Driver: 12 group mode, maximum current output 8000mA, internal temperature protection management
No strobe can be seen in any mode, and there is temperature management.
It can control the temperature of the flashlight not to exceed 55 degrees Celsius. If the temperature of the flashlight is lower than 55 degrees Celsius, it will output full current. If the temperature is higher than 55 degrees Celsius, it will continuously adjust the current so that the flashlight will not overheat
12 groups: Click the button to turn the flashlight on / off, touch the button to select the mode. If the flashlight is turned on, tap the switch 20 times quickly to enter the configuration mode. (In a visual interface, as long as you click on an option, it means that the option is selected. The flashlight has no visual interface. It flashes to represent an option and "touch the button in the flashing process" means to select the option.)
Option 1 (normal flash 1 time + buzz flash): touch the switch to enter the sub-option to select the mode group. If the user has no operation, the configuration mode will enter option 2.
Suboption 1.1 (normal flash 1 time): touch the switch to select mode group 1 (0.1%, 1%, 10%, 35%, 100%, strobe, bicycle, battery check)
Suboption 1.2 (normal flash 2 times): tap the button to select mode group 2 (0.1%, 1%, 10%, 35%, 100%)
Suboption 1.3 (normal flash 3 times): tap the button to select mode group 3 (100%, 35%, 10%, 1%, 0.1%)
Suboption 1.4 (normal flash 4 times): touch the switch to select the mode group 4 (1%, 20%, 100%, strobe, bicycle, battery check, SOS)
Suboption 1.5 (normal flash 5 times): tap the button to select the mode group 5 (1%, 20%, 100%)
Suboption 1.6 (normal flash 6 times): tap the button to select the mode group 6 (100%, 20%, 1%)
Suboption 1.7 (normal flash 7 times): tap the button to select the mode group 7 (0.1%, 1%, 10%, 50%, strobe, cycling , battery check, SOS)
Suboption 1.8 (normal flash 8 times): tap the button to select the mode group 8 (0.1%, 1%, 10%, 50%)
Suboption 1.9 (normal flash 9 times): tap the button to select the mode group 9 (50%, 10%, 1%, 0.1%)
Suboption 1.10 (normal flash 10 times): tap the button to select the mode group 10 (1%, 10%, 35%, 100%)
Suboption 1.11 (normal flash 11 times): tap the button to select the mode group 11 (100%, 20%, strobe)
Suboption 1.12 (normal flash 12 times): tap the button to select the mode group 12 (only 100%)
Option 2 (normal flash 2 times + buzz flash): touch the switch to activate or deactivate the memory mode. If the user has no operation, the flashlight will enter the last mode
Yes, only orders over $20 are free shipping now. The shipping cost increased dramatically these years, we have to set the minimum for the free shipping. Hope you can understand.
authentic / 8*Cree XHP50.3 HI LEDs / 7-mode / 1160m throw / 336800cd / 3*21700 / USB charging / IP68 / fan powered heat shield
IMALENT RS50 is a rechargeable searching LED flashlight with a compact size that blasts a max output of 20,000 lumens and a max beam distance of 1160 meters. The amount of light that the IMALENT RS50 flashlight emits is truly remarkable, a wide beam angle and strobe function are quite ideal for Search and Rescue with eight pieces of American Cree XHP50.3 HI LEDs.
Extremely small for a flashlight with this much power, with the fan-powered heat shield and built-in two heat release fans, this flashlight can keep the body temperature at about 40 degrees, which makes it the perfect tool for exploring, searching, and rescue. Once you see the raw power of a 20,000 lumens flashlight, you will never feel troubled at night adventures, such as searching, caving, patrolling, etc.
Ultra-long throw distance flashlight
Utilizes eight pieces of American Cree XHP50.3 HI LEDs. The lifespan is up to50,000 hours with a maximum output of 20,000lumens.
Instant turbo output by double-pressing the side power switch button while triple pressing the side power switch button, can get the lowest output.
High efficient circuit, can be constantly on at 6,500 lumens.
Built-in thermal control module, and equipped with a fan-powered heat shield, it will automatically adjust the brightness output according to the working state and outer temperature, keep using comfortably.
Aerospace-grade aluminum alloy body, wear-resistant Type III hard-anodized surface treatment.
The fan-powered heat shield has a charging interface: Users can charge the flashlight and fans battery directly without removing the shield.
Head diameter: 74mm
Tube diameter: 51mm
Peak beam intensity: 336800cd
Impact resistance: 1m
Waterproof: IP68 (Submersible to 2m)
Cooling time: 1 Hour 45 Minutes
Charging time of fan-powered heat shield: 2 Hours
Battery capacity of fan-powered heat shield: 1000mAh
Controller: Indoor temperature protection management
Driver Instructions:
Modes: 0.1% –3% –30% –100%
Its biggest advantage is that you cannot see frequency in any mode, and there is a temperature control.
You can control the flashlight temperature not higher than 55 degrees Celsius. If the temperature of the flashlight is lower than 55 degrees Celsius, it will output full current. If it is above 55 degrees Celsius, it will constantly adjust the current so that the flashlight does not overheat.
New Arrival! Klarus XT21X Pro 4400LM 6500K LED Flashlight
authentic / Cree XHP70.2 LED / 7-mode / 336m throw / 19506cd / 1*21700/1*18650 / USB-C charging / IPX8 / power bank function / window breaker
Head diameter: 41mm
Tube diameter: 29.2mm
Waterproof: IPX8 (submersible to 2m)
Beam intensity: Max. 19506cd
Voltage: 2.8-4.2V
Cellphone charger mode: USB Type C to USB Type C charging compatible, from 0% to 100& on a single charge
Battery: 1*21700 (not included), the length of the battery is not more than 71mm
12 groups:
Click the switch to turn on / off the flashlight, touch the switch to select the mode
If the flashlight is on, tap the switch 20 times quickly to enter setup mode. (In a visual interface, whenever you click an option, it means that the option is selected. The flashlight has no visual interface. It blinks to represent an option, and “touch the switch in the process of blinking” means to select the option. )
Option 1 (normal-flash 1 time + buzz-flash): Touch the switch to enter the sub-option to select the mode group, if the user has no operation. Configuration mode will enter option 2.
Sub option 1.1 (normal-flash 1 time): Touch the switch to select mode group 1 (0.1, 1, 10, 35, 100%, strobe, beacon, battery check)
Sub option 1.2 (normal-flash 2 times): Tap the switch to select mode group 2 (0.1, 1, 10, 35, 100%)
Sub option 1.3 (normal-flash 3 times): Tap the switch to select the mode group 3 (100, 35, 10, 1, 0.1%)
Sub option 1.4 (normal-flash 4 times): Tap the switch to select mode group 4 (1, 20, 100%, strobe, beacon, check battery, SOS).
Sub option 1.5 (normal-flash 5 times): Tap the switch to select mode group 5 (1, 20, 100%).
Sub option 1.6 (normal-flash 6 times): Tap the switch to select mode group 6 (100, 20, 1%).
Sub option 1.7 (normal-flash 7 times): Tap the switch to select mode group 7 (0.1, 1, 10, 50, strobe, beacon, battery check, SOS).
Sub option 1.8 (normal-flash 8 times): Tap the switch to select mode group 8 (0.1, 1, 10, 50).
Sub option 1.9 (normal-flash 9 times): Tap the switch to select mode group 9 (50, 10, 1, 0.1).
Sub option 1.10 (normal-flash 10 times): Tap the switch to select mode group 10 (1, 10, 35, 100).
Sub option 1.11 (normal-flash 11 times): Tap the switch to select mode group 11 (100, 20, strobe).
Sub option 1.12 (normal-flash 12 times): Tap the switch to select mode group 12 (100% only).
Option 2 (normal-flash 2 times + buzz-flash): Tap the switch to activate the mode memory or inactive, if the user has no operation. The flashlight will enter the last mode.
W35A is lightweight throwing rifle rail tactical light. The white light beam can reach 653 yards! The light intensity is as high as 89,600 candelas!
The light head is only 32.5mm (1.28 inches) in diameter, short and powerful. There are 2 mounting holes on the body, Various types of rail mounts can be installed, Such as Weltool PM4. Therefore, the W35 series tactical lights can be installed on M-LOK or Picatinny, KeyMod, MIL-STD-1913, STANAG 2324, STANAG 4694, Weaver, and other types of tactical rails. Suitable for most AR rifles and short-barreled rifles or carbines.
IP67 protection standard, waterproof and dustproof, shock and vibration resistance. Tactical switch, can lightly press the switch to light up silently, or it can be locked to be always on.
Use suggestions:
After the glass lens of the light head is damaged, you can replace the spare lens by yourself, take out the battery, and press the light head down on rough and soft leather or fabric, such as mousepads, anti-skid pads, and twist the light body counterclockwise. Unscrew the bezel and take out the damaged lens and replace it with a new one, and then tighten the bezel clockwise. In addition to this situation, please do not disassemble other parts, otherwise, the warranty will be invalidated and the product may be damaged.
When this tactical light is on, the internal heat will be discharged in time, so it is normal to generate heat during use;
Please check and replace the O-ring regularly to maintain the waterproof rating.
Please check and lubricate the threads regularly with professional lubricant.
Clean the contact surfaces regularly to keep the flashlight in normal operation. If irregular strobe or failure to turn on occurs, the contact surfaces may be dirty and require cleaning by using alcohol cotton swabs.
This flashlight is not intended to be used as a diving light.
Do not aim the flashlight directly at the eyes. Keep out of the reach of children.
Specifications:
Light intensity: 89,600 candela
Battery: Use 1 USB rechargeable 18350 high drain lithium-ion battery (not included), (cannot use 2 lithium ion batteries or 2 lithium batteries).
Switch: Tactical tail switch, rated for 50,000 presses.
Battery over-discharge protection function
No PWM, no noise, and temperature control protection function
Weltool W5 LEP search flashlight throwing distance up to 2807 meters! The luminous flux is 699 lumens, and the beam intensity reaches 1,970,000 candela. It uses two 22500 or 22430 lithium-ion batteries. You can also purchase an extension tube and use two 21700 lithium-ion batteries to increase runtimes. High-quality temperature control driver chip, constant current drive and ensure that the flashlight will not overheat.
W5’s LEP light source has high energy density, and after passing through a special lens reflection system, it forms a dazzling beam of light. High and low brightness modes, side-press electronic switch, with battery indicator light, and lock function. W5 has almost no spill, suitable for field search, sea rescue, long-distance indication and other purposes.
Instructions:
First install the battery correctly.
The flashlight has a polarity protection function. If the battery is installed incorrectly, the flashlight will not be damaged, but it will not light up. Please check the battery in time.
After installing the battery, when it is not turned on, press the side switch once, the battery indicator on the switch turns on for 5 seconds and then automatically turns off (full battery: green light, low battery: red light, ultra-low battery: red light flashing)
Press the switch for a long time to turn on or off the flashlight. When the flashlight is turned on, the battery indicator will be on (full battery: green light, low battery: red light, automatically turned off after 5 seconds), and the red light will always flash when the battery is ultra-low. Short press the switch to switch the mode, the default is low light mode when the flashlight is turned on.
During use, if the battery power is low, the battery indicator will show a red light, and it will turn off after 5 seconds. When the battery is ultra-low, the indicator light will keep flashing. Before the battery power is exhausted, the main flashlight will flash to indicate, and then it will stop working at any time.
Switch lock and unlock function:
In the off state, press the switch more than 5 times to lock or unlock:
The main light flashes quickly 2 times to indicate that it is locked;
After unlocking, the main light will light up in low light mode.
After being locked, the flashlight will memorize the locked state. At this time, it needs to be unlocked when the battery is replaced and used again.
Specifications:
Reflective system: Double convex lens
Beam divergence angle: 1.8’
Light source: Special LEP module, wavelength 400-700nm, lifespan is about 10,000 hours
Switch: Side-press electronic switch with lock function to prevent accidental touch
High efficiency constant current drive circuit, no noise and no PWM
Temperature control protection: When the temperature of the flashlight is too high, the flashlight will automatically reduce the brightness to prevent overheating
Low voltage reminder function (battery indicator + main light flashing reminder)
With battery over-discharge protection
Wear-resistant thread
Pass the 1-meter drop test
Double O-ring waterproof, protection level can reach IP67
Head diameter: 44.5mm
Tube diameter: 25.2mm
Controller instructions:
Now we offer another controller version, which has 4 simple modes to switch, which is very suitable for normal users.
Modes: 0.1–3–30–100 (the maximum current output is 4800mA).
Its biggest advantage is that you can not see frequency in any mode and there is temperature control.
You can control the flashlight. The temperature should not exceed 55 degrees Celsius. If the temperature of the flashlight is lower than 55 degrees Celsius, it will output full current. If it is higher than 55 degrees Celsius, it will constantly adjust the current so that the flashlight does not overheat.
GT Nano is the 10180 battery version in the classic BLF GT family. It is a super tiny yet ultra throw keychain flashlight. With a length of 52.5mm and 17g in weight, this tiny flashlight can burst into a max of up to 450 lumens output and up to 300 meters amazing throw. The included 10180 Li-ion battery and a Micro USB charger allow the flashlight ready to use and easy to be charged. Defaulted smooth ramping UI, optional advance settings, IPX8 waterproof, GT Nano is a must-have for your EDC collection.
Specifications:
Firmware: Tom E’s open-source GPL NarsilM v1.3 adapted by Texas_Ace
User interface:
By default the GT Nano is set to use the very intuitive Narsil smooth RAMPING UI. Instant access to a 2.5A TURBO mode is also provided.
A more conventional discrete level MODE-SET UI is available as an alternative. Any one of 12 pre-defined mode-sets can be selected.
MOMENTARY mode is useful for signaling purposes or rapidly/briefly lighting up targets.Driver: Texas Avenger FET driver
Button: Tactile with back-lit rubber boot
Reflector diameter: 20.8mm
Waterproof: IPX8 (Submersible to 2m)
Head diameter: 24mm
Light intensity: 23400kcd
IMALENT MS03 LED Flashlight
authentic / 3*Cree XHP70.2 / 6-mode / 13000LM / pure white / 1*21700 / USB-C rechargeable / lanyard / IPX8 waterproof (2m underwater)
Enter coupon code MAP on the shopping cart page to get $43.25 off
Voltage: 3.7-4.2V
Head diameter: 36mm
Tube diameter: 27mm
Built-in thermal control module will automatically adjust the brightness output according to the working state and outer temperature.
