That sounds like the issue that’s been driving me crazy with my FW1A. Any mode above level 130, no matter what I do with thermal calibration and thermal limit, ramps down after about 6 seconds. The exception is turbo which works as I expect.
I just tried doing the “dance” chops728 described and it did work for me. Is that how it works for everyone out of the box? This is the first I’ve heard anyone else mention it. Would a different firmware version fix the issue? I’m trying to like this light. I just did the reflector mod and the switch mod will be next, but I’m not happy with the output at level 130 and turbo isn’t always practical.
I can no longer check the battery voltage with 3 clicks, put it into turbo with a double click or lock it with 4 clicks. Is there a solution to these problems?
Have you removed and reinstalled the head? That combined with making sure the tail is tight before reinstalling the head has always reset any odd behavior that has occured with mine.
That was it, muggle mode. 6 clicks solved the problem. I accidentally dropped the flashlight from 1 meter and wondered if something had cracked. Luckily it was not. Thank you!
Cool — Rayoui beat me to it; was going to suggest the same. The internal battery tube enabling the circuit is a bit finicky. I have an FW3A in 18350 format. Was working just fine. I dropped it on a hardwood floor while off and the light turns on, then rapidly kicks into ramping mode up to turbo. Button control was unresponsive. I had to unscrew both the head & tail to get the tube reseated properly for normal function. Never saw one “fall into muggle mode” like that, but who knows how sensitive is the hardware to jostling. This is why I consider the FW3A an enthusiast flashlight and for an emergency situation, I’d avoid any flashlight with an inner battery tube for connectivity… with the exception of a NovaTac that uses a reliable compression spring.
On my FW3A, the inner tube connection ring on the driver board is very close to the retention ring holding it in place. Almost touching it. Maybe something happened there when it hit the floor.
OK, I’m back to frustration mode on the FW3A. The original with 18650 is no problem. I swap batteries with no issues. I always take off the head for access.
On my FW3A that has an 18350 body, I’m running into problems again. Screw on both ends tight. There’s one quick flash in the final screw-down. And then the switch is unusable. Repeat the screw down and occasionally the light ramps up automatically and then either turns off (and stays off) or stays on—switch unusable.
This one has the tailcap parts secured by a retaining ring. All seems tight. Driver is tight. Wiped down the battery tube ends. Attach tail cap first, slide in battery, attach head. Same as described above.
I kept loosening and then tightening. Sometimes it would auto-ramp and stay on high, or it wouldn’t do a thing. And then… finally, I have control. Switch works. I set it down, head first. A moderate tap on the head. It auto ramped again.
Next, I took some snap-ring pliers and loosened the driver retainer, then re-tightened it. THAT seemed to do the trick. Rapped the light on a desk to test of instability. All seems solid now. But what really bothers me is how the driver was already tightly in place. What is actually the variable here? It leaves me wondering if it’ll happen again.
Yeah, I have a feeling this might be the same thing. The tolerance has very little room for error. Maybe there’s microscopic variations in the thickness of the retaining ring. And just the right rotation of the battery tube might bring it close enough to short.
There are several causes. First of all make sure that the driver and switch PCB are both centered. If the ring has an offset it might not work correctly. Also check for defects in the anodization of the inner tube. Pull it out, look if there are any scratches, especially at the little step. If there are any, look for a cause, remove it and tape something over the scratch. Then screw on the tailcap. Check that there is no short between the outer and inner tube. Same for the spring and inner tube. If that is OK fully assemble the light.
Never had a problem with mine, but as you said, tolerances are pretty small.
Eyeballing it, looks like everything is centered. Don’t see any tube bending. No scratches through the anodizing. But I have some kapton tape that’s very thin. I’ll try putting one wrapping of it on each end of the battery tube.
Hi, I need some help with my FW3A. It is not working properly after I did an emitter swap. When I insert the battery and loosely screw the head on the light turns on at a normal brightness, the tail switch doesn’t do anything at this point. When I fully screw the head on the light stays on and cannot be turned off unless I unscrew it. The modes appear to work as normal but a single click to turn off the light just puts it on a low brightness and not off.
My light is the 219C version, and I flowed the SST-20 FD2 emitters on it with a candle. Also I should mention I had forgotten that the battery was still inside the host when I was desoldering the red and black wires from the board and when lifting it off I saw a spark.
I am thinking I have probably messed it up when I forgot to remove the battery, and the thing in the driver that tells the light to turn off is scrambled. So would reflashing the driver help? (I don’t have the necessary equipment for a reflash so I would need to buy it) or should I just try to source a new driver?
I have tested the LED board with a mulitmeter and it works.
The wires of the driver don’t appear to be damaged, the wire housing is intact.
I have cleaned all surfaces of the head, board, driver, and threads, with isopropyl.
I have tried using a multimeter to check for continuity, and there are no issues with the tail / body tube.
That cannot be fixed with a new firmware, you’ve damaged the hardware and need a new driver. Sadly Lumintop doesn’t have drivers anymore and the latest version comes with a different, much inferior driver.
Probably you’ve damaged one of the AMC7135. Depending on the fault it might be possible to check in circuit which one is damaged, otherwise you have to remove one by one until the problem is solved. Then you can either live with a reduced output or find a source for AMC7135 (hard to find at the moment, that’s why Lumintop removed them from their drivers). Either way you need a hot air station to remove the affected 7135.
OK, so I’d been using my stubby (18350) FW3A with only a few hiccups… had to loosen & re-tighten the head to clear that peculiar auto shut-off when ramping up, just a couple times over the past 2 weeks.
Last night I’d used it a bit. No problems. Set it on my nightstand pointing towards me so I could see the GITD insert… and at about quarter to 6 am, I open my eyes to a blinding bright light. My FW3A had turned itself on & auto ramped to maximum!
I was lucky that I wasn’t in a deep sleep at that point and woke up in time. The head was almost too hot to touch and the table had a hotspot where the head had rested. Switch was inoperable. I unscrewed the head and cut power. Fully tightened the head & proper function was restored.
I wonder, if I did a software lockout would this have still happened?
I’ve never had this trouble with my full size FW3A (18650), just the use of the 18350 tube.
Anyway I’d forgotten to apply the kapton tape I mentioned back in April. Definitely going to give it a try now… Hopefully I can find the stuff! (My junk drawer situation is a bit fubar)
