raccoon
January 6, 2022, 12:09am
14
I would test BLF on my other computer, but I'm running Memtest86+ on it right now, and that program takes forever to test RAM.
(Some of my RAM is bad, and I need to figure out which sticks of RAM to replace.)
I'll test out BLF on my mom's laptop in the meantime.
Bort
January 6, 2022, 12:12am
15
I would test BLF on my other computer, but I’m running Memtest86+ on it right now, and that program takes forever to test RAM.
I’ll test out BLF on my mom’s laptop in the meantime.
I had that happen on an old computer, took a long time to figure out it was the RAM because it was very intermittent.
I tell you being down to 32MB (yes MB) of RAM was no fun even way back when.
So you have my sympathies
sb56637
January 6, 2022, 12:15am
16
Thanks, appreciate it. It’s probably only going to cause trouble on a browser that was already using the old version of the Advanced editor. Still not sure why Chrome wouldn’t clear the cache, but that’s the issue.
raccoon
January 6, 2022, 12:18am
17
Okay, I'm on my mom's laptop.
I had to run CCleaner to be able to post on BLF using Chrome.
I did not get any errors like on my laptop, so that's good.
By the way, when I could not post on BLF, I couldn't post with Advanced Post Editor, Simple Post Editor, or Plain Text.
sb56637
January 6, 2022, 12:19am
19
Okay, I’m on my mom’s laptop.
I did not get any errors like on my laptop, so that’s good.
Had you recently used BLF on that laptop and browser?
raccoon
January 6, 2022, 12:23am
20
Bort:
It took me a while to figure it out for me too.
My desktop computer would give me Blue Screens of Death every day or two.
I tried lots of fixes, and even tested RAM while running Windows, but I was told by Windows that my RAM was fine.
So far, Memtest86+ has done at least two passes, and has found lots of errors.
I won't know how bad it is though until I stop Memtest86+'s test, and I'm not going to do that until I get up tomorrow.
Speaking of which, it's almost my bedtime.
Bort
January 6, 2022, 12:34am
22
Bort:
I had that happen on an old computer, took a long time to figure out it was the RAM because it was very intermittent. I tell you being down to 32MB (yes MB) of RAM was no fun even way back when.
I won’t know how bad it is though until I stop Memtest86+’s test, and I’m not going to do that until I get up tomorrow.
Speaking of which, it’s almost my bedtime.
If i remember correctly it was a process of elimination for me but windows would BSOD spontaneously in those days anyways so that made it harder to track down.
I had an HP hand me down blow a ram chip but i forget how but i figured it out quickly.
My main rig uses a good brand of RAM so no failures in the last 8 years on it, fingers crossed.
But Windows 8.1 is dead in 2023 so i will need a new computer then.
My desktop is overclocked, so I have to use very good RAM.
I've had it almost twelve years, though I did add more RAM to it about two years ago.
I won't know which RAM sticks are bad until tomorrow.
You don't like Windows 10?
It's very similar to 8.1
And W11 is very similar to W10.
Bort
January 6, 2022, 1:17am
24
I’ve had it almost twelve years, though I did add more RAM to it about two years ago.
I won’t know which RAM sticks are bad until tomorrow.
No overclocking on my end.
Windows 11 on a 10 year old (by 2023) computer is not going to run very smoothly.
That said no previous computer of mine has lasted this long.
Depends on the computer's components.
My gaming desktop will be twelve or thirteen years old next year, and I'm sure that it'll run W11 just fine.
There is a workaround to install W11 on old computers, though I don't think I'll be able to get updates.
Bort
January 6, 2022, 1:27am
26
Depends on the computer’s components.
My gaming desktop will be twelve or thirteen years old next year, and I’m sure that it’ll run W11 just fine.
There is a workaround to install W11 on old computers, though I don’t think I’ll be able to get updates.
I have a i7 4770K, 16GB Ram and so forth. Top of the line at the time.
Its fine for now but i am noticing some slowdown running modern software.
I prefer simple and updated so i plan to upgrade the computer once the updates for Win 8.1 run out.
darosk:
Test
Thanks! Did it just work for you, or did you clear your browser cache? And which browser?
freeme
(youtube.com/@1thedeals)
January 6, 2022, 8:26am
29
Advanced Post Editor not working.
Advance Post Editor is working fine. This is one of the few sites that go well with my FF.
dave1010
(dave1010)
January 6, 2022, 8:36am
31
The Advanced Post Editor didn't work for me on Chrome either.
How I fixed it:
Right click anywhere on the page, click on Inspect
(If you don't see that then click the 3 dots in the very top right of Chrome and go to More tools
, Developer tools
Go to the Network
tab
Check Disable cache
Reload the page
Go to the Advanced Post Editor and check it works
Un-check Disable cache
and close the web inspector
dee-u
(dee-u)
January 6, 2022, 8:45am
32
Test test test
Advance editor seems to work in Chrome for me.
This is off-topic, but luckily that's usually not a problem around here.
I didn't like the UI of Memtest86+, so I used MemTest64.
I know that Memtest86 and Memtest86+ are better programs, but I got good results from MemTest64.
My problem is with one stick of RAM, but I'm not sure which one.
I'll have to remove one or two sticks of RAM (out of 4) at a time and re-run MemTest64 to narrow it down.
