.
Guys. I would say Just do it. There are guys with modded HID lights out there which blinding everybody on the street. So if they manage to pass yearly Car inspection test without any fines I certainly refuse to be worried about LED bulb.
Even if car inspector decides that you have illegal stuff he will just warn you to replace it (and then you replace it with halogen H7 bulb) and when you replace it and pass the inspection put freaking LED bulb inside afterwards
I used my BLF and modding experience and my logic (no matter for youtube reviews) and I ordered this type of LED bulb link:
Why I have choosen this?
Well it is obvious choice since this is the most similar to our flashlight system.
It has active fan cooling with 20 or 16mm DTP board( I don’t know this data) with single quad Osram emitter that is projecting beam into real 360 degree quartz crystal tube and that should evenly spread light in a car reflector for same beam pattern as halogen H7 bulb but with much better and brighter 6000k light.
One emitter on round DTP board(and cooling fan beneath ) is better solution than 2 emitters on those 2 sided square DTP boards, or better than other 360 degrees light I saw with 10 or more emitters on very top of DTP board.
I think it could be modded if needed to , and if I will not be happy how it will perform in a car I will mode my old my old Microfire Warrior HiD with it
Look round DTP MCPCB with Osram inside :
I am sure there are guys here who think this could actually have modding potential
Ordered and on Slow boat from China so we will see
Unless the inspection will tell you that you failed, you have to replace the bulb and come again (and pay again).
Unless police is going to notice that you have blue light coming out of a classic reflector which means wrong light source. Alternatively during routine control (or if you’ll get a ticket) they may notice that the homologation print on the reflector says “H” which means halogen.
Unless you get into car accident (hopefully not!) and bulbs will be one of the first things that’s getting checked by the police or insurance appraise and then you’re screwed - you’re automatically guilty (I was blinded by him officer!) and you’ll have to pay for the repairs of both cars.
About the bulbs you chose - you made wrong decision. Quoting marketing BS doesn’t help. Light intensity at the end of the “magic crystal” is pretty low, you can expect reduced range compared to halogen bulb. What you’ll get is blueish light with low CRI that may get you in trouble.
If inspection tell that you failed you return with H7 halogen bulb. Pass inspection, and after that put LED inside again! You don’t have to pay single penny for additional inspection if you failed. You have 7-15 days deadline to repeat inspection.
I will pass inspection with LED bulb i am 100% convinced in that.
Now question for you:
How can police officer detect and determine what type of bulb do I have and what type of reflector do I use in a car? Police officers has smarter stuff to do and they don’t care for that.
There is no such thing as Homologation print on my reflector and even if there it is somewhere “beneath” Police officer can’t disassemble that without an warrant. 3. Police never checks freaking lights when car accident happens:
First thing in a car accident situation:
- If there is no medical assistance and fireman they help to people
- They secure place of an accident and call necessary services
- Collect all necessary data from people involved in a car accident
- Do alcotest and Drug test of participants
Finally they do car crash report
Also you are pretty wrong with “magic crystal” too. Light should be much intense with extended range but I will have to test this. So far as you can see you have aliexpress reviews so people using that are not dumb either. They all report great improvement over halogen bulbs.
Can’t speak for anywhere else, but here in NYC these douchebags ride around with those idiotic 2×N lightbars right across the grille blinding everyone in sight, and never get pulled over, at least not for that. If a cop wants a pretext to pull you over, he certainly can, like, “I notice your lights seem ‘odd’, and I suspect they’re non-compliant, so…”, and then run your plates, reg, lic, etc. And then let you be on your way if you’re cool or toss a few tickets at you if you’re an ass.
That’s why practically everything else (turn, backup, markers, etc.) I long ago converted to LED, as they’re nigh-impossible to tell, but headlights are THE most visible and glaring (haha) light-source on the car, and even Andrea Bocelli would be able to tell if they’re Angry Blue and obviously not what came with the car from the OEM.
For lowbeams, you might be able to do the H-whatever to H-somethingelse conversion (snip tab, file notch, etc.) to get double the lemons for only 10W more, and still have the same exact filament placement., but at the expense of bulb-life.
For ages in my old car, I was running 90W/130W H4s that were still very well-behaved, and I never ever got flashed, let alone pulled over. And the capsules came with that blue film that I just scraped off anyway, so they had the legit look of real hotwire bulbs.
