I purchased two SC31 Pro’s back in August of 2020. One of them is still 100% OK as good as new, except for some normal wear of the anodization. The other one is still working OK, but the button LED is dead.
Recently I purchased SC21 Pro. This is a great little flashlight. It’s still Andúril 1 though. I have a plan to Reflash Andúril 2.0 .
After years of using SC31 Pro my main preferences for EDC flashlight : Andúril, button-LED, magnetic tail cap. And integrated USB-C charging.
I also have a Wurkkos TS10, Andúril 2.0 .
It doesn’t have button-LED but the Aux LEDs are great as locator. And the tail switch is so fun and tactile.
Thanks Sofirn and Wurkkos for your great flashlights.
I also have a Sofirn HS10 , a fun little head lamp. I really like the integrated USB-C charging.
Is the new SC31 Pro better than the old version?
(with Andúril 2.0, attiny1616, exposed flashing pad)
Is it compatible with USB-C to USB-C charging? The old one can only be charged with USB-A to USB-C.
I was looking at the SC31T, which is just $13 USD (with battery), but for $5 USD more to get Anduril in the SC31 Pro? No brainer, IMHO. Unless of course, you want a non-Anduril flashlight for a muggle.
I will use a Carclo 105xx triple optic which is the same optic the FW3A uses.
However the MCPCB is a 20mm triple that is custom machined smaller to fit inside the SC31 Pro.
I will also be using a custom machined copper spacer.
Yes, others have done this before.
Here’s some pictures of one that I did for a buddy of mine(he stripped and polished it) I added the triple and added aux:
