Fireflies PL09MU new E21A 21700 flash light from Fireflies
Hey lojik thanks but yea I tried both andruil 1&2 sequences did factory reset everything I could but all it has is strobe and battery check im really confused if you hear anything else please let me know and I’ll do the same
Ok, sorry I wasn’t more help. Figured it was worth a try if it hadn’t been done yet is all.
I really appreciate it I’m kinda new at this needed a new hobbie so any help is good help thanks again
Twist the cap off, leave it a few seconds and tighten it back.
From off, do ten clicks and hold untill the light flashes.
I think your problem is that you’re stuck in simple mode.
No matter how many times I do factory reset 10 clicks hold the light never indicates that the mode switched it does nothing I am stumped
Mine has an abbreviated program fyi.
Thank you for the heads up. As far as you can tell, what disappeared in the abbreviation?
I should’ve looked earlier, FF included with the box came an abbreviated operations/diagram instructions.
Step ramping
smooth ramping
turbo
Battery check
Strobe’s
Lock out
Aux off low high blinking
are all the features noted
Oh so this is a more muggle friendly version of the Nov-Mu AND of Anduril. Kinda like a new cross between simple mode and advanced. Good to know. Thank you for confirming it with the included manual.
Thanks for the explanation but I’m a little bummed this was my first endevour to the enthusiast flashlight world and the”FF” definitely wasn’t advertised I guess I’ll just have to buy another lol… P.S. still an awesome light though
Does the light accidently switch on?
I tend to carry in a pocket full of junk :slight_smile:
Are there reviews of this light. I don’t care for lumens above 1000, but I’m a stickler for high efficiency flooders with a spotless beam.
No the light doesn’t accidentally turn on haven’t had that problem besides you can lock it out via 4 clicks or 1/4 turn on tail cap its a great flooder excellent color rendering
Can you do 15 clicks from Off and check what is the Anduril version (if it does run Anduril)?
I’m guessing this may be Anduril 2, and after a factory reset, Anduril 2 will be in the Simple UI mode which has the more advanced features Disabled (ie. only Battery-voltage Check, but no Strobe modes)
In case it is Anduril 2 with Simple UI, then do 10H (from Off, do 10 clicks but the last click should be a “hold” (do not release, until the light blinks once), This will set it to Advanced UI where the other features like Strobe are then enabled.
Anduril UI made specifically for this light it is a simplified version its not anduril 2 either it has one strobe function but the rate is adjustable by ramp up or down if you want full anduril version the light will have to be flashed. I tried factory reset multiple times its permanently set to a more simple version
Thanks for the quick response!
Any idea if this model can be updated to the regular Anduril 1 or Anduril 2? Does this light have flashing pad/points for updating firmware?
Yes it does have the flashing pad and can be updated
Which build should I flash, if I would want to?
I’m waiting for the tool to do so its on the way but I think the fireflies PL47 will work since they are very similar that is the flash im gonna try first
I wish I had saw this thread earlier. Jack contacted me in November to share a coupon code and affiliate link for the pl09MU, but only on Reddit.
anyway, when I was asking him for details about it back then (because it hadn't been released yet), he had told me it had a "simplified version of Anduril".
I hadn't thought to share that, mostly because I was so busy with the holidays. I had barely even shared his coupon, and I didn't share an affiliate link. Mostly because it was confusing, and I wasn't concerned with it. I just wanted to get the code to people.
I finally have one on order, excited to check it out. It will be my FIRST mule and FIRST e21a light!
Thanks i appreciate it but got 15% off on NealsGadget thanks to Matt Smith but you are gonna love this light the Nichia leds have amazing CRI and brightness let me know what you think
