Mouser added several XHP50.3 HD on order, availability announced for February : https://www.mouser.fr/c/optoelectronics/led-lighting/led-emitters/high-power-leds-white/?q=xhp50d&normallystocked=y
I have noticed that 3V version is only 6200K. I was hoping to have choice of 5000K version but seem to be only available with special order like 50.2.
Has anyone found an in-stock supply of XHP35.2 HI in flux bins greater than D4? I hope to find E2 flux bins or greater in 5000-6500K to reflow into my stock GT. Crees data sheets appear to be dated and they are notorious for not listing all available variations. I’ll probably settle for a D4 if nothing turns up. Mouser has plenty in stock and they are easy to deal with.
Still no listings showing for XHP70D-H0 variations (XHP70.3 HI). Id love to try one in a GT with a TA driver, assuming high flux bins once available. Cree’s data sheet looks promising.
I’ll probably cross post this in a few other threads to see if anything turns up…
XHP50.3 HI 4500K 90cri are in stock at Mouser now:
Looking at the data sheet for the XHP50.3, if I’m reading it right, the 3V only comes in 7000K and 6200K in HD and not HI at all.
Is that right?
Thanks for the heads up. I haven’t bought any LEDs for a long time but I think I’ll grab me a few of these.
Man does Mouser make searching for LEDs a pain… if you select XHP50D-HI series, which it’s supposed to belong to according to Mouser, and check “in stock” flag you get 0 search results. In the Cree datasheet they are clearly called XHP50.3 yet Mouser want to use some other series name which in turn doesn’t show this LED that they themselves have labeled as belonging to.
Indeed, my order that was in backorder just shipped, let’s hope they don’t have a trash tint.
Thanks. Ordered.
I put a XHP50.3 HD 4000K 90CRI from Digikey into my Skilhunt H300. My Opple says its a bit green, but thankfully my color-deficient eyes can’t tell :disappointed:
Gchart, that pic looks like a gen2, no? I thought dot three versions had a white silicone pour around the die.
Good eye. That picture was taken before the emitter swap. It was more of a “hurray, I got it open… and here’s what it looks like” picture. I have updated my post to note this.
The new LED does have the white around the die and is not covered in a phosphor pour.
XHP70.3 HI looks interesting.
XHP70.3 HIs have been listed at Mouser, several of them have a MOQ of 1 (none 90CRI ), no lead time info.
https://www.mouser.fr/c/optoelectronics/led-lighting/led-emitters/high-power-leds-white/?q=xhp70d-h0
The XHP70.3 Hi looks like perfect LED for ZL SC700d
XHP50.3 HI 4500K 90CRI from mouser with a beaded TIR :
0.1A
CCT = 4312K (Duv 0.0045)
Color Rendering Index (Ra) = 92.2 [ R9 = 69.3 ]
R1 = 91.6 R2 = 94.2 R3 = 95.7 R4 = 91.0 R5 = 90.1 R6 = 90.5 R7 = 96.2
R8 = 88.5 R9 = 69.3 R10 = 85.5 R11 = 90.0 R12 = 67.0 R13 = 92.0 R14 = 97.6
IES TM-30-15 Rf = 88.76 Rg = 96.79
0.5A
CCT = 4440K (Duv 0.0042)
Color Rendering Index (Ra) = 91.4 [ R9 = 65.8 ]
R1 = 90.6 R2 = 93.1 R3 = 94.4 R4 = 90.8 R5 = 89.4 R6 = 89.0 R7 = 96.2
R8 = 87.7 R9 = 65.8 R10 = 83.0 R11 = 89.5 R12 = 67.0 R13 = 90.9 R14 = 97.1
IES TM-30-15 Rf = 88.94 Rg = 97.42
1A
CCT = 4524K (Duv 0.0034)
Color Rendering Index (Ra) = 90.8 [ R9 = 63.4 ]
R1 = 90.1 R2 = 92.4 R3 = 93.5 R4 = 90.7 R5 = 89.1 R6 = 88.2 R7 = 95.6
R8 = 87.1 R9 = 63.4 R10 = 81.4 R11 = 89.3 R12 = 67.9 R13 = 90.3 R14 = 96.7
IES TM-30-15 Rf = 89.00 Rg = 97.93
2A
CCT = 4586K (Duv 0.0033)
Color Rendering Index (Ra) = 89.7 [ R9 = 58.9 ]
R1 = 88.9 R2 = 91.1 R3 = 92.2 R4 = 90.1 R5 = 88.2 R6 = 86.8 R7 = 94.7
R8 = 85.7 R9 = 58.9 R10 = 78.6 R11 = 88.7 R12 = 68.4 R13 = 89.0 R14 = 96.0
IES TM-30-15 Rf = 88.72 Rg = 98.43
I didn’t test higher because it’s a quick test without heatsink, anyway the tint is sunlike (0.0033), or slightly greener at lower current. Disappointing that it’s not closer to the BBL
The beam looks quite good even with SMO reflectors.
At 0.1A with KR1 SMO reflector :
spot : CCT = 4605K (Duv 0.0033)
Corona : CCT = 4191K (Duv 0.0067)
spill : CCT = 4383K (Duv 0.0032)
for the data thefreeman. Cree is not the new Nichia but it looks decent, 90CRI Cree’s that I have seen before were awfully green (that was before I had a spectrometer, so I can not back that up with duv numbers), this sounds better.
Added a quick spot, corona, spill measurement with SMO reflector
A bunch of them got added in order, availability announced for March.
Cutter has some stock of 3V XHP50.3 in 3B chromaticity.
The 4000K 80+ CRI looks interesting. But man, $12 a pop
