NEW high current 60V 24A 1440W power supply RD6024 is released now
RD6024 60V 24A 1440W actual test about accuracy/ripple and output efficiency
www.youtube.com/embed/W8CDqu0i-1o
the promotion lasts to 9th, after that though there will be promotion, but not as big discount as this time
X25A cable for RD6024 full output
:person_facepalming: That’s it not right way to measure ripple voltage with that probe hooked to output and that long ground wire. Also most of time is used 50 ohm BNC termination setup for best measurements. You must use short wires and probes as possible. Also about efficiency for BLF users more interesting will be when you have low output voltage and higher load currents. That’s its right way
Also for EU citizens real price is not 75$ but over 95$ with VAT.
hello, the ripple test way in the EEV blog video is correct, it is more accurate, but most customers does not have same condition to test it, we show a way that customer can do in their home to get the same result, you can see in the technical parameter chart we already indicate that the repple is 100mV@12A,150mV@24A, but actually it is not such big when you test it.
for the second thing you said ripple under low voltage and big current, the ripple is mainly influenced by the current, the voltage does not influence it much, and we show the ripple at big current
and for VAT, it is charged by Aliexpress, we do not get it, and it is used for your customs when the package arrive at your customs, so that you do not need to pay it, it is the new law for EU area since 2021-7-1
after 5.5 hours the RD6024 promotion will end, and there will be winter sale for the whole store, the price at that time is from 85USD(no VAT price)
Pulled the trigger on one yesterday. I have been waiting on this 24 amp model for awhile.
I have two of the older DPS models which have been great but I really wanted this newer better display model.
The on and off membrane switch on the DPS model was a little hard to push, sometimes the whole power supply would move just trying to activate the on switch. Hoping this one is much easier.
thank you , hope you like that
I did the same, I also have a DPS model (5020) and yeah the interface is really subpar.
24A is nice although I would have preferred 30A.
I’m wondering if this model has reverse polarity protection — I’ve messed up two 5020 charging batteries
I didn’t purchase because I could not find a suitable power supply to power this, any recommendations?
for now there is not cheaper and suitable power supply
I’m using a 95W laptop power brick (20V) to power my DPS5020, which has been sufficient for 4.2V20A.
I also have a meanwell 48V4.5A which I’ll be using with the RD6024, I don’t need the full 60V24A power, so that’ll be sufficient for my use.
normally people don’t need 60v/24A in the same time . only use 60v or 24a
so some lower power PSU is ok
I probably won’t ever utilize both 60v and 24a but that doesn’t stop me from wanting it. I use my RD6012 for electrochemistry and it’s been great for that, more likely to use higher voltage than high current in that application, I am just being picky. :slight_smile:
About the cheapest I saw. I have no idea how good the seller is, just pointing you to it.
That looks nice, I can’t find max dimensions for a power supply in the S800 case, but it’s very close in size to the one RD has listed on AliExpress so maybe it will fit?
for RD series power supply, use the green and black terminals to charge battery, only when you connect it in the right way, it will charge, if you connect it in the wrong way, it will not charge even you turn on the output
according to our PSU size 241*125*65mm, after install it there is not much space, so I do not know if this power supply can be put into the S800 case because its size is L250*W135*H70mm.
