Fujitsu, on the other hand, currently owns the factory. This single factor is the only one capable of producing these low self-discharge nickel-metal hydride batteries, and it supplies many brands such as Amazon, Fujitsu, Panasonic, andā¦ IKEA.
The white LADDA batteries were not that good long term.
I have empirical data from tests which proves that LADDA (At least the NiMh AAA did not do so well long term.
They tend to lose their capacity more so than comparable NiMh rechargables over time. Consistently.
Itās not a great difference, I would say they lose 20% more of their capacity than some comparable NiMh AAAās.
Most likely due to their chemical composition. I have a plethora of LADDAās and I compare them with a number of other brands through a rather
exhausting set of tests.
That said, the batteries they are being compared to are āCOMPARABLEāā¦.meaning, they are from the same circa dates as the Ladda.
I cannot speak for later batteries from LADDA (Ikea) or from competitive brands.
Bottom lineā¦ā¦itās not a great lossā¦and there are BETTER substitutes in the same price range. Some of which would surprise most people I suspect.
I have 3 of those IQ338XLs along with my MC3000ās and various other chargers / discharge testers.
If you want 4 different results from any of those batteries, just repeat the test in a different slot.
BTW, 127milliohms is as high as the IQ338XL will read, regardless of the batteries actual IR
I canāt.
Since 2017 Iāve bought hundreds and hundreds of batteries and havenāt needed to buy new NiMh batteries lately. In more than a year actually.
Iām just using up the old stock until the capacities are too low to continue using them.
The batteries that were ābestā last year may not be this year. Factories change. Materials change, manufacturing processes change etc etc.
I can only speak for the batteries Iāve had and used / tested over the last 4 years.
IKEA still sells the 2450 and now the 1900. Wrapper says Japan, imported through IKEA Mexico. Wrapper is now brown. Iāve been wanted ikea priced rewrapped regular eneloops and it appears this is it.
Our local IKEA here in Germany still has plenty of those made in Japan.
AA in Pro (2450 mAh, 6,99 Euro / 4pc) and standard (1900 mAh, 3,99 Euro / 4pc ) and AAA in standard (750 mAh, 3,99 Euro / 4pc).
Pretty cheap. I will post some pictures later.
If I should send some to anybody, anywhere, let me know ! (At cost price + shipping.)
It's just the white ones, and the tan/brown ones that stopped selling in most places. Still interesting to see that you guys still have the white ones.
Those grey 2450 should be the same as the white 2450
Thanks. I may just stick with Eneloops then. I was also pretty amazed to find that the Eneloop Pro has 500 charge cycles and a nominal 24% increase in capacity. Also, they self-discharge faster and are more prone to deep discharge.
As stated already, the IKEA package states less charge-cycles than Panasonic does on their Eneloop packages.
But I would assume the batteries sold via IKEA are technically the same as those sold by Panasonic directly ?
Or has anybody found different results via testing ?
Edit: the test-results from lygte-info.dk look very similar for the eneloops and the Ladda.
Whatās there to be sad about? The title to this thread is misleading. Laddas are very much alive and kicking. Ikeda have not killed them off. At the very least they changed the colour of the wrapper and packaging. They might have possibly changed the chemistry too but I doubt it and itās only speculation and internet guesses. Personally I prefer the newer wrapper and believe it is just a different colour lipstick on the same pig.
Over the past few months Iāve been using the old white label Ladda against the newer label and canāt tell any difference.
In my part of the world, by far the Laddas are the best value. If available I still prefer the original Eneloops but those are expensive and hard to come by. Typically $3.50+ Cdn for 1 Eneloop vs $4.99 Cdn for 4 pack of Ladda (AA). I bought a bunch of Eneloops recently when Costco.ca had a sale on those. Unfortunately Eneloops no longer appears on Costco.ca and Iām hoping that this is only a temporary thing. Energizer rechargeable are Made in Japan and are readily available here around $20 Cdn/4 pack. Duracell rechargeable are the same price as the Energizers but are made in China.
