Just got firefly PL09mu what a great light one question though I think the andruil is a very stripped down version there are no blinky function or any other in-depth menu functions except strobe and battery indicator anyone else experiencing this please reply
Hey lojik thanks but yea I tried both andruil 1&2 sequences did factory reset everything I could but all it has is strobe and battery check im really confused if you hear anything else please let me know and I’ll do the same
I should’ve looked earlier, FF included with the box came an abbreviated operations/diagram instructions.
Step ramping
smooth ramping
turbo
Battery check
Strobe’s
Lock out
Aux off low high blinking
are all the features noted
Oh so this is a more muggle friendly version of the Nov-Mu AND of Anduril. Kinda like a new cross between simple mode and advanced. Good to know. Thank you for confirming it with the included manual.
Thanks for the explanation but I’m a little bummed this was my first endevour to the enthusiast flashlight world and the”FF” definitely wasn’t advertised I guess I’ll just have to buy another lol… P.S. still an awesome light though
No the light doesn’t accidentally turn on haven’t had that problem besides you can lock it out via 4 clicks or 1/4 turn on tail cap its a great flooder excellent color rendering
Can you do 15 clicks from Off and check what is the Anduril version (if it does run Anduril)?
I’m guessing this may be Anduril 2, and after a factory reset, Anduril 2 will be in the Simple UI mode which has the more advanced features Disabled (ie. only Battery-voltage Check, but no Strobe modes)
In case it is Anduril 2 with Simple UI, then do 10H (from Off, do 10 clicks but the last click should be a “hold” (do not release, until the light blinks once), This will set it to Advanced UI where the other features like Strobe are then enabled.
Anduril UI made specifically for this light it is a simplified version its not anduril 2 either it has one strobe function but the rate is adjustable by ramp up or down if you want full anduril version the light will have to be flashed. I tried factory reset multiple times its permanently set to a more simple version
