Pick a colour, any colour and someone somewhere will not like it. Just human nature. I myself I’m used to red, yellow/orange and green from traffic lights and traffic signs. My mind associate those colours to certain pattern of behavior.
Both of mine are a steady green in normal use with blue and orange when used as a power bank or charging. I lower the intensity of the LED button because I prefer it that way. I had it off for a while and found that I miss having the green indicator light. I use one almost everyday on the jobsite and always 1/4 turn to manually unlock before putting it back into its storage bag. It’s good to know at a glance that it is ready to go and do not require 1/4 turn to engage the batteries and vice versa when I’m ready to put it away.
Thanks for the info. So it looks like the BLF-LT1-A4 has an updated Anduril version
For reference: the BLF-LT1-A2 - Anduril 2 version check shows 2021-01-25 model 621, so this A4 has a more updated firmware version (January 2021 vs August 2021). Not sure if there are any significant differences though between those 2 versions.
However, I wonder if any chips inside the driver board could also have changed…
I got a LT1 with the latest board and tested the 8 flashing pads and the 8 pins of the ATtiny85 with a multimeter. I can confirm that they correspond to each other. See the labelled photo below.
I am going to try to update it to the latest firmware with 200% turbo once I get my SOIC clip.
I see an opportunity for an intrepid party to create an easy flashing adapter jig for the later driver boards with the non-standard pad layout.
It’s something that I imagine a 3D printer would be well suited for.
There’s a big ole hole formed by the contact ring that would neatly accommodate a disc or short cylinder with contact pins, directly connected to the flashing apparatus. The two mounting screws/holes make for easy indexing/reference points.
Or, with short jumpers to a standard connector, serve as an adapter plate of sorts. Emisar’s reflashing kit looks like it uses a standard header connection to the pin end, so unplug that from the ribbon cable, plug in the LT1 adapter plate, and voila, Bob’s your uncle.
The screw holes could also make an alternative “bridge”-like design feasible, without having to use additional material to solely for locating purposes within the hole with a disc.
Depending on when the firmware is loaded in the production process, I wouldn’t be surprised if the factory might already employ something like this…
Flashing flashlight firmware is a niche within a niche, so it’s not an idea that will form the basis of a business empire, but it would be a neat community project.
To be honest, it is very easy to get to the chip on the LT1, you just need to unscrew 2 screws and the driver pops out, there is no glue and no need to desolder anything.
It literally takes less than a minute.
Once you have access to the chip you can just use a standard SOIC clip to flash it.
Cant find anywhere does LT1 has low voltage protection? I am asking because somehow my LT1 stopped working and when I checked batteries they were totally empty I dont remember exact voltage but it was close to 0V. I have newest driver from Sofirn with powerbank function.
Question: I just received my BLFLT1 with the A2 driver board and green LED’s. I’m trying to use the power bank function without any success. It will not charge my original LT1 or my SP36 BLF. When connected to my S21 Ultra it charges at 300 mA which is not enough to keep the screen on and hold its own let alone charge the phone. My USB DMM reports 4.75 volts at .294 amps when attempting to charge my phone. I tried every USB C to USB C cable I own and see the same. Several are higher end Anker cables. Any info appreciated.
Oof, blue would imho indeed be a serious mismatch for the intended use. It is a lantern and this makes it more important to use a colour that is suitable for a nightlight, camping, etc. Much more important than with normal flashlights. Blue wakes you up and personally I don’t want that in the same room where we sleep. With amber it can just stand on a bedstand or next to your pillow in a tent, basically in your face and you won’t be bothered by it.
And since this is the original LT1 thread, I just wanted to give a big thank you to DBSAR (and Sofirn) for creating this thing! The LT1 is absolutely THE BEST latern I’ve ever owned and my son and I use it every night as a bedtime story light. Good moments
Add me to the happy LT1 owner list. Love it and use it all of the time. The links earlier in the thread for the shade and base are appreciated as well. The accessories make the lantern more versatile.
While it was myself who got the project started, I have an awesome team and contributors who spent time, and worked to make it a reality, including, ToyKeeper, SIGShooter, Barry0892, DEL, The Miller, Phlogiston, Lexel, sbslider, BlueSwordM, bmengineer, Lux-Perpetua and amishbill. these all deserve the equal credit on this project, ( and future projects we work on.
An update on the LT1, and other projects including the LT1M (mini)
The pandemic has slowed things down quite a bit, including my big move, lifes-change, etc. But i am still dedicated to new progress on this BLF project with Sofirn for future models, advancements, etc.
While it may have been myself who got the project started a few years back, I do not deserve all the credit in this what so ever… I could not have done this alone at all… And with an awesome team and contributors who spent time and worked to make it a reality, including, ToyKeeper, SIGShooter, Barry0892, DEL, The Miller, Phlogiston, Lexel, sbslider, BlueSwordM, bmengineer, Lux-Perpetua and amishbill.
These all deserve the equal credit on this project, (and future projects we work on.) i wis those who enjoyed this venture and a happy customer of the Sofirn BLF LT1, give them all a great thanks of appreciation. You all are amazing, and valued in this project so much! Along with the family of the BLF community, SB working so much to make this community great, I again thank you all from my heart. – Dennis / DBSARlight
I used this lantern a bit last summer, then left it somewhere on a table.
Today I try to turn it on and won’t turn on. So I take out the batteries and see that 3 of them are discharged downto 2.3V and one is at 3.7V.
I’m not sure if this is normal or not, but I thought I should post about it.
It seems that it self-discharges quite a lot when not in use, and not evenly.
