I just received a black one from Nealsgadgets, took about 20 days to PA. They have them in stock, both black & silver, $2.95 with discount code…
but if you aren’t buying anything else the shipping is $8.00.
I should have got a silver one too, the black doesn’t go well with the stainless bezel I currently have on it, it does go with the anodized bezel so I don’t mind keeping it, but I’m not using it right now.
Neals needs to send me a replacement short tube due to sending the wrong one, so if they will include some clips to the shipment without any extra shipping I’ll get one in silver and another in black, then the black one I currently have can be available for you.
OK thanks, I can try that way too, but I’d like to know for sure if that’s actually the correct placement.
I’d also like to know what the purpose of it is? Having it resting on the shoulder will make the gap at the clip even wider, that’s why it didn’t seem right.
But twisting it in to work it down between the tubes also didn’t seem right, I assumed it was an afterthought maybe to help keep it centered.
Thanks pennzy, great photo of the o-ring placement in the zeroair review, the CPF post shows 3 O-rings with one down between the tubes like I have one, to center it as I thought…
“If that lower one falls out then it can lead to the tube not meeting the ring on the head concentrically and actually touching the ”live” end on the wall of the head and making the light imposssible to switch off. That happened to me on the 18350 tube I bought from Neal’s and no matter how I tried I could not get that lower O-ring to go back into place so I ended up shrinking some battery wrap around the tube which worked perfectly to keep it centred inside the wall of the light”
Doesn’t sound right. For a “small batch”?. Maybe someone can verify this. I’ve gradually lost respect for Lumintop as a company over the last couple of years, but I did want another FW3A if I could get one identical to the originals.
Based on my experience with Lumintop I’m kind of surprised they even answered your question. Thanks for sharing that.
Bit of a late reply, but yes the HL3A has also been downgraded. I bought one a few months ago and it has the FET+1 driver. I really wish the Lume1 drivers had the ability to be used in the HL3A and EDC18, let alone be available to buy anymore!
it would be better if they just stopped produce the lights instead they downgraded them so badly… now they just make the lights look terrible vs how the orginal is…
I wonder if they degraded everything, including the Titanium and Copper/Brass versions. I would be super pissed if I spent 100 bucks on a Ti version and got the degraded driver and crappy optic.
Lumintop are shooting themselves in the foot because I have no confidence to buy ANY Lumintop product. If they want to change the specs of product for the worse they need to use a new SKU and product name so everyone knows it is different.
Have to agree, downgrading existing products makes me extremely reluctant to buy any of their new products. If only there was a good FW1A alternative (i.e. Anduril, Tail Switch, Head Diameter <28mm).
