We have about a half dozen models here, 18650, 26650, rotary, AA, side switch, binary switchâŠ
I think we need to simplify it, how about two models.
We can look at others in the future is the first two are successful.
A single AA and lithium (my suggestion is 18650 but am willing to look at 21700 or 26650).
I donât think 500 lumens is a good idea, we might think that is not many lumens but it eats batteries fast. We are also used to recharging batteries after not a lot of use but most people would not be. Plus most people are amazed by 200 lumens and never realized a light could get that high, giving them half a car headlight with relatively short runtime is not necessary.
So how about this:
First light:
1AA two mode, 50 lumen and 150 lumen.
No recharge ability.
I hate to foist alkalines on people but lets be honest, this is what most people will end up doing.
I would like to see NiMH and recharge ability, it would make it an amazing light. But people will put alkaleaks in it, recharge and then they explode. Alkalines are very safe until you try to recharge them.
Second light:
18650 or 21700, two mode, 75 lumen and 250 lumen
USB chargeable to 80% which is not 4.2V.
If the battery falls below 2.5V it refuses to charge it.
A side switch can work if it can last years without draining itself.
Otherwise a tail switch.
I recently received an FC11, its a very interesting light, i would make some changes to it but much of what would be needed to make it a grandma light is just software changes. The single mode while its charging is actually quite useful. It appears to be about 50 lumens, am i correct?
Also what is ts self drain rate when off, has anyone measured it?
Three final thoughts:
The other models as a future project?
A rotary sounds fun to be honest.
Second: What colour temperature?
Do we have to choose one or is having multiple doable?
If only one my suggestion is 4000K. Cooler is harsh for older eyes and this is mostly going to be used indoors where 2700K lightbulbs dominate.
That said i prefer 5000K so if we can have multiple i would suggest that.
Third thought:
Could we come up with a firmware that could be put into a production light that would make it a grandma light, perhaps Anduril lite?
It could have a mode group with more lumens if you want to allow it?
It needs very careful hiding, if accidentally changeable it will happen.
