NEW high current 60V 24A 1440W power supply RD6024 is released now
177 posts / 0 new
RD tech
RD tech's picture
Last seen: 1 day 15 hours ago
Hello, our new product RD6024 4 digit high current power supply is coming. Hope you like it and you can check the product information and make order in the link below:
https://www.aliexpress.com/item/1005003744641750.html
As what we do all the time, we will set the lowest price when new product is released, so here is the price:
RD6024:$75.99USD (normal price over:$100USD)
RD6024-W:$79.99USD (normal price:$105USD)
Discount Time: 2022.1.4-2022.1.9 PT .
We also prepare the S800 case and input 1000W PSU for you to assemble them together to make a complete power supply. But RD6024 is 1440W max, 1000W PSU can let RD6024 output 24A or 60V, but it is not enough for 60V and 24A full output, you can find a 1500W 65V power supply for it, but you need to choose the good quality one, and check if it can be placed into S800 case.
Here are some important features about RD6024:
  • Support 60V 24A 1440W maximum output
  • 4-digit resolution, accurate display
  • Low ripple: 100mV@12A, 150mV@24A VPP
  • High efficiency: full output efficiency >95%
  • Optional display style(classic/detail display/curve style)
  • 15 colors can be chosen for displayed parameters
  • New setting interface, more user friendly
  • Optional output power limit, protect the device
  • 2.4 inch screen/PC software/APP control(RD6024W only)/support firmware update/multiple protections/keypad control/keypad lock
  If you have any questions about RD6024, you can contact us in the ways below:
  1. Contact us on Aliexpress directly
  2. Contact my email:1749808860@qq.com or WhatsApp: +8615868147353or WeChat: 15868147353
If you have any interest in USB tester or power supply, please contact me
this is my shop on Aliexpress: https://rdtech.aliexpress.com/store/923042
Edited by: RD tech on 04/08/2022 - 22:24
jimahi
Last seen: 7 hours 16 min ago
I always wondered why your prices don’t clearly state that the power supply is not usable unless you buy the other parts (case & PSU). It looks like the price for a complete system is double the advertised $75.99. I find this a bit misleading as I’ve gone to your site a few times only to be disappointed that the actual price for a complete power supply is much higher than what you advertised. Why not advertise the complete price here on BLF instead of the low price for one of the parts (programmable buck converter) only? Maybe you could create a special BLF ‘package’ price promotion that includes everything needed for a fully functioning power supply… Why would someone buy just the front panel unit (RD6024) without the other parts (aside from upgrading)? Is a 65V or 68V rail common in labs (like 48V rail in telecom racks) and thus many customers don’t actually need the 65V or 68V PSU? Please take this post as more curiosity questions rather than complaining. I will say that you make good products (as I have used some of your products in the past).
icpart
Last seen: 3 days 21 hours ago
I need only panel not whole product. I have very large 1KW transformer which stay around and I want to make PSU with it. Also yeterday I saw there is aluminum CNC case made from user 100Mhz from taobao for RD power supplies. He made some amazing work for another soldering stations and cases of anothers products. So some of us may prefer to make own case or order another one.
RD tech
RD tech's picture
hello, because not everyone needs the whole set, they just need the panel, they have their own AC to DC PSU, and they prefer to make the shell by themselves, our products are all DC to DC power supply, no mater the old DPS/DPH/DP power supply or new RD power supply series, they are all DC to DC power supply, we can prepare the case and input PSU if you need, but we will let you choose what you need.
RD tech
RD tech's picture
yes, in the feedback, there are may DIY power supplies based on our power supply, customers have all kinds of thoughts, which is really great, we have made 2 videos about the DIY power supplies in our YouTube channel
jimahi
Ah, OK. Now I understand that these are priced primarily for folks using their own PSU or who are NOT buying the PSU from RD Tech. I would have thought it was the other way around – that most folks would buy the complete power supply and not just the panel. I’m surprised that most of your customers purchase only the panel. Especially with all of the warnings on your site about the possible damage that may occur when using an inferior PSU. Thanks.
RD tech
RD tech's picture
yes, and for input power supply, just do not use very chep PSU it should be ok, for those electric bike charger, second hand power supply, sometimes there will be high voltage peak, which exceeds the input limit of our product, so it is not suitable, but if you have good one, there is no problem
RD tech
RD tech's picture
RD6024 60V 24A 1440W actual test about accuracy/ripple and output efficiency
RD tech
RD tech's picture
the promotion lasts to 9th, after that though there will be promotion, but not as big discount as this time
RD tech
RD tech's picture
X25A cable for RD6024 full output
icpart
Facepalm That’s it not right way to measure ripple voltage with that probe hooked to output and that long ground wire. Also most of time is used 50 ohm BNC termination setup for best measurements. You must use short wires and probes as possible. Also about efficiency for BLF users more interesting will be when you have low output voltage and higher load currents. That’s its right way
Also for EU citizens real price is not 75$ but over 95$ with VAT.
RD tech
RD tech's picture
hello, the ripple test way in the EEV blog video is correct, it is more accurate, but most customers does not have same condition to test it, we show a way that customer can do in their home to get the same result, you can see in the technical parameter chart we already indicate that the repple is 100mV@12A,150mV@24A, but actually it is not such big when you test it.
for the second thing you said ripple under low voltage and big current, the ripple is mainly influenced by the current, the voltage does not influence it much, and we show the ripple at big current
RD tech
RD tech's picture
and for VAT, it is charged by Aliexpress, we do not get it, and it is used for your customs when the package arrive at your customs, so that you do not need to pay it, it is the new law for EU area since 2021-7-1
RD tech
RD tech's picture
after 5.5 hours the RD6024 promotion will end, and there will be winter sale for the whole store, the price at that time is from 85USD(no VAT price)
moderator007
moderator007's picture
Pulled the trigger on one yesterday. I have been waiting on this 24 amp model for awhile.
I have two of the older DPS models which have been great but I really wanted this newer better display model.
The on and off membrane switch on the DPS model was a little hard to push, sometimes the whole power supply would move just trying to activate the on switch. Hoping this one is much easier.
RD tech
RD tech's picture
thank you , hope you like that
thefreeman
thefreeman's picture
Last seen: 10 min 24 sec ago
I did the same, I also have a DPS model (5020) and yeah the interface is really subpar.
24A is nice although I would have preferred 30A.
chops728
Last seen: 5 hours 46 min ago
I’m wondering if this model has reverse polarity protection — I’ve messed up two 5020 charging batteries
Mark M
Mark M's picture
Last seen: 2 hours 4 min ago
I didn’t purchase because I could not find a suitable power supply to power this, any recommendations?
RD tech
RD tech's picture
for now there is not cheaper and suitable power supply
thefreeman
I’m using a 95W laptop power brick (20V) to power my DPS5020, which has been sufficient for 4.2V20A.
I also have a meanwell 48V4.5A which I’ll be using with the RD6024, I don’t need the full 60V24A power, so that’ll be sufficient for my use.
RD tech
RD tech's picture
normally people don’t need 60v/24A in the same time . only use 60v or 24a
so some lower power PSU is ok
Mark M
Mark M's picture
I probably won’t ever utilize both 60v and 24a but that doesn’t stop me from wanting it. I use my RD6012 for electrochemistry and it’s been great for that, more likely to use higher voltage than high current in that application, I am just being picky. Smile
moderator007
About the cheapest I saw. I have no idea how good the seller is, just pointing you to it.
https://www.aliexpress.com/item/4000816881141.html
Mark M
Mark M's picture
moderator007 wrote:
About the cheapest I saw. I have no idea how good the seller is, just pointing you to it. https://www.aliexpress.com/item/4000816881141.html
That looks nice, I can’t find max dimensions for a power supply in the S800 case, but it’s very close in size to the one RD has listed on AliExpress so maybe it will fit?
RD tech
RD tech's picture
for RD series power supply, use the green and black terminals to charge battery, only when you connect it in the right way, it will charge, if you connect it in the wrong way, it will not charge even you turn on the output
RD tech
RD tech's picture
according to our PSU size 241*125*65mm, after install it there is not much space, so I do not know if this power supply can be put into the S800 case because its size is L250*W135*H70mm.
RD tech
RD tech's picture
for now the promotion has finished, the price is normal price
RD tech
RD tech's picture
hello, the RD6024 promotion has finished, for now the price has returned to the normal standard, you can get 2 USD coupon now when placing the order
RD tech
RD tech's picture
RD6024 feedback
it came so quickly, the quality of the product is on top, I am delighted with this device ! The seller answers all questions, the packaging is powerful and withstands Russian mail. Take it, you will not regret it.
RD tech
RD tech's picture
RD6024 feedback
Fast, high quality, excellent! I order not for the first time
