There were no xenons in B8 Passat and they will suspect because each reflector type in this model looks and operate differently.
Those markings are mandatory on every legal reflector.
HIDs make more light but they’re much easier to focus. LEDs produce different beam pattern which means they focus differently than regular bulbs. Usually it ends up with increased glare and shorter range especially in classic reflectors.
You will see more light right in front of the car but at the cost of shorter range.
Please lift the bonnet (hood). It might be on the “edge” of the light housing. Which is nice of course, because you need some form of probable cause to lift the bonnet.
I drive a 2015 Subaru with factory HIDs and find them much less bright than the newer model cars that sport the latest OEM LED headlights! Given the wild disparity of bright white LED and yellow halogens seen on the roads, I would think it unlikely that you would be pulled over with 6000K LED retrofits that were aimed properly! I have been driving my 2009 Kawaski Concours with twin retrofitted LED bulbs for several years, never got stopped except the time I was speeding way over the limit. nary a mention of my headlamps!
phantom23, Man you are exaggerating in everything! And again wrong… How something will focus depends on reflector/optics and bulb design! You can’t claim stupid things like “HID focuses easier” this is not true and quite opposite from that you wrote! HID kit ends up with increased glare in classic reflector headlights while LED bulb should have beam pattern that depends on LED bulb design(as you see you have at least 5 different types of LED bulb design) and it is surely capable of giving even beam pattern with better looking less intense light than HID.
No one will ever suspect. And even if they “suspect” What they should suspect? This is no felony!
So question for you: Did you test any of LED “bulb” design in your car? If you did please tell us which car LED bulbs you used? If you did I could actually accept your opinion but if you did not use them I simply can’t accept opinion which is not empirically proved. That kind of opinion means nothing…
I opened this thread to see if there is any BLF member that could actually help me to choose car LED bulb and to help other BLF members in their choice. You are obviously not one of them
DOMEHAVEN,
Thanks on experience with Police and LED. It is good to know that LED can be brighter than HID( I would be happy camper if it will be brighter than halogen).
About “retrofits that is unlikely aimed properly”. I believe that it can focus same like Halogen if not better. Click my mentioned link for ordered light. Look at the photos people posted. Beam looks even and perfectly centered with my ordered model of LED bulb. How it will behave in my car reflector I still don’t know until I try.
HID focuses easier because the very light source (an electric arc that’s a few mm long) is optically close to the filament in the regular bulb. It does produce more glare simply because it’s much brighter. 100W H7 bulb will also produce more glare for the same reason.
Meanwhile with LEDs they are all optically different from halogen bulbs, they have higher surface with lower surface intensity, they have different shape etc. Side effects are very reflector dependant, some reflectors will focus better than others, some will produce more artefacts etc. Classic reflectors are much worse at dealing with LED retrofits than projector lenses.
My opinion based on 1 bulb in one reflector will mean much less than multiple tests you can find around the internet.
“Suspecting” is not a felony but it’s enough to stop you and/or take a loot. “HC” on the reflector and you will end up with a ticket.
Dom said that factory lenses can be brighter than retrofit HIDs. It’s very likely.
This is thread where we strive to find the most suitable or should I say the best possible LED bulb for our car. We are on BLF after all. Here we(not me but there is certainly someone who knows something about that) should know more about that than internet and youtubers right?
Attitude where LED is not suitable as a retrofit or this is better than that, or like LED bulb is big problem for Law Enforcement Officers that will skin us alive will not lead us to proper car LED bulb selection.
Everybody can decide on their own whether to put LED bulb or not. In my case I have 0(zero) risk of doing that.
Where Dom mentioned retrofitted HIDs? He said that factory HID is less bright than OEM Factory LED. So LED can be brighter after all…
So to be back on topic look at the pics of costumers that bought same Car “Magic Crystal” LED:
The fact that we’re on BLF doesn’t mean we should encourage dangerous behaviour.
As for the pictures - glare galore with LED, the second picture is terryfying - there’s no cutoff line, just one massive light glow illuminating trees and everything around. That’s dangerous.
Someone has Xenon or HID and blinds everybody on a road and on the other hand you have ability to install something like in above mentioned photo (which is still a lot weaker than factory Xenon or HID). That could be called as “equalization”.
phantom23
I still think that you are exaggerating about safety. Above are randomly picked photos and I don’t know whether they are high or low beam. They look perfectly fine to my eyes without any blindspots as I could see with plenty of other 2 sided LED bulbs.
Here is another photo of “Magic Crystal” in newer Škoda Octavia:
Phantom in one of his post stated that “Magic Crystal” will be less bright than classic halogen. Well it surely does not look like that :laughing:
Really, really looking forward for that. The last pic with Skoda is something what I can expect in my car since they are within same VW VAG group (VW,Skoda, Seat, Audi). By judging that picture it looks as it should look and can pass Car inspection without any problem.
I guess phantom23 could also find errors in that beam pattern? :laughing:
it does not matter how it is aimed, “fake” leds or hid are clearly distinguishable. it is very easy to spot them. they do blind oncoming traffic as well as those in front of you. all true, but can we please NOT turn into “the other” forum
as far as laws: Federal Motor Vehicle Safety Standard 108 (FMVSS 108) regulates all automotive lighting, signalling and reflective devices in the United States.
it is not the brightest you need to look for, but the one that works best with your headlight, which kit that is… that is only possible to answer if someone who had tried several of them on exact car as yours. which will not be easy to find, otherwise you’ll have to try few and see how they work. or more like , if you like how they work, cuz none will worked properly with optics that were not designed for the light source. but if you insist of swapping, this will be how you find the best for you.
several years ago i read that certain kind of leds worked great, so i got those exact lights, installed them, and they worked worse than what i had before. so what is good in one man’s opinion, is unacceptable for another guy
I picked best two costumer photos I found on Aliexpress regarding “Magic Crystal LED” bulb (it can be bought under 4 different retailers, different OEM but they are same)
Projector headlights or optics in close valley (Sharp borders of aspheric lenses are clearly seen):
Reflector headlights:
They both look like short light beam? If I’ll judge photos they both look perfectly fine. Since I am aspherics fan first one looks much better with sharper borders but I have reflector headlights so mine will probably look like bottom one with wider spread…
alpg88,
This one seems like universal fit as you can see by photos.
yes, they will all physically fit, but they will all work different with different optics, and since the optic was not build for those, the beam quality will differ from car to car.
HID retrofit can blind others due to sheer brightness. LEDs are dimmer but it doesn’t mean there’s less glare - due to different optical characteristics and artifacts there can be much more glare! Like in your picture!
[quote=luminarium iaculator]
Your eyes are wrong, they look horrible! There are tonnes of glare in both puctires.
Yes, who cares about safety, right? There are nowhere near accidents on the roads right now, we should die more!
I said they can provide shorter range as that’s usually the cse with LED retrofits.
Being in the same manufacturer group says NOTHING about the optical characteristics of the reflector.
That beam patters is horrible as well, there’s monstrous glare that illuminates entire house and a tree in front of it.
You will not pass the inspection for one more reason - those bulbs have fans and they’re pretty loud. Guy performing the inspection will spot it right away.
As I said some reflectors are more forgiving than others but it has to be a specific bulb-reflector combination, every single combo has to be certified separately.
You are mentioning glare. “Glare” or “useful spill” coming out of the reflector light is there. You can’t bypass natural halo effect of reflector headlight!
Considering that this on pictures is 6500k cold white tint of Osram LED it is not “Glary” at all.
You can always choose neutral or even warm LED tint for less glare so again I don’t see any problem with either type of beams on upper photos, and one more proof of LED superiority to Halogen bulbs, and the people who like halogens can choose LED bulb with warm tint
I drive a lot at night, you can spot the mods right away… usually so far out of adjustment and angry blue. I do wish for better headlights, but I will not blind the other driver like they blind me.
