Nice mod jon_slider!
That slight donut hole would bug me until I tried everything to remove it. Have you thought about frosting the top of the TIR lens with some sandpaper?
yes,
so I tested a bit of tape over the center of the Tir,
the shadow got worse
not the right solution
am considering a test w LH351d 2700k 9050
maybe the Tir will like that die size better…
Interesting. I guess that’s what makes modding fun (at least for me), you never know how things are going to turn out until the end. And if it doesn’t work out the way you intended, seems there’s always another option.
If you do find the right optic please let me know because as much as I like these little guys, they have been sitting on a shelf collecting dust because as my eyes have gotten older I just can’t stand the cold white light of death they emit.
Olight makes nice hosts… I sold all mine when I discovered High CRI
modding the Ti SMini was a very forceful process… Im glad the host survived the hammering… There has got to be a better tool… LOL
They are tuff lights !
smini nw is my original unit . so good .
Im much happier with the Nichia, on the left:
Nice tint on the left!
Looks great.
I should go mod my old Olights.
:+1: for tint improvement. I think the hassle of open ’er up was worth it.
As for the dark spot, could be emitter sitting too high into the optic. I recall the original MCPCB being thinner than off-the-shelf 1.6mm and required adjusting.
I tried to replicate the photo taken at 4 ft from wall and my Ti S-mini SW30K SW45K doesn’t have dark spot.
I ground down a utility blade to create a gradule thicker bevel. The problem I had when trying to remove the bezel is the sharpest part of the blade hits the inside of the bezel ring then stops. This only moves the bezel off a small amount. By increasing the size of the start of the bevel each time the bezel moves further and further out each time hammered down around the bezel ring. By the time you get all the way to the end of your ground down bevel, the bezel should come off. Start at the sharpest end drving it down until it stops then move about 1/4 the way down the blade and go around the bezel again and then move another 1/4 down the blade etc….etc…
good idea! thanks
here is another good one:
pic is a link
congrats… looks great
here are the two mcpcb, stock on right:
since the Tir sits on the mcpcb, in both cases (unless Im mistaken)…
the LED heights should be the same… but the retaining ring sits higher when pressing on the stack with the thicker mcpcb
however, please do tell what adjustments you made…
your beam looks clean
In order to minimize re-focus issues when modding I usually try to duplicate LED surface height in hopes duplicating original optics/reflectors geometry. Similar to approach illustrated in this old photo where I was swapping a first gen Luxeon emitter (or course in that case I was stacking MCPCB’s for added height.)
In the case of the S-Mini, I thinned the 3535 MCPCB before mounting the 219B. I’ve tried thinning PCB’s with pre-mounted emitters and the failure rate is not worth the trouble.
Also, the S-mini’s are designed with no wiggle room, the outter gold retaining ring might not seat flat otherwise.
Thanks. I look forward to your success!
thanks for your thoughts
since I did not thin the mcpcb, the retaining ring does not seat flat, but afaict, you just got lucky, cause we are both resting the stock Tir on the mcpcb, around the 219b…
IF the problem is that my 219b sits too high into the xm-l2 Tir, then a plastic centering ring could be used to lift the Tir… I might test that if I open the light again… I agree the bezel ring would sit too high, again… but my first mystery to solve, is how you got a good beam, and I did not, (yet). And I think the height of the LED can definitely play a role…
thanks for the brainstorming
That would be my first guess as well. When I swapped the LED in my Baton 1 to a 219 C I used one that I pulled from a Convoy T2. The new PCB was the same thickness as the stock.
In another mod I tried shaving down the base of the TIR to fix a height issue with bezel clearance. You might have some leeway to do this but it could make the focus worse. Considering you probably only have one stock TIR, maybe try to adjust your PCB thickness first. I’ve had luck sanding them down on a belt sander but it’s a pain and hard to keep flat.
Im not concerned with the gap at the bezel
and Im not understanding how thinning the mcpcb, would alter the height of the 219b LED in the Tir… since the bezel presses on the Tir, which presses on the mcpcb… The LED height in the Tir stays the same when thinning the mcpcb…
So I see no point in taking the light apart to change mcpcb thickness
maybe there are LED height factors, in relation to the Tir, that are altered by thinning the mcpcb, that Im not understanding?
Sorry, I didn’t explain that thought very well. The big variable you changed with respect to focusing the TIR was the LED (smaller die, different emitting properties, etc.). The only variable you can change now is the LED height in the TIR. It’s always trial and error for me. If you find you need the LED to sit lower then you’d need a shim to lift the TIR off the PCB and possibly the PCB itself to be thinner or the bezel may not go back on / gap may be too big.
thanks, that all makes sense
if I understand correctly, you have a 219b with the stock Tir sitting over the LED, and resting on the mcpcb…
and I have exactly the same setup… but your beam is better
We agree that thinning the mcpcb only alters the depth the bezel can be pressed, and does not change the heigh of the LED in the Tir…
so I dont know why your beam is better, but it is… congrats!
Jon I’m pretty sure I didn’t keep the original spacer, I don’t remember because I did the mod 2 yrs ago. The S-mini originally would have had a XM-L 5050 opening whereas the Nichia 3535 would have been smaller requiring a different spacer. As you say I was probably just lucky that it worked out.
