Both, bit not necessarily an issue. It’s just the design choices that were made based on the judgement of those doing the work (Toykeeper and Hank).
If everything fits, RGB LED’s could be installed in the switch recess, and the existing outputs from the driver could be wired to the switch, probably even in parallel with front aux board. However, the D4 switch recess is pretty tight. Also, you would need a new PCB for the RGB switch LED’s versus single color.
If you want them to behave different than the front aux LED’s currently do, such as only being illuminated for 5 seconds when the light is turned on, that requires a customized version of Anduril. Since it is open source, those inclined to learn Python can do it themselves. Otherwise it’s not likely to happen unless someone else with the knowledge how to do it puts the time into it.
Yes, it's the mode in which I always keep my AUX lights (edited Anduril with my own colors in only R to G spectrum)
But.. I always keep my Emisars with the AUX LED's Off.. because I'm usually of the "set and forget" mindset.
If the K1 has RGB switch Indicator LED's I can only assume that they are exactly what I'm after (hardware wise) just not in the right light. The K1 simply didn't had a front facing placement for the LED's because.. well, huge Al reflector and all.. But yep, all in all they're basically the regular D4's AUX LED's physically moved under the switch and as such, they should behave the same exact way as those, so, yes, that's a definite improvement. The only thing left would be to have the R to G colors for batt. status and the B color for.. indicating stuff.. And yep, I believe it's just a software matter in that light.
Thing is, I use to sit all my lights on their front bezel (that reminds me why I love SS crenelated bezels.. ) and as such, I would not really see the AUX lights even in the dark, especially with the D4's smooth bezels.
I just got used to do it this way as the bezel is the most wide part of the body as a general rule, many times is scratch resistant and another general rule is that many lights will roll if set on a side.. So, to enforce my "set and forget" rule, if the majority of lights will roll on a side, will more likely scratch on a side, etc. etc. etc. I found the best consensus to be front end = light comes out, (and that is lots of light, dangerous light to one's retina, thus keep away from view - And yes, if anyone has to ask, I did, accidentally.. blasted these things right into my eyes.. one too many times :| ) set the light on this side, (as it's the most stable and also protects the lens) and side switch = interact & indicate (tail stand, on a side, on the bezel, regardless which is it, the light coming from it will never be potentially completely blocked)
K9.3 is the only 2-channel model from Hank that has FET enabled. The others all have FET drive disabled in their firmware, but it can be re-enabled (on channel 1 only) via a firmware reflash.
All 2-channel hanklights (except K9.3) are 9A per channel with most emitters. If you choose 219B’s on one channel, that channel will be 5A. If you choose E21A’s, each channel will be 3.8A (because you have to get E21A’s on both channels).
K9.3 is the exception, because it comes with 9A+FET drive on channel 1 and 5A drive on channel 2, unless you get E21A’s on channel 1, then it’s limited to 9A on channel 1.
There is two options for the firmware update one says tintramp fet and the other just says tintramp. do you know which one is for which my light mine has both 219 B on both channels?
It ensables the FET (direct-drive turbo) on CH1. It probably shouldn’t be used though, that’s probably too much power for just two LEDs. If you have the dual-channel DT8, this FET-enabled firmware will be a good match that will allow for higher output on turbo.
Yeah, you have to be very careful with battery selection to use FET on two Leds. None of the available Leds in the D4 or D4s can take 15A individually (the amount a good battery will deliver with direct drive). I had hoped the FET could be used with W2s but it’s just too much current. Also, W2 output goes down after 8-9A even if it doesn’t burn out. FET for four W2s in the DT8 is perfect though (about 7.5A each).
In general terms, this post is a must read. When I was first getting into the “performance” flashlight game, I had no concept of the relationship between power source, driver, emitter, and the consequences of overdriving LED’s. This coupled with the lack of published acceptable parameters from manufacturers regarding cell compatibility nearly cost me a couple of lights due to excessive cell amperage (ie, poorly researched/ chosen cells). I’m not a ‘modder’, so chances are those lights would be in a landfill if I hadn’t gotten some sage advice…mostly from the good and knowledgeable folks here at BLF. So thanks for elaborating on this nuance. Good stuff.
The Leds are typically wired in parallel so the current is divided as you say. The 2 channel drivers that Hank uses are 9A for each channel. However, my discussion is about the firmware which enables FET. This can be dangerous to flash on a light unless you know what you’re doing.
For the DT8 with 2 channels, W1 or W2 will give more throw? In principle it should be the W1 because of the higher output/area but it also depends on the optics and there’s no info about this in the site.
It may depend on the optics. The divergence of the output beam is smaller but the increased output might overcome this effect. I ask because I’ve seen a situation where changing W1 for W2 actually increased throw: Thrunite Catapult Mini modded by Vinh, see Thrunite CatVN Mini - Most Compact TIR Thrower R - Sky Lumen. The numbers may not be that precise but were measured in the same setup so comparison is possible.
Well, it's 520L, 130Kcd for the W1 - VS - 1100L, 157Kcd for the W2.. so it's just increasing the power output (and power drain) to "match the brightness/area..
Also, the W1 is closer to the more power efficiency per output/area @520L compared to the W2 @1100L, so.. all in all, in the same optic, at same power / output/area the W1 will always have the advantage
