To be honest, it is very easy to get to the chip on the LT1, you just need to unscrew 2 screws and the driver pops out, there is no glue and no need to desolder anything.
It literally takes less than a minute.
Once you have access to the chip you can just use a standard SOIC clip to flash it.
Cant find anywhere does LT1 has low voltage protection? I am asking because somehow my LT1 stopped working and when I checked batteries they were totally empty I dont remember exact voltage but it was close to 0V. I have newest driver from Sofirn with powerbank function.
Question: I just received my BLFLT1 with the A2 driver board and green LED’s. I’m trying to use the power bank function without any success. It will not charge my original LT1 or my SP36 BLF. When connected to my S21 Ultra it charges at 300 mA which is not enough to keep the screen on and hold its own let alone charge the phone. My USB DMM reports 4.75 volts at .294 amps when attempting to charge my phone. I tried every USB C to USB C cable I own and see the same. Several are higher end Anker cables. Any info appreciated.
Oof, blue would imho indeed be a serious mismatch for the intended use. It is a lantern and this makes it more important to use a colour that is suitable for a nightlight, camping, etc. Much more important than with normal flashlights. Blue wakes you up and personally I don’t want that in the same room where we sleep. With amber it can just stand on a bedstand or next to your pillow in a tent, basically in your face and you won’t be bothered by it.
And since this is the original LT1 thread, I just wanted to give a big thank you to DBSAR (and Sofirn) for creating this thing! The LT1 is absolutely THE BEST latern I’ve ever owned and my son and I use it every night as a bedtime story light. Good moments
Add me to the happy LT1 owner list. Love it and use it all of the time. The links earlier in the thread for the shade and base are appreciated as well. The accessories make the lantern more versatile.
While it was myself who got the project started, I have an awesome team and contributors who spent time, and worked to make it a reality, including, ToyKeeper, SIGShooter, Barry0892, DEL, The Miller, Phlogiston, Lexel, sbslider, BlueSwordM, bmengineer, Lux-Perpetua and amishbill. these all deserve the equal credit on this project, ( and future projects we work on.
An update on the LT1, and other projects including the LT1M (mini)
The pandemic has slowed things down quite a bit, including my big move, lifes-change, etc. But i am still dedicated to new progress on this BLF project with Sofirn for future models, advancements, etc.
While it may have been myself who got the project started a few years back, I do not deserve all the credit in this what so ever… I could not have done this alone at all… And with an awesome team and contributors who spent time and worked to make it a reality, including, ToyKeeper, SIGShooter, Barry0892, DEL, The Miller, Phlogiston, Lexel, sbslider, BlueSwordM, bmengineer, Lux-Perpetua and amishbill.
These all deserve the equal credit on this project, (and future projects we work on.) i wis those who enjoyed this venture and a happy customer of the Sofirn BLF LT1, give them all a great thanks of appreciation. You all are amazing, and valued in this project so much! Along with the family of the BLF community, SB working so much to make this community great, I again thank you all from my heart. – Dennis / DBSARlight
I used this lantern a bit last summer, then left it somewhere on a table.
Today I try to turn it on and won’t turn on. So I take out the batteries and see that 3 of them are discharged downto 2.3V and one is at 3.7V.
I’m not sure if this is normal or not, but I thought I should post about it.
It seems that it self-discharges quite a lot when not in use, and not evenly.
That is very unusual, as all four of the cells are held in parallel, thus they can only discharge or charge all at the same rate. There must be some issue with the cells not contacting the top ring, (as flat-top cells would cause that and not recommended.) even then the cells should never self-discharge at that rate unevenly unless the cells are defective.
A friend had a similar situation but he had 1 battery below 2v with the other 3 above 3.8v. He also hadn’t used it in over a year and like Kat’s it wouldn’t turn on.
It’s interesting that his light as well as Kat’s wouldn’t turn on with at least 1 battery > 3.7v given that the LT only needs 1 battery to run. Unless as you say that they weren’t making contact with the ring for some reason.
If I get a chance I’ll look at his light and batteries. Could be that he’s using flat-tops where contact with the ring can be hit-or-miss depending on the brand.
He was using old laptop batteries which could account for the 1 cell reading so low. As I understand it drain from the switch is minimal and shouldn’t draw much from even a single battery over the course of a year.
I am using flat top Samsung 30Q with solder blobs added and have no issues with LT1, a least time I checked, I will check them next time I remember on a meter to see if they are all parallel.
Laptop batteries usually have lived a hard life and I find can fail at random, good for low cost projects through where that is less of a concern.
