CRX TEC XP-L HI v2 5D - H17FX - 18350 - Rv Clicky Tail sw - 1012lm.
Made from titanium pill capsules found on AliExpress.
Two lights and a cell charger,
Ti-6Al-4V grade 5 titanium alloy
Copper lined body
Cree XP-L HI v2 5D emitter
Lava red afterglow bezel gasket
18mm x 12mm LOP reflector
18mm x 2mm ARC glass
KD 16mm Copper DTP MCPCB
10mm thick copper LED shelf
25mm x 1mm brass pill housing
Dr. Jones 17mm H17-FX configurable driver
Lucidrv2 firmware
Reverse clicky tail switch, bypassed spring
Screwed bezel & tailcap
Slimline pocket clip
18350 cell compatible
Triple 11mm x 1.4mm ice red tritium vials in tail
Max – 1012lm, 3A - 784lm
Max Throw -
Length – 94mm
Width – 22mm
Weight – 117g (with 18350 cell)
CRX TEC XP-L HI continuous runtimes:
I really like the cut in pattern on the body.
I had considered buy a Ti Dawn for this pattern.
But there’s no clip you say…
And now a triple emitter pocket rocket version!
CRX TEC Triple XP-L HI v2 5D - H17-FX - 18350 - Rv Clicky Tail sw - 2100lm.
Made from titanium pill capsules.
Copper lined body
Triple Cree XP-L HI v2 5D emitters
Lava red afterglow LED gasket
Carclo 10507 optic
20mm x 1.5mm ARC glass
Noctigon 20mm triple Copper DTP MCPCB
20mm x 8mm thick copper & brass LED shelf
H17-Fx Lucidrv2 firmware
Reverse clicky tail switch, brass contact
Max sustained output - 770lm.
CRX 13mm x 4mm random Ti ice red tritium glow fob on chain
Max output – 2100m, 924lm (3A)
Max throw - 180m, 120m (3A)
Length – 76mm
Width – 22mm
Weight – 92g (with 18350 cell)
CRX TEC Triple Cree XP-L HI continuous runtimes:
These things must run through the cells so how about a…
CRX TEC 18350 Titanium 1000mA Pocket Charger/ Spare cell carrier.
Made from a titanium pill capsule.
Copper lined body
S9 1000mA micro USB charging board
Max charging current – 1000mA
Length – 51mm
Width – 22mm
Weight – 55g (with 18350 cell)
So for the last ti pill capsule I made a handy on the go 18350 cell pocket charger/ spare cell carrier.
With this I can carry a spare cell for the TEC lights and also have a charger on hand for when I’m out & about in a form factor not much larger than an 18350 cell.
Copper lined body with a 1A charging circuit in the head.
Red indicator light for charging, blue for charged.
The unit is potted and with the threaded head/ silicone o-ring it is fairly water resistant.
Stay cool
